POV-Ray : Newsgroups : povray.off-topic : Liquid Physics Server Time
16 May 2026 23:06:41 EDT (-0400)
  Liquid Physics (Message 28 to 37 of 37)
Subject: Re: Liquid Physics
Date: 2 Apr 2008 07:18:18
Message: <47f3798a@news.povray.org>
Right. Well maybe it would be helpful to fix a few typos...
>   evaluate (v,p) t dt (dv,dp) =
>     let
>       v' = v + dt*dv
>       p' = p + dt*dp
>     in  (v', a (t+dt) v' p')
Err... that's incorrect. The acceleration function ("a") needs to be a
parameter somewhere. Or it needs to be a top-level function. Let's make
it top-level, like in the C++ version:
   acceleration t v p = ???
   evaluate (v,p) t dt Nothing = (v, acceleration t)
   evaluate (v,p) t dt (Just (dv,dp)) =
     let
       v' = v + dt*dv
       p' = p + dt*dp
     in  (v', acceleration (t+dt) v' p')
[I made the derivatives optional too. Did I get it right?]
>   integrate t dt a (v,p) =
>     let
>       a = evaluate (v,p) t dt -- er... where's the rest?
>       b = evaluate (v,p) t (dt/2) a
>       c = evaluate (v,p) t (dt/2) b
>       d = evaluate (v,p) t dt     c
>       dv = (fst a + 2 * (fst b + fst c) + fst d) / 6
>       dp = (snd a + 2 * (snd b + snd c) + snd d) / 6
>     in (v + dt*dv, p + dt*dp)
...and if we're using a top-level acceleration function, you don't need
that "a" parameter there (which incidentally causes a name clash).
   integrate t dt (v,p) =
     let
       a = evaluate (v,p) t dt     Nothing
       b = evaluate (v,p) t (dt/2) (Just a)
       c = evaluate (v,p) t (dt/2) (Just b)
       d = evaluate (v,p) t dt     (Just c)
I'll have to try this out later and see if it actually works...
http://blog.orphi.me.uk/
Subject: Re: Physics Code
Date: 2 Apr 2008 07:30:41
Message: <47f37c71$1@news.povray.org>
You know what? Screw it. Let's start again...
data State = State {velocity, position :: !Double}
data Derivative = Derivative {dvelocity, dposition :: !Double}
evaluate :: State -> Double -> Double -> Maybe Derivative -> Derivative
evaluate s t dt Nothing = Derivative {dvelocity = acceleration s t,
dposition = velocity s}
evaluate s t dt (Just d) =
   let
     s' = State {velocity = velocity s + dvelocity d * dt, position =
position s + dposition d * dt}
   in  Derivative {dvelocity = acceleration s' (t+dt), dposition =
velocity s'}
integrate :: State -> Double -> Double -> State
integrate s t dt =
   let
     a = evaluate s t dt     Nothing
     b = evaluate s t (dt/2) (Just a)
     c = evaluate s t (dt/2) (Just b)
     d = evaluate s t dt     (Just c)
     dv = (dvelocity a + 2 * (dvelocity b + dvelocity c) + dvelocity d) / 6
     dp = (dposition a + 2 * (dposition b + dposition c) + dposition d) / 6
   in  State {velocity = velocity s + dv * dt, position = position s +
dp * dt}
acceleration :: State -> Double -> Double
acceleration = error "not implemented yet"
Does that look correct?
Date: 2 Apr 2008 07:47:08
Message: <47f3804c$1@news.povray.org>
Well, I just ran it on a simple harmonic oscilator and got a sine wave,
so that's always a good start...
Subject: Re: Wave Physics
Date: 2 Apr 2008 07:54:19
Message: <47f381fb$1@news.povray.org>
> I know I've asked this before, but what's the algorithm for this?
The wave equation.
http://en.wikipedia.org/wiki/Wave_equation
2nd time differential of "wave value" is proportional to the 2nd spatial
2nd time differential is just acceleration (use it in an integrator like RK4
to get the new positions).
2nd spatial differential in 2D is just d2u/d2x + d2u/d2y
See attached POV code.
Download 'us-ascii' (3 KB)
Date: 2 Apr 2008 08:10:52
Message: <47f385dc$1@news.povray.org>
> The wave equation.
> RK4 to get the new positions).
Right. So for each pixel, measure the difference against the four
neighboring pixels, total that up, multiply by the wave propogation
constant, and that's the total acceleration for this pixel. Seems simple
enough.
What happens if the wave propogation medium propogates different
frequencies at different velocities?
Date: 2 Apr 2008 08:14:24
Message: <47f386b0$1@news.povray.org>
> enough.
The wave propagation constant is not constant, but a function of
frequency (dispersion relation).
Date: 2 Apr 2008 08:25:28
Message: <47f38948$1@news.povray.org>
Well then your c is a function of frequency, it's also probably a function
of "wave value" and "wave steepness" too in real life. (higher and steeper
waves might propogate faster than lower waves).  Good luck calculating the
frequency at a point though :-)  I'm thinking you might be able to do
something clever with fourier though...
Date: 2 Apr 2008 08:28:25
Message: <47f389f9$1@news.povray.org>
> function of "wave value" and "wave steepness" too in real life. (higher
> and steeper waves might propogate faster than lower waves).  Good luck
> calculating the frequency at a point though :-)  I'm thinking you might
> be able to do something clever with fourier though...
Well, Reaktor's "Steam Pipe" instrument simplates dispersion using a
simple all-pass filter in the feedback loop. OTOH, it's only trying to
simulate a 1D wave. At exactly 1 point in space. Hmm, maybe you could do
some sort of interesting convulation operation?
Date: 3 Apr 2008 01:59:09
Message: <47f4803d$1@news.povray.org>
I think if you are simulating a musical instrument, it would be better to
get the resonant parts working first before you start trying to simulate
different propagation speeds at different frequencies.  I would imagine that
is a much smaller secondary effect.
Date: 3 Apr 2008 03:13:05
Message: <47f49191$1@news.povray.org>
>>> (higher and steeper waves might propogate faster than lower waves).
>>> Good luck calculating the frequency at a point though :-)  I'm
>>> thinking you might be able to do something clever with fourier though...
>> do some sort of interesting convulation operation?
> to get the resonant parts working first before you start trying to
> simulate different propagation speeds at different frequencies.  I would
> imagine that is a much smaller secondary effect.
Oh yeah, sure. I'm just going off at a tangent now. ;-)
