POV-Ray : Newsgroups : povray.off-topic : Liquid Physics Server Time
23 Dec 2025 21:44:39 EST (-0500)
  Liquid Physics (Message 1 to 10 of 37)
Subject: Liquid Physics
Date: 30 Mar 2008 17:49:01
Message: <47f018dd@news.povray.org>
So, just for fun I'm writing a quick liquid simulation.  Because I like
liquids, and I'm learning C#, that's why :)
Anyway, I'm running into some problems with the simulation.  Namely, a
certain instability.  Here's what I'm doing:
For each particle, I loop through all the other particles (i=0..count-1,
j=i+1..count), and check the distance between them (I use some
additional bounding to speed things up, but that's not important to my
problem here).  I compute the forces the two particles place on each
other, and then add them to each particles' total "force" value.
Once I'm done computing interactions, I loop through all the particles,
add the force to the velocity, and reset the force to zero.
The way I see it (and granted, I've never written a liquid sim before),
there are two forces I need to deal with, pertaining to two stages that
occur when liquid particles collide:
1) When the particles are farther apart, they attract each other.  This
weak attraction would be the driving force behind surface tension.
2) When the particles are closer together, they push against each other.
  This force must be much stronger than the first in order to maintain
some volume.
Now, so far I'm only actually implementing the second force above.
However, what I see is that the particles tend to settle pretty quickly
to the floor, and then they clump together.  Apparently, the particles
on the outside "force" the particles in the middle of the clump closer
and closer, until they suddenly explode and things go flying everywhere.
I *think* the problem has to do with conservation of momentum.  I
naively dealt with that by halving the force applied to each particle in
a pair (one half of the force gets applied to each), but that's not
quite right, is it?  The momentum of each particle shouldn't simply be
split evenly with every individual particle it collides with... rather,
I'll need to collect a list of interactions, and split this particle's
momentum between *all* of those other particles...
If anyone else here has dealt with similar issues, I'd appreciate
knowing if I'm on the right track...
...Ben Chambers
www.pacificwebguy.com
Subject: Re: Liquid Physics
Date: 31 Mar 2008 02:13:05
Message: <47f08f01$1@news.povray.org>
Firstly, I wouldn't use integration like this, it's called Euler integration
and is basically rubbish and well known for being unstable.  A far better
method, and the de-facto standard in real-time applications, is Runge-Kutta
4, or RK4 for short.  It is far more stable and much more accurate per CPU
time than the Euler method.
There are numerous tutorials and explanations online of how to use RK4 in
exactly the sort of simulation you are doing, but one of my favourites is
here, it's very clear.  It's got small code snippets in C++ but they are
very simple and should be easy enough to convert to any language.
http://www.gaffer.org/game-physics/integration-basics
> This force must be much stronger than the first in order to maintain some
> volume.
When I did this sort of thing before, I did both forces as one using a
single function.  Something like:
Force = A * (1/d^4) - B * (1/d^2)
Where d is the distance between two particles, and A,B are constants.
> However, what I see is that the particles tend to settle pretty quickly to
> the floor, and then they clump together.  Apparently, the particles on the
> outside "force" the particles in the middle of the clump closer and
Your physics time-step is too big.  WHat is happening is that from one frame
to the next two particles are moving from far apart to *very* close
together.  IRL (and with a smaller time-step or better integrator) this
wouldn't happen, because there would be inbetween steps that prevent the
particles getting this close together.
There are several ways to fix this (I would do all of them if I were you):
1) Use RK4 instead of Euler (this will let you get away with much bigger
time-steps without explosion)
2) Use smaller time-steps, eg update the physics 10 times for every graphics
update
3) Limit the maximum force artificially in the code to avoid explosions
So long as your time step and integration method are accurate enough to
avoid explosions, it doesn't matter what the formula for Force is, so long
as you apply it equally and opposite to each pair of particles momentum will
be conserved.
I would also add some damping force, proportional to speed or speed squared,
this will also help calm things down.
Date: 31 Mar 2008 08:16:53
Message: <47f0e445$1@news.povray.org>
> integration and is basically rubbish and well known for being unstable.
> A far better method, and the de-facto standard in real-time
> applications, is Runge-Kutta 4, or RK4 for short.  It is far more stable
> and much more accurate per CPU time than the Euler method.
True indeed. Now, if I could just figure out how the hell to implement
RK4...
[Sure, I have a dictionary of mathematics, and there's Wikipedia and
there's MathWorld, but all involve pretty abstract mathematics that is
difficult to figure out how to apply to a really complicated
differential euqation.]
> in exactly the sort of simulation you are doing, but one of my
> favourites is here, it's very clear.  It's got small code snippets in
> C++ but they are very simple and should be easy enough to convert to any
> language.
Mmm, that's a nice article. I'm still having trouble following it
though. Perhaps a Haskell example?
   integrate t dt a (v,p) = (v + dt*(a t v p), p + dt*v)
OK, well that seems trivial enough. So how about RK4?
   evaluate (v,p) t dt (dv,dp) =
     let
       v' = v + dt*dv
       p' = p + dt*dp
     in  (v', a (t+dt) v' p')
     let
       a = evaluate (v,p) t dt -- er... where's the rest?
       b = evaluate (v,p) t (dt/2) a
       c = evaluate (v,p) t (dt/2) b
       d = evaluate (v,p) t dt     c
       dv = (fst a + 2 * (fst b + fst c) + fst d) / 6
       dp = (snd a + 2 * (snd b + snd c) + snd d) / 6
     in (v + dt*dv, p + dt*dp)
Er... is that actually correct? And what's with the formula for A? I'm
not really understanding how this is supposed to work...
Yep, I've seen this happen lots before.
> graphics update
Indeed.
For my chaos pendulum simulations, I added a constant term to the
denominator in the "inverse square law" force calculations to prevent
division by zero and absurdly large forces.
I intended (but never got round to) implementing a system where the
computer integrates a time step, then integrates it again with twice the
resolution, and if the results differ too much, it subdivides further...
http://blog.orphi.me.uk/
Date: 31 Mar 2008 09:22:09
Message: <47f0f391$1@news.povray.org>
> Mmm, that's a nice article. I'm still having trouble following it though.
>     let
>       v' = v + dt*dv
>       p' = p + dt*dp
>     let
The only difference is that in the evaluate function without the supplied
derivative, you don't need to update the state, simply return the derivative
at time t using the initial state.
> Er... is that actually correct? And what's with the formula for A? I'm not
What it's doing is this:
1) Work out the derivative at time t.  This is simply a matter of
calculating the new acceleration at time t (as the derivative of velocity)
based on the current state, and returning the current velocity (as the
derivative of position).
2) Using the derivative you just calculated, a, calculate a new state at
time t+dt/2 using normal Euler integration.  Return the derivative of the
new state.
3) Same as step 2, but use b instead of a, and store the result as
derivative c.
4) Same as 2, but this time use the derivative c to do the whole step dt
from the first point.
5) Take a weighted average of all the derivatives you just caluclated, a-d,
this gives the most accurate derivative.
6) Use this weighted average to actually advance your state by dt using
If you want to actually understand the maths behind it, well that's another
story (and another Google search, or two :-).
A good idea, it's called "adaptive time step".
Date: 31 Mar 2008 09:38:41
Message: <47f0f771$1@news.povray.org>
>>     let
> supplied derivative, you don't need to update the state, simply return
> the derivative at time t using the initial state.
Er... right... I think...
So just return v and the instantenous acceleration at time t?
It's news to me that C++ supports optional function arguments.
[And while we're on the subject, this is the first example of C++ code
I've ever seen which appears to be comprehensible. Usually it just looks
like gibberish...]
So anyway, it computes several derivatives and takes their weighted
average. That seems simple enough in principle. I rather suspect that in
practice it's spine-tinglingly easy to screw up some tiny detail that
makes the entire algorithm not work properly. There's *a lot* of
individual steps there to get right...
>> the resolution, and if the results differ too much, it subdivides
>> further...
Mmm, as with all adaptive algorithms, the key is to get the maximum step
size "small enought", and to avoid infinite recursion. (I also wondered
if maybe it would be better to just look at the magnitude of force
changes or something to decide how "stable" the system is at this point...)
Date: 31 Mar 2008 10:10:46
Message: <47f0fef6$1@news.povray.org>
Yes, exactly.
Of course it does (see printf) but you don't use that here.  You just define
two functions with the same name but with different arguments (this is where
the article text is a bit misleading IMO).  The compiler knows which one to
actually call because it matches up the arguments.
> like gibberish...]
Maybe because it's written for the purpose of clarity rather than trying to
make it look "clever" by being totally unreadable.
Yeh, try it first with a simple model like a mass on a spring, or a
pendulum.  You can then check the results with the actual theory of those
models, and even compare to standard Euler at the same time.
When I first wrote my RK4 code for the thing I'm currently working on, I
accidentally updated the initial state for each of the 4 derivative
calculations.  It was only when I noticed that the velocities being reported
didn't match up with the actual distances being covered (like covering 1km
in 10 seconds at a speed of 20 m/s!) that I found the bug.
> size "small enought", and to avoid infinite recursion. (I also wondered if
> maybe it would be better to just look at the magnitude of force changes or
A common method used in car simulations (where the tyres are very stiff and
hence need a very small time step or the thing explodes easily) is to check
that energy is (almost) conserved.  Going back to the simple mass/spring
model, if you keep track of the kinetic energy in the mass and the spring
energy stored, it should be fairly trivial to include a check if the total
energy has suddenly spiked.  If so you could then do some smaller time
steps.  Of course if you are getting input from outside the system you need
to account for this too.
Date: 31 Mar 2008 10:17:24
Message: <47f10084$1@news.povray.org>
> define two functions with the same name but with different arguments
> (this is where the article text is a bit misleading IMO).  The compiler
> knows which one to actually call because it matches up the arguments.
Ah, right, so it's overloaded but that's not shown in the article?
(BTW, I thought printf() was only for C, not C++?)
>> looks like gibberish...]
> to make it look "clever" by being totally unreadable.
Did the Haskell version look "readable"?
> reported didn't match up with the actual distances being covered (like
> covering 1km in 10 seconds at a speed of 20 m/s!) that I found the bug.
One of the nice things about Haskell is that you can't make that
mistake. Since you never update anything in-place, you can't
accidentally destroy a result you need to use again later, and by left
wondering where this "wrong" data is coming from.
...unfortunately you *can* still accidentally return the wrong damn
varible from your function. :-S
> and hence need a very small time step or the thing explodes easily) is
> to check that energy is (almost) conserved.  Going back to the simple
> mass/spring model, if you keep track of the kinetic energy in the mass
> and the spring energy stored, it should be fairly trivial to include a
> check if the total energy has suddenly spiked.  If so you could then do
> some smaller time steps.  Of course if you are getting input from
> outside the system you need to account for this too.
Mmm, it has a flavour...
Date: 31 Mar 2008 10:38:17
Message: <47f10569$1@news.povray.org>
Yup, it is in the source code however.
Well it is for C, but anything you can do in C you can do in C++.  Not that
it's a good idea though...
Not really, I tried to add some to your code to show what I meant with the
other evaluate function, but I couldn't work out what was going on!
> One of the nice things about Haskell is that you can't make that mistake.
> Since you never update anything in-place, you can't accidentally destroy a
> result you need to use again later, and by left wondering where this
Seems logical, but without thinking about it too much, how would you keep
track of the state of the system while it's running?  Are you basically
saying that variables are write-once in Haskell?  SO I couldn't do something
like:
currentState = Integrate(currentState);
I would need to instead do:
frame++
state[frame] = Integrate( state[frame-1] )
Date: 31 Mar 2008 10:56:14
Message: <47f1099e@news.povray.org>
Ah, OK. I thought it was just a typo or something...
> that it's a good idea though...
Ah yes, C++ is a superset of C. But I was thinking (hoping?) that in C++
you have something less hellish than prinf() to play with...
> the other evaluate function, but I couldn't work out what was going on!
No, Haskell doesn't support overloaded functions, so you'd have to make
some moderately radical (oxymoron?!) alterations to make it work.
> keep track of the state of the system while it's running?
Ah, grasshopper, you are still thinking in imperative terms. ;-)
A true Haskeller would define a notionally infinite list which
notionally contains the entire state of the system at every future point
in time. Examining the elements of this list causes the integration to
actually be performed, and assuming you let go of the start of the list,
the GC will delete each state after it has been calculated.
In other words, define an infinite list, and then map some monadic
function over it which displays the state of the screen or dumps it to a
file or otherwise "does" something with it. And the result will be more
or less like this C++ example.
Now, if you want to use *user input* to alter the integration as it
proceeds, then you must take an somewhat different approach. (See below.)
> Are you
> basically saying that variables are write-once in Haskell?
You *could* put it that way. It would be more correct to say that a
variable is *defined* as having a specific value in Haskell. Consider this:
   let node1 = Node {next = node2, prev = node4}
       node2 = Node {next = node3, prev = node1}
       node3 = Node {next = node4, prev = node2}
       node4 = Node {next = node1, prev = node3}
   in ...
As you can see, it's not so much that you can only assign once to a
variable, it's that you are *defining* what a variable's value *is*. The
compiler will chase dependencies - even circular ones - and resolve them
for you, figuring out what order to initialise everything and so forth.
(You can't really speak of assigning several values to the same variable
"one after the other" because [pure] Haskell function don't have any
notion of "time".)
> So I couldn't do something like:
No, you couldn't.
You could, however, write
   animate state = do
     dispaly state
     let new_state = integrate state
     animate new_state
which will display the initial state, call your integrate function to
compute the next state, display that state, and so forth. (This method
*does* allow you to accept user input and do something different based
on what the user input is.)
A third way would be to use explicitly mutable state - something like this:
   state <- takeMVar my_state
   writeMVar (integrate state)
But there's no particular advantage in doing that here, and it just
takes more typing to write out.
Date: 31 Mar 2008 11:13:14
Message: <47f10d9a$1@news.povray.org>
You do.
C:
printf("Number is: %d\n", somenumber);
...and be careful types match between format string and arguments
passed, and particularly that you passed *enough* arguments
C++:
cout << "Number is: " << somenumber << "\n";
...and there is no duplicated information that could get out-of-sync
(format and arguments).
It's just you can still use the C way if you want to.
