POV-Ray : Newsgroups : povray.off-topic : Error mesage Server Time
8 Jun 2026 23:29:09 EDT (-0400)
  Error mesage (Message 17 to 26 of 36)
Subject: Re: Error mesage
Date: 2 May 2008 04:52:20
Message: <481ad644@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> I presume this doesn't work on a protected-mode OS?
  Well, the program has some memory allocated for itself, so if the pointer
happens to point to such memory, it will print gibberish. If it points to
unallocated memory you get a segmentation fault.
  The C++ version of printing to stdout (or to a stream) is much safer
from this point of view. (While you *can* make it behave the same way,
it's much harder to do so accidentally.)
Date: 2 May 2008 05:10:54
Message: <481ada9e$1@news.povray.org>
Right. Thought so...
I don't really know C++, but from what little I've seen printing *looks*
safer...
OOC, how does C do argument passing? [I'm puzzled as to why it's
possible for a function with variable arguments to exist.]
http://blog.orphi.me.uk/
Date: 2 May 2008 05:42:39
Message: <481ae20e@news.povray.org>
> safer...
  It's more modular too. For example, assume you have abstracted away
a type like this:
typedef int MyType;
  And somewhere else in the code you have something like:
MyType value = something;
printf("The value is: %i\n", value);
  That 'printf' assumes the type is an integer. What happens if you later
change the type? For example like:
typedef double MyType;
  What happens is that the printf breaks horribly and will print gibberish.
  That won't happen using the C++ style:
std::cout << "The value is: " << value << "\n";
  Now if the value type changes the output will still be correct.
  The C standard (and consequently the C++ standard) defines a special
mechanism for passing a variable amount of arguments to a function.
Simply put, you can declare a function like:
void foo(...);
and then you can call it like:
foo(any, amount, of, arguments, you, want);
  Of course C being C, there's no way for the function to know how many
arguments were passed and what was their type. printf() solves this with
the format string given as first parameter. (And its problem is, of course,
that it simply trusts that the amount and type of the arguments corresponds
to the given format string.)
  The C standard defines special macros which can be used inside foo() to
retrieve the given arguments.
  From the compiler's point of view the implementation of this is rather
simple: All the function parameters are pushed onto the stack, and then
the foo() function simply pops them from the stack. But as I said, there's
no type checking nor anything. It's all just "raw". (But it's not like
there wouldn't be *any* advantage at all in this: The advantage is, of
course, that it's quite fast and memory-efficient to do it this way.)
Date: 2 May 2008 11:28:04
Message: <481b3304$1@news.povray.org>
On Fri, 02 May 2008 09:02:45 +0100, Invisible wrote:
> Jim Henderson wrote:
>> I still prefer the one I got from Windows + a biometric scanner (during
>> GINA login):  "An error occurred:  The operation was successful".  Oh,
>> and it wouldn't log me in (I wish I could've gotten a screenshot)
> Well *clearly* a Windows operation being successful would indicate an
> error; Windows operations are designed to _fail_. ;-)
That was my thinking; the MS consultants who were there were absolutely
beside themselves trying to figure out what was going on.
Jim
Date: 2 May 2008 12:52:34
Message: <481b46d2$1@news.povray.org>
Well, technically, the foo() function indexes into the stack (with a
compiler-provided macro to move the stack pointer into a pointer
variable, basically), and then whoever called foo() has to pop the
arguments. Which is one reason you don't see many "ret N" instructions
in compiled C code - the callee never knows how many arguments the
caller pushed.  (Altho you'd think that's something the compiler could
optimize if you didn't have a variable numbers of arguments for a
particular function.)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 2 May 2008 12:54:00
Message: <481b4728@news.povray.org>
FWIW, that usually happens when a function returns an error indication
but doesn't set the secondary information that says what error it was.
Or, in C terminology, the function returned -1 but didn't assign
anything to errno.   Yet one more reason to dislike C. :-)
Date: 2 May 2008 13:59:49
Message: <481b5695@news.povray.org>
Oh, yes, I do know that side of the coding - but that didn't make it any
less funny, especially to see the MS consultants (and I'm not saying
"Consultants who consult on Microsoft technologies", but "Microsoft
Consulting") try to figure that one out. :-)
Jim
Date: 2 May 2008 14:22:33
Message: <481b5be9@news.povray.org>
"Jim Henderson" <nos### [at] nospamcom> wrote in message
news:481b5695@news.povray.org...
> (and I'm not saying
> Consulting")
I've worked with some guys from MCS before. Some are really good. Others are
.... not so good. (to put it politely)
Date: 2 May 2008 15:16:57
Message: <481B68D0.6070603@hotmail.com>
>> (during GINA login):  "An error occurred:  The operation was
>> successful".  Oh, and it wouldn't log me in (I wish I could've gotten
>> a screenshot)
My interpretation was that because an error occurred the process could
not validated your login, hence it should not log you in and indeed it
was successful at not letting you in. In my opinion it is thus a
correct, though slightly confusing, message.
Date: 2 May 2008 16:02:51
Message: <481b736b$1@news.povray.org>
>> (and I'm not saying
>> Consulting")
> are .... not so good. (to put it politely)
The guys I worked with were pretty good - and they did appreciate the
humour of the situation. :-)
Jim
