POV-Ray : Newsgroups : povray.off-topic : 33rd anniversary of .... Server Time
16 May 2026 23:06:48 EDT (-0400)
  33rd anniversary of .... (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: 33rd anniversary of ....
Date: 6 Apr 2008 14:21:19
Message: <47f9149f@news.povray.org>
Patrick Elliott wrote:
> Well, maybe true. We also might have ended up with a mil-spec system
> that is stable, required to operate in a wide range of conditions, and
> clearly documented interfaces.
We might have, but I doubt it.  That would be over-engineering to a
tremendous degree.
Where such things are necessary, they're built without too much trouble
beyond tremendous time and cost.
> What we have is unstable, often doesn't
> operate even in the conditions it supposedly was designed for, and even
> the clearly documented interfaces, like modem commands, get screwed up
> by nonstandard interfaces/drivers/control mechanisms, which where
> designed to work only with specific OSes.
This is pretty much true of every piece of long-lived general-purpose
software. It's impossible to foresee every eventuality. If your OS
doesn't support removable media or streaming 3D holograms, you're going
to have unstable programs that don't work right when you remove the
media out from under them or stream 3D holograms into their input files.
> In other words, we started with 100 species of machines, none of them
> alike, and ended up with something that... has almost as many hacks,
> bugs, design short cuts, and stupid compromises as human DNA (and not
> because those things "worked" better than the other paths tried).
But we have that mainly because of age and backward compatibility. It's
not like "autoconf" is a gem either, and for exactly the same reason.
> If the
> military built aircraft the way Microsoft, to a large degree, and
> others, to different degrees, pushed us to produce computers,
> we would be losing billion dollar airplanes once a week,
They wouldn't cost a billion dollars. They'd cost $1000, and they'd run
pretty well until you put a trailer hitch on them and tried to tow your
RV behind. :-)
> Its a logical fallacy to presume that Microsoft was "necessary", any
> more than just about any other absurd thing that led to the modern world
> "had to" happen to get here.
Of course.  What do you see as a motivating factor for hardware to get
standardized beyond someone selling a fairly cutting-edge software
package not tied to a particular piece of hardware?
 > Even if true, the real question is, "Was
> the price paid to do so *worth* it, given other paths that may have led
> to the same thing?"
Except they didn't. The world had the chance for 10 or 15 years, and
there were just as many competing incompatible brands when PC-DOS came
out as there were ten years earlier.
> PCs imho where inevitable. Had Microsoft not shown up, someone else
> would have. Eventually, some standard would have appeared. Likely, given
> the wide us of Unix, it would have been a *nix standard.
I disagree. UNIX puts too many requirements on the hardware for it to
work at the time.  What we *did* get that was vaguely standard was CP/M,
which is what PC-DOS was based on.
And, OK, which UNIX? Why do you think it would have been a standard, and
which one, and would it really have led to there being fewer flavors of
UNIX to program against? Even now, there's a dozen or more flavors of
UNIX in current use. We already *have* a "unix standard". You *still*
need autoconf, and it's broad enough Microsoft managed to implement it
in Windows (for some meaning of the word "implement").
Blame BSD for that, perhaps?
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 7 Apr 2008 00:24:03
Message: <MPG.22634fcf50c1a90698a13d@news.povray.org>
In article <47f9149f@news.povray.org>, dne### [at] sanrrcom says...
> > to the same thing?"
Neither did cars, until Ford, and frankly, Ford did it right, while
MS... didn't care about doing it right, so much as doing it profitable.
That is the difference between visionaries getting involved with an
industry, vs. those who just see a clear way to make a more cash.
n
Point was, it didn't have to be PC-DOS. Windows wasn't able to run on
those either.
Even with the need to make some adjustments, there is still a basic
standardization to internals, and commands. Windows new shell even
borrows the later, in a form of Bash like shell, since their own sucked
so badly. lol Look at cars. While there isn't much of a standard, and
not *every* part is interchangeable any more between makers, you can
still manage to weld together bits from different cars and have
something that still functions, and you can take parts from dozens, and
use them to build a car that "none" of the manufacturers would produce
themselves, and odds are, despite some specific differences, and a few
adaptions, most of its isn't going to flat out refuse to work right
because you plugged a Ford transmission into a Mitsubishi motor, in a
Chevy frame.
Yes, fragmentations is bound to happen ones the "foundation" is there.
The problem is, how you get to that foundation. MS kind of forced the
industry to build from the top floor down, and as a result often the
stuff on the lowest level doesn't always work reliably, while the OS
itself *is* standard, so it "looks" like the building is intact, even
though its shifting on the loose rubble on the bottom level, like a
drunken sailor on marbles. *nix went the other way. The foundation is
very close to the same, to a degree that it take relatively little to
adjust core processes between them, the hardware, when there is
documentation, and some sort of common interface, just works, without
having to have 234 device drivers (including different versions, and
multifunction devices, which may have 4-5 drivers), for 100 devices.
But, my point is. You can't reliably project from "because it happened
this way.", to, "It needed to happen that way." We have hindsight here,
and we still can't get out of the hole already dug, to try to fix the
problems that arose due to how it did happen.
void main () {
    if version = "Vista" {
      call slow_by_half();
      call DRM_everything();
    call functional_code();
  else
    call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 7 Apr 2008 01:35:58
Message: <47f9b2be$1@news.povray.org>
And what makes you say this?
Sure. But it was.  It had to be someone without a vested interest in one
particular brand of hardware, tho.  You didn't see Sun porting Solaris
to other peoples' chips until they realized they couldn't compete with
Intel as long as Windows was the problem. (Same reason they wrote Star
Office, same reason they've been battling Microsoft all along.)
 > Windows wasn't able to run on those either.
Windows ran on lots of machines where a fuller UNIX wouldn't. I'm not
sure what "those" means, unless you mean 8080-class chips, at which I'll
agree but wonder why you bring it up.
Windows could do a lot more with a lot less hardware. And it was PC-DOS
compatible.
And PC-DOS was very compatible with CP/M, conceptually. Indeed, the
original design was that you should be able to reassemble/recompile your
CP/M programs for 8086 and have them run under PC-DOS.
As with various versions of Windows. Yes?
> Chevy frame.
I see. That's why Apache and MySql and VI don't work at all under
Windows, yes?  I was wondering why that was.
I didn't mean to imply it did. *Someone* had to come along and make some
version of hardware a reasonable target for something like Linux before
Linux could get popular enough to snowball.  Lots of people wrote
operating systems for 8080-class machines, and none of them took off
(except CP/M) because they were all written to specific machinery by the
manufacturers of the machinery.  Once you had someone realize "Gee, we
can write the software *without* building the machinery", that's when
you start seeing "clones."
And while I admire your ability to turn a phrase, the hyperbole really
doesn't manage to communicate anything of interest other than your
distaste for Microsoft's products. You speak as if every day there are
thousands of people dying from Microsoft products, or that every
business that uses Windows goes broke trying to keep it running for more
than a few hours.
Date: 7 Apr 2008 12:24:45
Message: <47fa4acd$1@news.povray.org>
> Chevy frame.
Forget interchange of parts. With cars, if you learn to drive, you can
drive any car of any manufacturer. Doesn't seem to be the case with
operating systems, or with applications.
Date: 7 Apr 2008 19:12:31
Message: <MPG.226458149adb4f998a13e@news.povray.org>
In article <47f9b2be$1@news.povray.org>, dne### [at] sanrrcom says...
True.
> compatible.
Yeah, so what went wrong? lol Lets see. Code bloat, people actually
wanting to be able to transfer documents between unlike systems (with
filenames intact), oh, and an endless list of cases where people
"tried" to make something run on alternatives, but MS changed theirs in
some way that either broke the alternate, or broke their code "on" the
alternate. But sure. If they hadn't tried to rule the world, just live
in it, some of us might not be so annoyed by them.
Umm. Not really.. Half the stuff that doesn't work between 3.1 and XP is
a result of hacks needed to make it work right at all on 3.1, but which
where bugs, hole or unintended interfaces. The other half are cases
where MS changed the underlying implementations, so you just *can't* do
it any more. They are still doing that, releasing .NET, then basically
making it very very hard to code anything with MFC. Sure, it will still
*run*, usually, but its fairly clear that, if they could, they would rip
out all those old libraries and bury them, never mind what inconvenience
it might cause anyone.
> > Chevy frame.
Sorry? Are you saying all of those just had some bits of code lopped
off, some new code tacked on, then recompiled, because... I get the
impression its a *tad* more complicated than that most of the time. lol
Besides, your talking what is basically command line systems, which just
"happen" to have GUIs built to access them. Or, to put it another way.
Mind you, you get some of the same with Linux, depending on if its X, or
some other GUI you are running, but I get the sense that the gaps you
have to leap are "slightly" less cavernous. Besides, now you are talking
about odometers, gas gages, or steering wheels, which is a bit higher
level than the "core" systems.
> than a few hours.
Which version? lol Seriously though, forgive me if I would prefer to
avoid MS in my critical life saving devices. ;)
Ok, its not that bad, "anymore". It was, not that far back. I might
argue that we have, partly in XP, and hugely in Vista, traded stability
for the equivalent of some goon at the door saying, "Now, you know we
can't do nothing about the bad guys outside, so whys you want to leave?
Just stay here, nice and safe like, and let us decide if that packet
shood get sent or not." Security via not letting you do anything. Or an
admittance that they can't stop the stuff that "requires" that kind of
security. Either way, I didn't like 95/98 because it robbed me of a lot
of control I *used to have* over my system. XP, is kind of getting on my
nerves, and what I have seen of Vista... Well, I am not the only one fed
up at this point.
void main () {
  else
Date: 7 Apr 2008 19:17:34
Message: <MPG.22645948fb578fc798a13f@news.povray.org>
In article <47fa4acd$1@news.povray.org>,
nic### [at] gmailisthebestcom says...
> > Chevy frame.
True too. But just ask my father about that, he might disagree. His
favorite gripe is, "Why the #@$# can't they standardize where basic
controls like windshield wipers, emergency lights, etc. are located?" I
kind of have the same gripe, due to where I work, with how they can't
seem to decide where to put fracking door handles, or how they open the
door. Interestingly, this is one common factor in Windows upgrades too.
They can't decide where to put things, so keep changing them, and every
version you have to rediscover where they put the blasted speed control
from the wipers. Trivial, until you find yourself **needing** to change
it, but trivial enough, its probably "not" going to be the first thing
you try to figure out the new location for.
void main () {
  else
Date: 8 Apr 2008 13:35:42
Message: <47fbacee$1@news.povray.org>
Sure, bloat my OS code with printer drivers. I'll take that over having
six disks of printer drivers distributed with each application any day.
 > people actually
> filenames intact),
Never really had a problem with that...
> alternate.
Well, sure.  Even in the cases where that was deliberate, I'd still say
"well, duh."
Yes. If you take advantage of bugs or undocumented interfaces, or bypass
the API to try to do the same thing yourself without using the API, then
when the API gets upgraded, your program breaks.
It's not like nothing got rewritten since System 7 either. This is all
normal computer stuff that happens on every operating system and
application and framework everywhere.
> it any more.
Sure. See above. If you want a multi-user system, you can't take a
single-user application and expect it to run without giving it undue
privileges.  I mean, heck, even POV-Ray had to get beaten over the head
before it stopped writing per-user configuration into per-computer
directories. How long was Windows doing multi-user systems before Vista
finally said "OK, enough, really, you have to deal with multi-user
configuration"?
Things that are actually written to the documented APIs port
surprisingly well. If you write your own INI file parser, don't expect
the next upgrade of Windows to put your stuff in the right place in the
registry for you.
In what way are they making it hard?
 > Sure, it will still
And this differs from the desires of every single programmer inheriting
a legacy system in what way?
>>> Chevy frame.
No. I'm saying none of those programs "flat out refused to work" on any
OS, including Windows and variants of UNIX.
Well, yes, so? And putting a Ford headlight in a Ford car is going to be
much easier than putting a Ford headlight in a Toyota. (Note that there
used to be two kinds of headlights: Round, and Square. Now there's a
whole bunch.)
I haven't any clue where your analogy is supposed to be going. You seem
to be arguing that since cars are built from physical parts, Windows sucks.
I certainly would too. But then, I'd avoid Linux in those same situations.
IME, hardware is much flakier than software. I have about 40 Linux
servers I'm controlling right now. Between the colo "testing" their
generator and frobbing the power on and off, the bakery dumping a
50-pound bag of flour into the fans, the brand new expensive Dell
servers just deciding the disk controller doesn't exist any more, I've
had way more crashes than anything in software causes.
I've also worked at companies where the servers were running Windows,
and they just never died unless the hardware did.
Indeed, the worst OS I've used is actually Solaris, where we had to
rearchitect a number of services to account for the bugs in the OS that
would (for example) not reap processes spawned by cron such that even
kill -9 didn't stop them, or write file data over top of the inodes just
because the disk got busy.
So I don't know what kind of professional experience you've had with
long-running Windows machines, but "drunken sailor on marbles" is far
from my experience.
I had no problems with keeping Win2000 servers running indefinitely. We
had them locked down in a different state, with the only access being
remote unless you wanted to hop on a plane for a couple hours.
That's 8 years back, now.
Sure, DOS could get locked up pretty easily. WFW worked surprisingly
well for the time and the power of the machines it was on.
Try running Unix on a machine with no virtual memory, no memory
protection, and the kernel in the same address space as the user
programs, and see how well it runs.
Again, a bizarre analogy. How about explaining what you dislike about XP
by means of a reference to computers rather than to the Godfather movie?
 > Or an
> security.
What kind of "stuff" are you talking about?
Like what?
> up at this point.
Yeah, Vista is certainly a step back in many ways. Many of the problems
it's trying to solve, tho, are people who are saying "I should be able
to do anything I want, oh and when it breaks we'll blame Microsoft."
The thing I don't really understand is the number of people who use
MacOSX, Linux, and Windows, and complain that Windows asks for
confirmation for privileged operations, but equally croon about how
great Linux is that you have to sudo a program so you know it's
something dangerous.
Date: 8 Apr 2008 13:37:14
Message: <47fbad4a$1@news.povray.org>
No more true than with OSes, I think. Try driving a school bus, an
18-wheeler, a formula 1 race car.
It's more like "once you know how to work one Windows app, you know how
to work them all", or "once you know how to work one MacOSX app, you can
figure out how to work all the others."
Date: 8 Apr 2008 20:31:44
Message: <MPG.2265ba7b66df1e7898a140@news.povray.org>
In article <47fbacee$1@news.povray.org>, dne### [at] sanrrcom says...
Umm. Actually, I was referring to Windows there, not the bloat in Linux,
which at its most bloated looks anorexic by comparison. lol
>  > people actually
> > filenames intact),
Well, it didn't come up often, but some times...
s
True enough. One wonders why most of that stuff was so deeply buried in
the first place though. Try, for example, writing your own program,
which doesn't use IE core or export to wsh, so that it can a) run
scripts, b) use "createobject" like COM support *and* also correctly
bond those objects connection points to event managers. Two years I have
been looking for a solution and all I have gotten is "Well, why no just
rewrite everything in .NET, .NET is magical (never mind it seems to have
some similar problems), or 2-3 articles involving work arounds, none of
which supply useful example code, but just babble about theory and how,
"If you are as skilled and well versed as I am, implementing this
wizbang solution should be trivial!". Uh, yeah, that *kind of* why I
went looking for answers, because some of us don't have leet skillz. lol
Even knowing, in theory, all the bits that make it work, I can't find
any damn way to use it, without practically rewriting the entire program
I want to do it in from scratch, and then, it might still not work. Bad
enough when you don't document unknown interfaces, but to intentionally
make every single library so that it *prevents* people from being able
to use the documented interfaces to do anything but use early bound
objects... That is just perverse.
> > it any more.
> configuration"?
> registry for you.
Yes, yes, I can understand that. Tha isn't the problem though. Its not
privilege levels that are being screwed up, its stuff like the patch
that prevents you executing certain types of packets on a network, which
only inconveniences the hackers, but, in some configurations/networks,
also hoses certain tools use to do determine what is wrong with your
network. And then there are issues like deciding that no one is going to
care if you make 99% of all games prior to Vista stop working, because
you think you have a *better* solution for sound support than 20 years
of sound card manufacturers, and it doesn't actually try to support the
old method. Sure, lots of processing power. But, are you *sure* that
**no one** is going to be trying to use any of it for other things
"while" playing the games that need that sound?
Look, we can go back and forth all day about why they decide to do some
things, how its bad, or not bad, etc. Just saying, if you are the guy
that needs something to work the way it did, and not the other 90% who
don't know a phone jack from a cat5e jack, some of this stuff is a pain
in the ass when they start messing with it.
Umm. Other than buying the full compiler because they decided that the
"free" version would only support the newest version, there is the fact
that MFC was a bonehead design to start with, and its not easy to recode
any of it to work under a different library. Mostly, in my case, its
that I never had a reasonably up to date copy of MS' compiler, so I
would have to sell a kidney to be able to make changes to a product
written in something that they don't freely support. Which seems wacky
to me. You would think that writing the .NET system and releasing it
would cost "more" than dropping the 10+ year old MFC libraries on a
website and saying, "we don't support this anymore, but for that that
want it, here you go." They are going to charge me for the stuff that
obsolete, but not the newest stuff?
Yeah, yeah, I know the reason. It doesn't help my mood when I look at
the price tag. lol
s.
No, I mean that I was talking about core features, while you are talking
about a layer higher than that. Its bound to be easier, within limits,
to rewrite something where 90% of the function is "in" the application
and its only a few interfaces and the display that need tweaking. Its a
bit more serious if the heart of your application is relying on some
core feature working, which doesn't work the same on the new OS, or come
close enough to patch over.
Point was, unless its hardware related (and that is a whole new can of
worms), *nix isn't likely to have too many of those, even between
different "versions".
Got an external HD with similar issues. Power goes out, I have to reboot
for some reason (something messed up Halo so bad I had to reinstall,
after rebooting, since it froze solid), and the drivers and drive
monitor both insist that its unformatted... Not as bad as insisting it
doesn't exist, but geeze... Oh, well, they hosed the backup software on
it anyway. It doesn't backup anything not in its "approved" list,
including settings, databases for your browser and email, etc... Oh,
and, just to be real jerks, they don't sell an upgrade that *does* work
like the older version that did do all those things. WTF?
Gah.. Ok, that is just nuts. Yeah, if someone can manage to fowl up
something that is *usually* stable, they will find a way to do it.
> from my experience.
Oh, Windows 95 worked great, so did Win3.1, as long as I was careful
what I let it patch over. XP has been good so far. 98... Lets not talk
about it. lol
Because, its like having a goon sitting "inside" your house telling you
what *you* are allowed to do sometimes, instead of standing "outside"
the house, to protect you from the real problems. Sure, some people
*need* the goon, since they are not too bright and will do dumb things.
I get a bit annoyed trying to learn how to "not" do dumb things and
having the goon tell me, "Yous sure you wanna do that?", all the time,
even when I know that it will work. Its almost as bad, but less
intrusive, than the stupid paperclip thing they had/have in certain
applications.
>  > Or an
> > security.
Umm. People making your machine a zombie. They seemed to figure that no
one has a legitimate reason to create certain types of arbitrary
packets, so no one would mind if they limited what zombies could do,
even though it also torpedoed things that used the same principle to
work, and where legitimate products. Heh, its just one I ran into
recently, not a huge issue, but its not the only thing I hear people
griping about with how they did Vista's security model (and also partly
XP).
> Like what?
Mostly trying to fix things if they broke, or changing settings that
even the admin user doesn't necessary have clear access to. I haven't
run into it recently, since for the most part the case where you needed
to do those things where ones where it was just easier to find some
other way to solve the problem. I am not going to go into a list, since
its been a while since I used either OS, and I don't remember half the
annoying things I tried to adjust in them. (some there cases where you
could only change the setting via regedit though).
d
> > up at this point.
lol Yeah. Though, at times I wish Sudo existed on Windows. Frankly, I am
running, and shouldn't be, in a full access user, precisely because I
know if I change to a protected one I am going to be spending way too
much time arguing with the OS about what I am doing, or situations where
a sudo would solve an issue real easy, but where only logging out and
back in as admin would fix in Windows (and having to close down
applications that I either don't want to, or can't afford to if they are
doing something, like BeyondTV. Mind you, once in a while you get one of
the system updates that the OS **incists** you reboot with, and you
don't even realize it happened until the next morning when you find that
a) the applications you had open are all closed and b) what ever you had
it doing overnight never finished... There doesn't seem to be a "let me
fracking reboot when "I" want to option. Instead it keeps popping up
ever 5-10 minutes to ask you, "Heh! You done yet. Want to reboot?" No
frell you!!
void main () {
  else
Date: 8 Apr 2008 21:15:15
Message: <47fc18a3$1@news.povray.org>
I was too. I guess you never actually used DOS or something.
What "stuff"??
Don't even *start* talking about sound being poorly supported on Windows
until you've made sound work on Unix.
I agree. Of course. I'm just disagreeing that this is unique to one
operating system, or even that it's avoidable.
So, by "hard to support", you mean "commercial."  Come on, it's not
*that* expensive.
> the price tag. lol
Well, why are you even supporting Windows, then? It's a commercial
product. If you want to work on stuff for free, there are excellent
alternatives available.
I'm not sure what you consider a "core" feature. Me, it's starting a
program, reading and writing files, using internet connections, normal
windows widgets like scrollbars and text entry, etc. I have zero problem
moving my core programs between Windows and Linux with appropriate
libraries underlying.
Well, yes.
I disagree. Where's /dev/mt?  Do you have /proc under Solaris?
And again, I point to autoconf as a trivial counterexample. Take a look
at all the things autoconf can configure, and tell me which of those are
hardware related, and which you're unlikely to need in a "core" application.
> about it. lol
Yeah, some of the older OSes could have problems if you installed
crapware. If you didn't, no problem.
The analogy police are on their way. You've been warned.
How does this differ from UNIX saying you're not allowed to delete
something out of /bin for your own good?
> Sure, some people
I think it isn't that they aren't too bright. It's that they know
nothing about how the computer works.
It's asking permission to elevate your privilege. If you're running as
administrator, you're already doing something wrong, so complaining that
you're being annoyed by the warnings is kind of silly, methinks.
>>  > Or an
>>> security.
> XP).
I expect they actually have a different interface of some sort for
creating those alternate packets, and people are griping that it
changed, but that's just a guess.
>> Like what?
Sorry. "Admin user" in 95?  Impress me by explaining what you're talking
about, given that Win95 is a single-user OS.
And UNIX is better at this, is it? ;-)
>>> up at this point.
Um, it does. It's called "runas".
> Frankly, I am
You'd be surprised, actually. I mean, unless you've got really old
crappy software.
> or situations where
Why would you log out just to log in as administrator? Just lock the
screen, and log in while the other user is still logged in.
Never had that happen. The worst I get is the little yellow shield in
the corner saying "please let me know when I should install these patches."
> There doesn't seem to be a "let me fracking reboot when "I" want to option.
Of course there is. Or do you think people have production servers all
over the internet randomly rebooting on patch day?
Go to the control panel, under automatic updates. If you want it to
reboot after installing patches, tell it when and on what day of the
week in the drop-downs. Otherwise, set it to "download updates but let
me pick when to install them."  Or "notify me but dont download them."
> frell you!!
If you let it get to that point at all, you can stop it by (surprise)
stopping the windows update service.
"Gee, this CD player keeps playing this CD over and over! It's driving
me nuts!"
     "Did you try stopping the CD player?"
"Oh. No. Didn't think of that."
