POV-Ray : Newsgroups : povray.off-topic : Programming design question, related to GC Server Time
9 Jun 2026 03:31:56 EDT (-0400)
  Programming design question, related to GC (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Programming design question, related to GC
Date: 11 Apr 2008 23:37:06
Message: <48002e62@news.povray.org>
>>   If this is so, then what we have is a memory leak. In a GC'd system.
> It's definitely a problem. Some would argue that it's not technically a
> memory leak, but rather a failure to disconnect the Listener from the
> Engine. It's easier to diagnose (if it's deterministic, at least),
> because you see the Engine's list growing indefinitely. You don't lose
> memory and not know what's in it.
It would be a leak if the Engine kept *strong* references to the
Listeners. Then the Listeners would never get GC'd.
Date: 12 Apr 2008 05:33:00
Message: <480081cc@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> You can, of course. You're just reference counting whether the Listener
> is "alive" rather than whether the memory is still allocated.
> Do all the same stuff, but maintain the reference counter yourself.
> (This can, of course, be difficult, if your language doesn't support
> automatically doing something when a pointer to an object leaves its scope.)
  Can you mention some popular GC's languages where it's possible to
implement reference-counting of objects? AFAIK in Java it's not possible
(because there's no way for the object to detect if a reference to it
is copied or destroyed).
Date: 12 Apr 2008 14:30:50
Message: <4800ffda$1@news.povray.org>
Hmmm. Well, of course you can implement the reference counting
everywhere you assign or overwrite or dispose of a pointer of that type,
but that's not what you mean. I can't think of any languages offhand
that specify reference counting is built in but also allow you to do
actions when pointers enter and leave scope, like you can in C++.
Maybe Objective-C? That's the only "popular" one I know of but don't
know well enough to answer the question.
Of course, if you make a mistake anywhere in the reference counting
doing this, you're going to have a memory leak just like any other
manual memory management.
Weak references are the solution to this sort of thing, which also
brings the benefit of being able to add the listener to more than one
engine, for example. I don't think it's possible to reasonably implement
weak references with a library without compiler support, at least in
most GCed languages (which don't give you access to the internal data
they use to do the GC).
Now, COP (concurrency-oriented programming) is a bit different. In
languages where your objects tend to be "active", i.e., not only have
code but have a stack and a program counter, the connections between
objects are often tracable - you can tell when another process has
connected to you, and when it has disconnected, and how many are
connected. Some languages can, some can't, depending on whether they
implement the connections as connections between processes or
connections between ports/mailboxes.
But no, C++ is definitely more powerful in this respect. It would be
nice to see a language that would invoke a finalize method any time it
can statically deduce that some object is going to disappear at some
particular point, or to let you mark some particular class as
reference-counted, so as long as you don't get into circular references,
it can get collected deterministically (and trigger finalizers).
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 12 Apr 2008 14:45:24
Message: <48010344$1@news.povray.org>
Correction:
... that specify GC is built in ...
Regardless of GC mechanism, I don't know any langauge that automates the
GC and also lets you track individual objects, in an OO language. Come
of the concurrent languages do, but that's more for "has the person I'm
talking to crashed out or lost their ISP connection" more than for this
sort of task.
Date: 12 Apr 2008 15:44:08
Message: <48011107@news.povray.org>
> As pointed out, this is part of what "weak references" were created for.
> If a GC runs and the only pointers to an object are "weak", then all the
> "weak" pointers get set to null, and your Engine can notice that and not
> try to use that pointer any more.
  If the GC runs in parallel in its own thread, wouldn't there be a mutual
exclusion problem (even in 1-core processors)?
  Let's assume the Engine object does this:
if(listeners[i] != null)
  listeners[i].doSomething();
  If the GC happens to make a sweep after the conditional but before
the call, and it sets the weak reference at listeners[i] to null, we'll
get a null pointer exception (which may seem crazy because we just
checked that it's not null).
  Or are GC engines run only at places where there can't be mutual
exclusion problems? (How does the VM/compiler/interpreter know that?)
Date: 12 Apr 2008 18:25:31
Message: <480136db@news.povray.org>
Yes, except that's always possible in a multi-threaded system, if
another thread sets the listeners[i] to null. :-)
Generally speaking, you can't invoke a weak reference like that. Most
systems get around the problem by having a function (which has to be
built-in, you can't implement it yourself) that takes a weak reference
and returns either null or a strong reference; *that* really is the
point where the weak reference gets cleaned up after the object is gone.
  I.e., weak references are simply pointers into some system-maintained
table, not actual pointers to the objects themselves.
So the code would be
thisListener = weak_to_strong(listeners[i]);
if (thisListener != null) listeners[i].doSomething();
else listeners[i] = null;
You'd still have the weak reference. If the call to doSomething()
cleared out the last intentional reference to that listener (the "this"
in the call), then when you returned from the doSomething and
"thisListener" went out of scope, then you'd wind up getting it
collected. But you'd have to return from doSomething before that
newly-created strong reference disappeared.
When the GC actually doesn't stop all threads, it uses funky tricks like
making memory pages non-writable or non-readable and catching hardware
exceptions to avoid having problems with interactions like that. Like,
if the GC scans an object X for outgoing pointers, it marks it as
read-only until it's done. Then you store a new pointer in that object
from another thread, the GC catches the write, sees what new object Y
you might be pointing to, and makes sure that if that
newly-pointed-to-object had already been marked free (because you had
not been pointing to it before but now X points to it), Y is now marked
"in use" again.
But weak references generally have to be turned into strong references
to use them. At least everywhere I've seen such implemented.
Date: 12 Apr 2008 18:59:00
Message: <48013eb3@news.povray.org>
  In theory it could happen that each time the GC takes a sweep,
that second line is being executed. (Yes, extremely unlikely for
that to happen each time, but theoretically possible.) Since that
second line is using a strong reference, the object is not destroyed?
  Also, I assume that the weak_to_strong() function must be locking
(ie. have mutual exclusion). Doesn't that make it slower than just
using a strong reference?
Date: 12 Apr 2008 19:28:09
Message: <48014589$1@news.povray.org>
Correct.  Once the weak_to_strong creates the strong reference, it can
no longer be GCed, since there's still a strong reference around.
Sure. If nothing else, you need the overhead of calling
weak_to_strong(). You don't want to use weak references if you don't
need them.
But generally, if your GC is letting your code run while the GC is
running, you're going to have various kinds of locking overhead. Often,
instead, you'll have the program stopped briefly while a little bit of
objects is marked either "free" or "in use", then more application code,
then a little bit of scanning, etc, until you've finished a full scan.
Then you throw things away, a little at a time, also.
But generally, if you have threads, you GC one thread at a time, so the
thread you're GCing isn't mutating memory as you're collecting it.
Remember, too, that you're looking for live objects, not dead ones, so
if an object goes from live to dead while you're scanning, you're OK -
you'll get it the next time around. The complexity comes from objects
going from dead to live while you're scanning.
It's not just the weak-to-strong that needs locks. If you compact memory
to make larger free spaces, you obviously need to make sure nobody is in
the middle of referencing what you're moving and so on either. Even
reference counting stuff has to have locks, except now you need locks
for every time you assign a pointer, instead of just during garbage
collection.
It's actually pretty darn complicated to get right. And it has been an
ongoing field of research for 30 years already, and there's still no
solution that makes everybody happy, so...
Date: 12 Apr 2008 19:29:27
Message: <480145d7$1@news.povray.org>
http://www.cs.purdue.edu/homes/jv/pubs/lctes07.pdf
If you want some ugly nitty-gritties. :-)
Date: 14 May 2008 18:35:35
Message: <482b6937$1@news.povray.org>
Actually, thinking about this, it's really not possible the way you mean
it. How would you say which object's reference count went to zero? As
soon as you say "Remember that open file? Its reference count went to
zero," the reference count isn't zero any more. Which is why finalizers
always have problems with being "resurrected" during finalization.
So, I guess it's impossible to implement weak references yourself in the
same language as you access the references (i.e., as a library). If you
can return the strong reference from your library, the weak reference
can't be collected. Cool.
