POV-Ray : Newsgroups : povray.off-topic : Another stupid SQL query problem Server Time
16 May 2026 20:37:22 EDT (-0400)
  Another stupid SQL query problem (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Another stupid SQL query problem
Date: 21 Apr 2008 17:04:05
Message: <480d0145$1@news.povray.org>
The script name will not be a variable. But the email could come from
different IPs at different times. They want to have counts for the number of
times individuals used the getthere.asp script.
We are using MS SQL Server (2000 in this case)
Thanks again.
s
"Gail Shaw" <initialsurname@sentech sa dot com> wrote in message
news:480cfff3@news.povray.org...
> "Halbert" <hal### [at] gmailcom> wrote in message
> news:480cfb5d$1@news.povray.org...
>> If we have any SQL gurus out there (not mentioning any names, Gail :-)
> Hmmm, am I hearing things?
>> I
>> have a simple problem I with undoubtedly a simple answer.
>> I have a log table:
>> Log_time | IP | Script_Name| Email | DK
> Ok. Think I understand. It's a little complex, but not really difficult.
> Do need some things clarifying.
> Say you have 3 rows with the same Email, different IP, different Log time
> and different script. (is that possible?)
> What log time, IP, script do you want returning? The ones that match the
> latest log-time? Oldest log time? Any one, doesn't matter?
> Oh, what DB engine? Oracle, My SQL, SQL Server, other? What version?
> If no one's helped by morning, I'll take a look, but it's 11pm here...
Date: 21 Apr 2008 17:10:09
Message: <480d02b1@news.povray.org>
news:480d0145$1@news.povray.org...
of
> Thanks again.
Ok, so say this is the input (as a comma-seperated list). What do you want
as results?
Logtime, IP, Email
2008/01/01 10:15, 10.2.45.56, me@here
2008/01/01 10:25, 10.2.45.56, me@here
2008/01/01 16:15, 10.2.78.156, me@here
2008/01/02 12:15, 10.2.15.74, me@here
2008/01/02 12:17, 10.2.15.74, me@here
2008/01/02 12:19, 10.2.15.74, me@here
2008/01/01 12:15, 10.5.25.34, you@somewhere
2008/01/01 13:15, 10.5.25.34, you@somewhere
2008/01/01 14:15, 10.5.25.34, you@somewhere
2008/01/01 18:15, 10.5.25.38, you@somewhere
Date: 21 Apr 2008 17:18:35
Message: <480d04ab$1@news.povray.org>
> Logtime, IP, Email
me@here,7
you@somewhere,4
Date: 21 Apr 2008 17:30:19
Message: <480d076b$1@news.povray.org>
Halbert wrote:
>> Logtime, IP, Email
> me@here,7
> you@somewhere,4
That's easy, then.
select email, count(*) from logtable where '2008-...' < logtime and
logtime < '2008...' group by email
The "group by" (and possibly "with rollup" and "having" clauses) is what
you need to read up on.
If you need one of the IP addresses or other columns to come back, it's
harder.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 21 Apr 2008 17:34:51
Message: <480d087b$1@news.povray.org>
> That's easy, then.
> harder.
In reality, I need to select based on DK (a company identifier,)the script
name and the date range but I think that it would be sufficient to return
with only the email and the count.
Date: 21 Apr 2008 20:03:05
Message: <480d2b39$1@news.povray.org>
Halbert wrote:
>> That's easy, then.
>> harder.
The "group by" lets you select on anything. (I.e., the "where" clause
can refer to any column, including joins with other tables etc.)  But
everything you *return* has to either be mentioned in the "group by"
clause or has to be a summary function (like count(), sum(), avg(),
etc).  (I forget what those kinds of functions are called in SQL, but...)
Date: 22 Apr 2008 00:38:41
Message: <480d6bd1@news.povray.org>
news:480d087b$1@news.povray.org...
> > That's easy, then.
> > harder.
Still very simple.
SELECT Email, Count(*)
FROM uselog
WHERE
Log_time >  '2008-01-31' and Log_time < '2008-03-01' and Script_Name =
'/EN/travelsync/content/getthere.asp' and DK = 'TEST'
group by Email
Date: 22 Apr 2008 00:39:07
Message: <480d6beb@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:480d2b39$1@news.povray.org...
Aggregate.
Date: 22 Apr 2008 10:19:29
Message: <480df3f1$1@news.povray.org>
I knew it was simple and yet I couldn't seem to come up with it. Anyway that
worked splendedly. Thank you once again.
Date: 22 Apr 2008 11:11:59
Message: <480e003f@news.povray.org>
news:480df3f1$1@news.povray.org...
that
Thank Darren. He wrote the query.
