POV-Ray : Newsgroups : povray.off-topic : A question about OOXML Server Time
16 May 2026 23:06:56 EDT (-0400)
  A question about OOXML (Message 22 to 31 of 41)
Subject: Re: A question about OOXML
Date: 5 Apr 2008 15:14:05
Message: <47f7dd8d$1@news.povray.org>
Orchid XP v8 wrote:
> but the *data* is easy to get at. The same doesn't apply
> to Word...
 > I have converted Word documents to ODF and back again, with little or
no change to the document.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 5 Apr 2008 15:15:19
Message: <47f7ddd7$1@news.povray.org>
Orchid XP v8 wrote:
>> Well, sure. Because the existing one can't store Word documents.
>> That's kind of my point.
> I refute that.
> I have converted Word documents to ODF and back again, with little or no
Oh, this only applies to the attributes of the document that are in
common with ODF. If you want to store the Word document with the
embedded .NET XML in it that accesses the SQL Server tables to
regenerate the chart when you open the file, you'll have a bit of
trouble, I expect.
Date: 5 Apr 2008 15:15:31
Message: <47f7dde3@news.povray.org>
> Yeah. HTML has had this ability for years, and they've had no end of
> trouble ensuring interoperability. Oh, wait...
Sounds like you never did anything non-trivial in Javascript in a
webpage. Or CSS. You can have HTML interoperability nightmares without
even involving scripts.
Date: 5 Apr 2008 16:00:28
Message: <47f7e86c$1@news.povray.org>
Nicolas Alvarez wrote:
> Darren New escribió:
>> Sure, if your premise is "we shouldn't have to reimplement Word in
>> order to implement everything in the standard", then such arguments
>> make sense.
> We shouldn't have to reimplement Word to change the value of a single cell.
You do if it's a spreadsheet and that cell is involved in formulas.
That's what a spreadsheet *does*.
That's like saying "we shouldn't have to reimplement a page-layout
engine to change a single word in a PDF file."
Date: 5 Apr 2008 16:16:20
Message: <47F7EC45.4000708@hotmail.com>
Darren New wrote:
> andrel wrote:
>> [snip]
> I agree with all that. :-)
>> They only seem stupid if you disagree with the (hidden) premises of
>> the speaker. Most arguments are along the line of 'this is not how you
>> define a standard'.
> I primarily mean that most of the arguments seem to be along the lines
> of "OOXML doesn't tell me how to X, so it's a bad standard", while ODF
> doesn't tell you how to X either. Or "You can't implement everything in
> the standard without recreating Word", when what's in the file is, by
> definition, everything that Word can do. That's the sense in which the
> arguments seem silly to me.
> Sure, if your premise is "we shouldn't have to reimplement Word in order
> to implement everything in the standard", then such arguments make sense.
> I think what it comes down to is, given the standard, the arguments
> against it are mostly kind of silly. However, were you to create a new
> standard from scratch, you wouldn't put in the kind of stuff that you
> need to put into OOXML to make it preserve all the semantics of current
> Word documents. And most arguments I've seen confuse these two situations.
I think most people think that MS should not have preserved whatever
Word does but should have designed a standard for a text document with
layout specifications. As the old Word files don't conform to the
standard anyway there is no reason to put everything that is for
historic reasons in there into the new file. If a government requires
you to write a 'document file format' that is not the same as 'document
your file format'. Of course the counter argument is that Word and it's
files contain much more than just text and markup. Within MS office
there is no clear distinction between text, webpages, presentations,
databases, and spreadsheets to name a few. And the counter counter
argument is 'indeed'.
Date: 5 Apr 2008 17:17:06
Message: <47f7fa62@news.povray.org>
"Orchid XP v8" <voi### [at] devnull> wrote in message
news:47f72f3f@news.povray.org...
> Sure, the
> database integrity logic and indexes and constraints and so forth are
> another matter, but the *data* is easy to get at. The same doesn't apply
> to Word...
Ever tried getting data out of a database file (any product) when you don't
have access to the DB engine that created it?
Good luck.
At least if I open a word doc in notepad I can copy the info out. The
formating's gone, but that can be replaced.
Date: 6 Apr 2008 05:10:27
Message: <47f89383$1@news.povray.org>
> Good luck.
OK, yah, that's not even funny...
Date: 6 Apr 2008 05:27:51
Message: <47f89797$1@news.povray.org>
> You know, PDF manages to look the same everywhere. This clearly
> demonstrates how "impossible" it is to write such a standard.
Ermm, no, I have seen several PDF files with forms and buttons etc that only
work properly in Acrobat Reader.  I guess they are using Adobe specific
extensions that nobody else implements.
> You know, PDF specifies exactly how stuff should look on a page - and
> *lots* of people have implemented that.
Word (and PDF to a certain extent) allow you to do far more than just say
how it should look when printed or print previewed.
> HTML & CSS allow you to construct complex layouts, and these are also
> widely implemented.
But usually look slightly different on almost every browser!
> That's kind of the point. It shouldn't *be* a way of storing Word
> documents, it should be a way of storing documents.
Sure, then just ignore the Word specific stuff and parse the document data
to display.  But when you export form Word that extra data is there should
you wish to implement certain things that Word does.  If MS only exported
exactly what you saw there would similar outcry about how it is impossible
for developers to implement the same functions as Word.
That's because you've only been using the "basic" features of Word, which is
fine.  But some people might want to develop programs to work with the more
advanced features of Word, previously they couldn't - now they can, but they
don't have to.
> The fact is, this is not the case. Nobody is going to be able to implement
> this standard properly, because it is specifically and deliberately
> designed to be impossible to implement. And that should not be allowed.
"Implementing the standard" is not a digital yes no thing, you can implement
just the parts you need for your application.  As Darren said, if you wanted
to implement the whole standard perfectly you'd essentially have to write a
copy of Word.
Date: 6 Apr 2008 18:33:26
Message: <47f94fb6$1@news.povray.org>
> implement just the parts you need for your application.  As Darren said,
> if you wanted to implement the whole standard perfectly you'd essentially
> have to write a copy of Word.
Let's say we have small app A and B.
If app A doesn't implement parts of the standard they don't use,
and app B doesn't implement parts they don't use,
then chances are you will have incompatible files between app A and B.
This incompatability is what standards are meant to help avoid.
Adopting a standard that is difficult to implement doesn't help
A and B, but it will help MS.
MS will be able to load files from A and B,
and save them in a format that is not readable by A or B.
Date: 7 Apr 2008 03:08:40
Message: <47f9c878$1@news.povray.org>
Why?  If app A and app B did nothing in common (so no parts of the file were
implemented in both programs) then why should the files be compatible?  App
A might be a simple word processor with no support for images, App B might
be a utility that cuts out all the text and just leaves you with the images.
Nobody would expect the files from App A to do anything useful in App B.
Which it does.  It says that if you are going to include text, you do it
like this, if you are going to put in an image, you do it like this, etc.
If your App A doesn't need images, you just ignore those parts in the file,
and if you're writing App B, you better make sure you implement the part of
the spec that deals with images.
Sure it helps A and B, in the past they wouldn't be able to write these
programs without reverse engineering the .doc file type.
Why should the file saved by Word not be readable by A or B?  A and B will
just ignore the parts they don't need.
