POV-Ray : Newsgroups : povray.off-topic : A question about OOXML Server Time
16 May 2026 21:46:23 EDT (-0400)
  A question about OOXML (Message 32 to 41 of 41)
Subject: Re: A question about OOXML
Date: 7 Apr 2008 16:55:34
Message: <47fa8a46@news.povray.org>
Tim Attwood wrote:
> If app A doesn't implement parts of the standard they don't use,
> and app B doesn't implement parts they don't use,
> then chances are you will have incompatible files between app A and B.
Then why is everyone using XML?
Answer: because it's easy to ignore the parts you don't use.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 7 Apr 2008 17:39:36
Message: <47fa9498$1@news.povray.org>
Hype? :)
Date: 7 Apr 2008 23:27:21
Message: <47fae619@news.povray.org>
> Why should the file saved by Word not be readable by A or B?  A and B will
> just ignore the parts they don't need.
Because you are choosing a situation that fits a best case for
the standard. Let us say that A and B are both word processors,
to the end user of A it makes sense to load up a document that
has the same extention as documents produced by A, even if
they came from B. Now lets say that A uses VML and B
uses DrawingML, the document from B probably will not
look right in A, even though both programs will claim to be
ISO compliant (but are only partially). At the same time MS
will be able to load documents from A and B and save them
using special MS markup that neither A or B understand.
Date: 8 Apr 2008 02:24:05
Message: <47fb0f85$1@news.povray.org>
>> will just ignore the parts they don't need.
Well sure, but that's just how standards work.  If program A or B only
partially implement the standard then you cannot expect them to open every
possible file and show it correctly.  And we don't expect people to
implement every single part of the standard, because then you're rewriting
Word!
If your application A only uses VML, then I would expect the developer to
include some converter to put images into VML format.  Otherwise he must
expect a lot of people to get annoyed because he hasn't implemented the
other common image types.
> At the same time MS
Well fine, but it ceases to be an ISO OOXML file then if any program puts in
stuff that is not in the spec.
Date: 8 Apr 2008 05:50:16
Message: <47fb3fd8$1@news.povray.org>
> in stuff that is not in the spec.
Isn't that why people don't like the new standard?
MS put their custom tags into the ISO standard so they can
avoid rewriting Word to be ISO compliant. It's easier for
MS just to change the standard. A and B now need to re-implement
Word just to be ISO compliant, the standard is useless in this
regard. It doesn't specify a single "best practice" it gloms
together bits of dissimilar methods into a single standard.
It's a wart on a wart on a wart, and warts are ugly.
Date: 8 Apr 2008 06:02:57
Message: <47fb42d1@news.povray.org>
Well there's a surpise, you invent a new standard to define Word documents
in an open way, then you complain that to read them completely you need to
re-implement Word!
As far as I can see, it simply allows other programs to read and create
files that are compatible with Word very easily.  I don't think anyone is
going to attempt to implement every single feature of the real Word.  And I
guess the reasons that governments want it is so that if MS suddenly decides
to do something stupid (very unlikely) then other programs will be available
to easily get the data.
Date: 8 Apr 2008 13:39:40
Message: <47fbaddc$1@news.povray.org>
> documents in an open way, then you complain that to read them completely
> you need to re-implement Word!
And if MS didn't do this, then people would complain when they use the
advanced features of Word that they paid for because they need, and then
they can't open the file again after they saved it.
> And I guess the reasons that governments want it is so that if MS
> suddenly decides to do something stupid (very unlikely) then other
> programs will be available to easily get the data.
It'll also be helpful to avoid the whole "what secret stuff is MS
leaking into my documents" kind of MS-added-an-NSA-cryptokey complaint.
Date: 8 Apr 2008 15:58:14
Message: <47fbce56$1@news.povray.org>
That's assuming MS is not going to add plenty of non-standard tags in
their own implementation...
What will you think of a big binary blob between tags bearing the very
explicit name <newUndocumentedTag3425543>  :-) ?
Vincent
Date: 8 Apr 2008 21:16:08
Message: <47fc18d8$1@news.povray.org>
I think it'll probably be unnecessary for you to parse it in order to
(a) follow the standard and (b) get reasonable results.
Why, what do *you* think would happen?
Date: 9 Apr 2008 03:16:47
Message: <47fc6d5f$1@news.povray.org>
Try deleting out that section and see what happens?
