POV-Ray : Newsgroups : povray.off-topic : A question about Java generics (not a flame) Server Time
9 Jun 2026 18:38:43 EDT (-0400)
  A question about Java generics (not a flame) (Message 11 to 20 of 63)
Subject: Re: A question about Java generics (not a flame)
Date: 9 May 2008 16:38:04
Message: <4824b62c$1@news.povray.org>
Warp wrote:
>   Yeah, but that's only possible in languages with weak typing (I think
> that's the term?)
"Dynamic typing" is the term you're looking for - expressions have
types, but not variables.
"Static typing" being the alternative, where variables have types.
"Weak typing" is when type operations aren't enforced, like in C.
"Strong typing" is when type operations are enforced, like Java.
You can have strong typing that's also dynamic typing, like Smalltalk or
Lisp or Erlang, or static typing that's weak like in C, or static typing
that's strong like (say) Haskell (as I understand it), or dynamic typing
that's weak (like Forth or assembler).
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 9 May 2008 16:39:28
Message: <4824b680$1@news.povray.org>
Orchid XP v8 wrote:
>>   Java supports generics.
> ....OK, I just learned something.
Are they actually supported as new types? Or is it just syntactic
shorthand? I wouldn't think you could really have generics if you didn't
change the .class file format, which I think Sun's trying to avoid?
Date: 9 May 2008 16:45:28
Message: <4824b7e8$1@news.povray.org>
Orchid XP v8 wrote:
> So... it's Turing-complete?
Yep.  I saw a turing machine emulator written as templates, with a
series of error messages from the compiler tracing the path through the
state changes.
In any case, generics are a subset of templates. It's entirely possible
to think that generics are a good idea and that templates are a bad way
to implement them. For example, you have to parse and compile the
templates each time from source, and you get a new blob of code for each
type you instantiate a template with. Both of these are a bad idea when
you're trying to make a system where you can distribute object code
without source for generics, or you want to instantiate a generic at
runtime with some other class you just loaded.
Now, "crippled" is what I'd call the baroque C++ syntax. I mean, really,
folks, can't we accept that languages that aren't C don't need to avoid
C special characters in new syntax? :-) What's with this "::" for
namespaces in Tcl and <<>> for generics in Java? Ugly, guys, uUUUuugly!
Date: 9 May 2008 17:31:38
Message: <4824c2ba@news.povray.org>
http://java.sun.com/docs/books/tutorial/java/generics/erasure.html
http://java.sun.com/docs/books/tutorial/extra/generics/legacy.html
http://java.sun.com/docs/books/tutorial/extra/generics/convert.html
Basically, it looks like anything related to generics is removed from the
compiled code.
Date: 9 May 2008 20:49:51
Message: <4824f12e@news.povray.org>
  A compiler which supports export templates could conceivably have
precompiled templates for certain (although obviously not all) types,
such as for example for all basic types and STL classes. Thus it could
avoid having to compile them each time.
  If you are using the same code with two different types you are obviously
going to get two different pieces of code, no matter how you do it.
Templates just make it easier to avoid code repetition. (In other words,
if you want, for example, a vector of ints and a vector of doubles, you
don't need to write the vector code twice.)
  Templated data containers in C++ usually produce more memory-efficient
code than equivalent data containers using the pointer-to-base-Object
mechanism, which usually wastes a lot of memory. Thus any argument that
templates cause memory bloat is usually false. (Yes, there may be a few
situations where templated code causes more memory usage, but normally
it's the opposite.)
  Syntax doesn't really matter all that much. It's how you use it.
Date: 10 May 2008 08:28:30
Message: <482594ee@news.povray.org>
> Yep.
Right. Well, the good thing about Turing-complete languages is that they
can do everything. The bad part is... they can do everything. SQL is so
damn efficient precisely *because* there are things it can't do.
Java's generics [if they anything like any other language] are nowhere
near Turing-complete, which makes them much easier to handle. [And
harder to misuse.]
http://blog.orphi.me.uk/
Date: 10 May 2008 13:44:53
Message: <4825df15$1@news.povray.org>
Yes. If you restrict templates to doing what generics do, you don't have
to compile them each time. But that's a restriction on templates.
Not in every language, no.  Depending on what you do with the types,
yes. That, for example, *is* one difference between generics and
templates. Obviously Java "generics" (such as they are) don't have this
restriction, because by the time you get to object code, all the actual
type information is gone.
In any case, what *I* meant was that you get a new blob of code compiled
every time you instantiate a template. Not for each different type, but
even for the same types in different compilation units. Yes? Or am I
confused about that?  If I have std:vector<MyType> having functions
called in one module, then I compile another module with
std:vector<MyType>, does the linker see that it's the same code and
function on the same type and only include one copy of the object code
in the linked result?
Right. Generics do the same thing. They're just more restricted than
what templates give you.
Unless everything's already a pointer-to-base-Object, as you already
decry. ;-)
> it's the opposite.)
I think they likely cause code file bloat. If you use the same template
and instantiate it on 10 different types of pointers, aren't you going
to get ten different copies of object code?
True. It's a pretty minor thing, once you get used to it. I just dislike
people taking the syntax into languages that don't need it. Right up
there with people who think a leading zero means octal is a good idea on
values rather than constants.
Date: 10 May 2008 14:19:55
Message: <4825e74a@news.povray.org>
  At least Java generics do not support basic types, so I don't really
understand what you are talking about.
  I suppose that no compiler so far uses this optimization, but I can
perfectly imagine it being absolutely possible: When a template class or
function is instantiated for a certain type, the compiler could compile
it into some type of object file. Next time that template is used with
the same type (be it in the same compilation process, by another compilation
unit, or in a future one) it can simply use that object file instead of
recompiling the template code. The mechanism to do this could be similar
and related to export templates (or if technical reasons mandate it, it
could only work with export templates).
  Currently yes, but as I said, it's perfectly conceivable that this
could be optimized by compilers.
  The linker always merges all template instantiations of a given type
into one (this is required by the C++ standard, AFAIK). In other words,
the final executable will have only one instance of those functions.
That's not the problem.
  (The only "problem" with template code is the increased compilation
time and object file sizes.)
  Except that they don't work with basic types, at least not in Java,
so they only solve part of the problem. :P
> > it's the opposite.)
  The amount of code "bloat" caused by templates is usually much smaller
than the extra amount of RAM required if templates were avoided. Usually
template functions are relatively small, like some hundreds of bytes at
most, while the data containers they are instantiating handle even
megabytes of memory at a time. With C++ templates the optimization is
in the right place: In the memory usage of the data containers, not the
machine code in the functions of that data container.
Date: 10 May 2008 14:32:03
Message: <op.uaya3o1d7bxctx@e6600.bredbandsbolaget.se>
Some compilers delay code generation of some templates until link time.
Even in the absence of delayed code generation, the linker merges
duplicates.
>> it's the opposite.)
Some linkers can recognise that the generated code is identical, and merge
all the copies.
FE
Date: 10 May 2008 15:14:06
Message: <4825f3fe@news.povray.org>
> all the copies.
  Not "some". All of them. They have to.
  That's because, AFAIK, as per the C++ standard, you have to be able to,
for example, create a function pointer to a given template function, and
if two pointers initialized in different compilation units point to the
same function, they have to compare equal. Another requisite is that if
there are static variables inside the function, they must all use the same
static variable.
