POV-Ray : Newsgroups : povray.off-topic : Error mesage Server Time
9 Jun 2026 01:05:56 EDT (-0400)
  Error mesage (Message 31 to 36 of 36)
Subject: Re: Error mesage
Date: 4 May 2008 03:40:29
Message: <481d686d@news.povray.org>
Darren New wrote:
> Warp wrote:
>> MyType value = something;
>> std::cout << "The value is: " << value << "\n";
> Here's something I've been wondering about that. Say you have your own
> type, and you want a set of flags like hex/oct/decimal or setfill or
> something like that. I.e., you want to be able to say
> std::cout << prettyprintindent(4) << myvalue << "\n";
> Where does the "4" there get stored? And how can you make it so that
> (say) passing -1 puts back what it was before the previous call for the
> same stream? It would seem that you'd need some sort of data structure
> mapping streams to pretty print indent levels, yes? And no automated way
> of cleaning that up with a destructor?
> What am I missing here?
I believe you would create a separate class which inherits from OStream,
and give it a data member to store the 4 in.  You would then define the
function prettyprintindent(int) to return your subclass.  Since it
inherits, it can still be used like a regular OStream.
...Chambers
Date: 4 May 2008 07:30:56
Message: <op.uamnltkn7bxctx@e6600.bredbandsbolaget.se>
Did you not ask this once before?
http://groups.google.com/group/comp.lang.c++.moderated/search?q=custom
+stream+manipulator
Also, look up 'ios::xalloc'.
> And how can you make it so that (say) passing -1 puts back what it was
> before the previous call for the same stream?
http://www.boost.org/doc/libs/1_35_0/libs/io/doc/ios_state.html#user_sav
ers
Perhaps not exactly what you meant, but doing it this way avoids resourc
e
management issues.
> It would seem that you'd need some sort of data structure mapping stre
ams
> to pretty print indent levels, yes? And no automated way of cleaning t
hat
If you impose a fixed (and relatively small) limit on the history size,
you could store all the relevant information in the stream itself. For
automatic cleanup of arbitrary amounts of per-stream data, I think you
might need to use custom streams.
FE
Date: 4 May 2008 17:36:37
Message: <481e2c65$1@news.povray.org>
Which means you now have two instances pointing to the same stream?
std:cout << pretty(4) << myvalue;
std:cout << myvalue; // No longer pretty(4)?
yadda = (std:cout << pretty(4));
yadda << mine << yours;
// Now what do I do to clean up?
std:cout << pretty(4) << myprettyvalue << magic(15) << mymagicvalue;
// Looks like magic(15) has to understand "pretty" streams?
// Or even
   << pretty(8) << myprettyvalue;
How many copies of the "pretty" value are going to be in the
thing returned by the final << operator?
Yeah, but not I understand other things a bit better, so I'm trying to
figure this one out again.  Those links you gave really don't answer the
question, as they seem to be answering too-simple questions.
Ah, I begin to see. ios can allocate a word in each stream specific to
your class.
Ok. It looks like it only works for one integer from one user-defined
type at a time, and if you cast it to a pointer, it still doesn't get
cleaned up when the stream goes out of scope, because there's no type
information. Or am I misunderstanding that? If you allocate (say) a
buffer or something for the stream, at what point does that buffer get
cleaned up?
So it looks like the answer is either "you can't do this with standard
streams" or "for very limited cases it's built into the stream class
already".
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 4 May 2008 18:52:31
Message: <op.uani5upf7bxctx@e6600>
> type at a time,
The words allocated with 'ios::xalloc' are not related to any user-defined
types. They have only whatever meaning you choose to give them.
> and if you cast it to a pointer, it still doesn't get cleaned up when
Correct. The stream object itself neither knows nor cares what you store
there.
> If you allocate (say) a buffer or something for the stream, at what
> point does that buffer get cleaned up?
If you mean "automatically" then not at all.
> already".
Depending on your definition of "very limited", yes.
FE
Date: 4 May 2008 19:10:47
Message: <481e4277@news.povray.org>
> user-defined types. They have only whatever meaning you choose to give
> them.
Right, OK.
> there.
Yeah. I'd just been thinking about Warp's example earlier that needed
"weak" references to actually not "leak" resources. I was trying to
figure out how C++ handled it, if at all.
OK.
By "limited" I mean "for anything other than an integer, like say an
instance of a user-defined class." :-)
Thanks for the clarification!
Date: 5 May 2008 04:41:57
Message: <481ec855@news.povray.org>
  Stream manipulation flags are one thing which is shamefully bad designed
in C++, and I really don't understand what they were thinking of.
  A few flags are set only until the next output action which is affected
by that flag (after which it's automatically reset). However, the rest are
permanently set until they are explicitly reset. This means that these
flags can "leak". For example this may well happen:
std::cout << 10 << std::endl;
foo();
  If foo() calls, for example, std::hex(std::cout), then what is printed is:
10
a
  foo() could alleviate this problem by storing the flags into a variable
at the beginning and then restoring those flogs when it ends, but as we
all know, functions can have surprising exit points. (It's still possible
to make sure that the flags are restored at any exit point by using the
destructor mechanism of C++, but it becomes a bit more laborious. I'm
actually surprised the standard library doesn't offer an class type for
this exact purpose...)
