POV-Ray : Newsgroups : povray.off-topic : Now what am I going to store on this? Server Time
16 May 2026 23:06:48 EDT (-0400)
  Now what am I going to store on this? (Message 21 to 30 of 61)
Subject: Re: Now what am I going to store on this?
Date: 17 Apr 2008 05:35:26
Message: <480719de$1@news.povray.org>
scott wrote:
>>> Not compared to modern RAM circuits. I think transistors are getting
>>> down to the dozens-of-atoms size at this point.
>> I doubt it.
> What do you doubt, that silicon atoms are as big as 0.25 nm across, or
> transistors are as small as 25 nm?
If you made a transistor that consisted of only a few atoms, it wouldn't
work properly.
The concept of "electricity" is a simplification of the aggregate
behaviour of individual charged particles. Like other concepts such as
"temparature" and "pressure", it only makes sense at "large" scales.
If you were to make a device so small that it consists of only a few
dozen atoms, you couldn't be able to reason about it using the usual
laws of electricity. You'd have to use quantum dynamics or something.
(Let's face it, semiconductors work by having lots of silicon atoms with
impurities of other atoms scattered around. Well if your transistor is
only, say, 20 atoms in size, then they'd *all* be ordinary silicon
atoms, and it wouldn't be a semiconductor. But that terms such as
"conductor" make sense at these scales...)
Now there may or may not be a way of making some kind of switching
device out of a few dozen atoms, but you can't make a "transistor" (as
in, a sandwich of N-type and P-type semiconductive matter) with that few
atoms. It wouldn't work properly.
http://blog.orphi.me.uk/
Date: 17 Apr 2008 07:12:03
Message: <48073083$1@news.povray.org>
>>> I doubt it.
> work properly.
Probably not, but nobody suggested that.
Darren said that the *size* was comparable to some dozens of atoms.  A 25 nm
transistor is only 8 dozen atoms across, but (if you assume it's a cube) it
consists of almost a million atoms.
Clearly that's enough to still work ok, but you're right, the limit for
traditional transistors can't be much further away.
Date: 17 Apr 2008 07:26:09
Message: <480733d1$1@news.povray.org>
>>>>> getting down to the dozens-of-atoms size at this point.
>>>> I doubt it.
>>> or transistors are as small as 25 nm?
> 25 nm transistor is only 8 dozen atoms across, but (if you assume it's a
> cube) it consists of almost a million atoms.
Right. So when you say "size", I thought you meant volume, but you
actually meant diammeter?
Anyway, regardless, the advantage of the algae is that it's packed in 3D
instead of mere 2D, massively increasing the amount you can fit into a
given space.
Either way, you would *think* neuron cells would be the "obvious" choice
for making RAM circuits. They already have the ability to wire
themselves up for you, so...
Date: 17 Apr 2008 08:06:18
Message: <g7fe04ttj8sevl9nlvpcie6588hnncts90@4ax.com>
Then you would have RRAM. The stuff of Frankenstein movies :)
Regards
Date: 17 Apr 2008 10:55:34
Message: <480764e6$2@news.povray.org>
Tim Cook wrote:
> Chambers wrote:
>> No, it means we'll finally be able to store our audio files with
>> decent quality settings.  No more "Vinyl sounds better," guys!
> Been able to store audio files with decent quality settings for a while.
>  Ape, FLAC, et cetera.  The reason the "vinyl sounds better" guys make
> that claim is, apparently, due to the digitizing process itself that
> makes the *original* recording unacceptable to the audiophile's
> oh-so-sensitive ear.
Oh, the vagaries of the Internet, where sarcasm is lost :(
...Ben Chambers
www.pacificwebguy.com
Date: 17 Apr 2008 10:58:56
Message: <480765b0@news.povray.org>
Not for storage.  They work best as pattern filters.
(Just try comparing your brain's ability to recognize pictures to its
ability to remember minute trivia).
...Ben Chambers
Date: 17 Apr 2008 11:56:30
Message: <4807732e@news.povray.org>
>> choice for making RAM circuits. They already have the ability to wire
There are people who have successfully memorised Pi to thousands of
decimal places, routinely memorise decks of cards, etc.
The default way the *human* brain is wired up is optimised for tasks
such as shape recognition, which are critical to survival, and poorly
optimised for memorising digit sequences [which, for many millions of
years, was *not* an important task].
That doesn't mean that you couldn't wire up neurons in such a way that
they reliably store arbitrary data.
Here's a thought: When you turn RAM off, all the data gets lost. When
you "turn off" a biological storage system... all the cells die? Ouch!
UPS for the win! ;-)
Date: 17 Apr 2008 12:30:21
Message: <48077b1d@news.povray.org>
And you think that people building modern semiconductor wafers aren't
using quantum dynamics to design them?  I mean, you need QED to even
make *any* semiconductor work.
Technically, it would still be a semiconductor. Just not a very useful
one, because it would be 100% semiconductor.
I believe the junction between base and emitter in a CMOS transistor is
all one type of semiconductor (all P or all N) for what it's worth. :-)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 17 Apr 2008 12:34:15
Message: <48077c07$1@news.povray.org>
Invisible wrote:
> I doubt it. At that scale, quantum effects would become significant,
Well, yes. That indeed is the problem people are having. Quantum effects
are knocking electrons out of the gate and into the substrate, or
they're tunneling across the restriction zones even when it's switched
off.  (Likely what I'm remembering is transistors where the active part
that serves as a barrier is in the dozens-of-atoms size.)
> Also, significantly, transistors don't just grow themselves if you feed
> them a little nitrogen and AMP. ;-)
There is that, yes.  :-)
I don't really need to have bigger drives. I just need faster drives. :-)
Date: 17 Apr 2008 13:20:08
Message: <480786c8$1@news.povray.org>
Ah. Now *that* is a problem that biological devices are most unlikely to
solve. Current hardware runs way faster than anything biological anyway...
Of course, the "other" way to do this is to have a really ****ing wide
bus, which should be tractable for a biological system.
