POV-Ray : Newsgroups : povray.off-topic : Speed comparison between C# and C++ Server Time
16 May 2026 20:50:33 EDT (-0400)
  Speed comparison between C# and C++ (Message 11 to 20 of 20)
Subject: Re: Speed comparison between C# and C++
Date: 17 Apr 2008 13:39:38
Message: <48078b5a@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Warp wrote:
> >   It's certainly not a good idea to create, resize and destroy 6 vectors
> > at each iteration.
> And in a well-tuned GC system, that's less of a problem, see? :-)
  You and your obsession. It has nothing to do with GC. I has to do with
memory allocation strategies and optimization. There's nothing inherently
inefficient in non-GC'd allocation nor anything inherently efficient in
GC'd allocation. We are talking about *allocation* here, not deallocation.
There's basically no difference between GC'd and non-GC'd allocation.
  A non-GC'd regular C++ allocator can be made extremely fast (there are
many practical demonstrations of this). For some reason, however, most
compilers prefer the space-optimal allocation scheme to the speed-optimal
one.
Date: 17 Apr 2008 13:46:42
Message: <48078d02@news.povray.org>
> Somebody uses a C++ feature inefficiently, and that proves GC is better??
  In many (or most) GC'd languages (such as Java) memory allocation
(iow. 'new') is demonstrably faster than in most C++ implementations.
This is not a problem in C++ or an advantage of GC in particular, but
a question of how the allocator used by the compiler works. For some
reason memory allocation speed is not something which has been optimized
to death in C(++) compilers, for whatever reasons (even though most other
things have been). It's not a problem with the language itself, but a
problem with compilers (or, to be more precise, their libraries).
  For some reason Darren wants to think that the faster speed of memory
allocation in most GC'd languages is *because* of GC in particular (as if
those speeds were not possible in non-GC'd languages). This is demonstrably
not true. There's nothing in GC in particular which would make allocation
faster. It's just that GC engines have been more optimized for allocation
than most C(++) memory allocators.
  I have to admit this is a shame to C and C++. OTOH, it cannot be blamed
on the languages, but on the compilers and their libraries.
Date: 17 Apr 2008 14:15:00
Message: <web.4807928632efdb9f261d9700@news.povray.org>
Anyway, the C++ version was a port of the C# version... when I get home tonight,
I'm going to write the physics stuff from scratch in C++, and see what effect
that has.
For one thing, I found that I had to design the classes differently in C# than I
would have normally.  There's probably something in there that's hurting
performance.
.....Ben Chambers
www.pacificwebguy.com
Date: 17 Apr 2008 14:29:53
Message: <48079721@news.povray.org>
Maybe because allocating memory is a "rare" operation in C / C++ so
there's not as much need to optimise it?
(Certainly in a language like Java, if you *don't* optimise the
allocation of memory, the thing will crawl...)
http://blog.orphi.me.uk/
Date: 17 Apr 2008 20:37:44
Message: <4807ed58$1@news.povray.org>
I'm suspecting it's because C and C++ use pointers rather than
references, and can't carry around enough metadata (generally speaking)
to allow finding the pointers in a data structure, so they can't compact
memory. That means that finding free memory is generally a search.
> faster.
Generally, yeah, there is. Allocation of a structure in a compacting GC
implementation is almost always as fast as allocating something on the
stack in C++. When it isn't, it's because you have to run a compacting
GC cycle first.
That's what I said.
I'm not sure that's 100% true.  Often, taking a big program with a
hand-crafted allocator just for that program, and replacing it with a
GC'ed memory allocator, will actually run faster.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 17 Apr 2008 20:39:00
Message: <4807eda4$1@news.povray.org>
This is incorrect. A GC allocation is adding the size of a structure to
the pointer, just like allocating something on the stack is. If you
can't move stuff around after it's allocated, it becomes extremely hard
to beat this speed.
Date: 17 Apr 2008 20:52:02
Message: <4807f0b2$1@news.povray.org>
Well, you can't move objects around in memory to compact, that is true.
However, nothing stops a memory allocator from keeping lots of metadata
internally to find free memory quickly.
How do filesystems know what empty blocks are available to save a new
file? A linear search from the beginning of the disk?
Date: 17 Apr 2008 21:27:02
Message: <4807f8e6$1@news.povray.org>
Sure. If you're always willing to (for example) allocate powers of two
for memory, and you keep a free list for each power of two, then you can
allocate and free pretty quickly. The problem is this wastes even more
space than a compacting GC does, and you still have to do some
management to coalesce adjacent free blocks eventually.
It's a lot easier when you can fragment your allocations. If all your
allocations are one page in size, yah, it's also pretty easy to go fast. :-)
Put it this way: there's nothing a "manual" non-compacting allocation
could do to make allocation faster than you could with a compacting GC
scheme, or the compacting GC scheme could just use that technique to
allocate stuff, then do a GC if it ran out of memory.
But don't argue with *me*.  Go look up the research papers on the
efficiency of manual and automatic memory management. I already posted a
list once.
The most interesting recent one I found points out that if you take
typical Java programs, find objects that are allocated but their
pointers never get passed outside the immediate scope and add bytecodes
to "manually" free them, it goes even faster and uses even less memory.
So, basically, if you detect that you *could* stack-allocate it, and
then do, you get the best of both worlds, with very few "I could have
stack allocated it but didn't" situations.
Date: 18 Apr 2008 02:43:55
Message: <4808432b@news.povray.org>
scott wrote:
> But what is the CPU % when your frame rate first drops to 30 from 60?
> 380   30  25
> 480   10  40
> 515    3  48
> 520    1  50
0   0% 60fps
100 1% 60fps
200 3% 60fps
300 5% 60fps
400 25% 32fps
500 33% 21fps
550 43% 9fps
Doh!  Sitting down to do real timings helps :)
OK, I'll work on the graphics code next.
...Ben Chambers
Date: 13 May 2008 15:43:09
Message: <4829ef4d$1@news.povray.org>
> to beat this speed.
Or, to phrase it a different way that might make it more clear...
How fast can you make your malloc() implementation if you know that
nobody will ever call free()?  Pretty straightforward, given sbrk(), yes?
