POV-Ray : Newsgroups : povray.off-topic : Question about garbage collection (not a flame) Server Time
16 May 2026 23:05:05 EDT (-0400)
  Question about garbage collection (not a flame) (Message 15 to 24 of 24)
Subject: Re: Question about garbage collection (not a flame)
Date: 31 Mar 2008 15:58:31
Message: <47f15076@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> http://www.iecc.com/gclist/GC-faq.html
  "Most allocated objects have short lifetimes."
  Hmm, that may be so with languages which force you to allocate everything
on the heap (ie. things which potentially have longer lifetimes than
stack-allocated local objects).
  Personally I seldom find myself allocating memory dynamically for short
periods of time in time-critical parts of the program, when coding in C++.
Most short-lived objects and variables can usually be handled on the stack.
  Stack allocation is actually pretty fast (at least with gcc in linux).
I have made some tests which sometimes even gave surprising results:
Having a single heap-allocated array which is used by a function each
time this function is called can sometimes be even slower than having
the function allocate the array from the stack each time it's called.
(In other words, having allocated an array just once with 'new' and
having the function, which is being called repeatedly, just use that
array, may in some cases be slower than if the function allocated the
array for itself from the stack each time the function is called.)
  That's a bit surprising of a result, but might be explainable by
cache behavior or something similar.
  (The reason why I tested this was because having the function use
the externally-allocated array is not thread-safe, while having it
allocate the array locally is.)
Date: 31 Mar 2008 16:18:11
Message: <op.t8wf4l2m7bxctx@e6600.bredbandsbolaget.se>
That stack allocation is fast should come as no surprise since it
typically requires a grand total of zero additional CPU instructions. In
the worst case it requires a single one-cycle instruction.
FE
Date: 31 Mar 2008 22:06:32
Message: <47f1a6b8$1@news.povray.org>
Warp wrote:
> (Naturally if it's a long chain of references, destroying the first
> object will destroy all the others like dominoes falling.)
That's where the "nondeterministic time" comes in with reference
counting, just so you recognise.
>> Reference counting really is far too simplistic to work properly.
>   Well, as long as you don't have circular references (there are ways
> to make it *difficult* to create them) I don't see a problem.
That's the primary problem, yes. That, and the size of the counter, if
it needs to be the same as the size of a pointer. And that it's probably
the slowest way to do GC.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 31 Mar 2008 22:08:55
Message: <47f1a747$1@news.povray.org>
And if it's not on the heap, but on the stack instead, it *still* has a
pretty short lifetime. :-)
Yep. And a lot of languages are smart enough to figure that out
automatically. Not Java as initially implemented.
One of the advantages of letting the compiler handle stuff like this for
you is that the compiler can get smarter.
Yeah, or better addressing modes maybe?
Date: 1 Apr 2008 04:07:09
Message: <47f1fb3c@news.povray.org>
  How is that nondeterministic? It's perfectly predictable when those
objects will be destroyed. Just because destroying one object causes
the destruction of another doesn't make it "nondeterministic".
Date: 1 Apr 2008 04:08:34
Message: <47f1fb91@news.povray.org>
  But so does using a pre-allocated array. The array is *already* allocated.
The function doesn't need to allocate it each time. Yet, in some cases,
the function becomes faster by using the stack-allocated array than the
pre-allocated array in the heap.
Date: 1 Apr 2008 12:05:45
Message: <op.t8xy3ubv7bxctx@e6600.bredbandsbolaget.se>
> allocated.
Two points to consider:
- Data locality
Allocating the array from the stack keeps it close to the local variables,
thus confining memory accesses to a smaller area. This plays better with
memory caches.
- Register contention
Accessing a heap-allocated array requires loading its address into a CPU
register. Accessing a stack-allocated array can be done with the stack
register, freeing other registers for use in calculations.
FE
Date: 1 Apr 2008 14:52:22
Message: <47f29276$1@news.povray.org>
You can't tell by looking at
   a = null;
how long it will take to execute that statement.
It depends entirely on how long the system has been running, how much
data is hanging off pointers in "a", and so on. I.e., you get the same
sort of stop-and-wait-for-GC that you get with mark-and-sweep.
This is usually people talking about things close to real time but not
critical enough to actually figure out how long it would take, like
games and such.
If "a" points to a parsed XML file read from a file specified by the
user, you don't know how long it'll take to collect it, as an example.
Date: 1 Apr 2008 18:37:28
Message: <47f2c737@news.povray.org>
>    a = null;
  By the same logic something like 'printf("Hello\n");' is nondeterministic
because I can't know how long it will take. It could take hours for all
I know.
  The subject was about deterministic object destruction, not deterministic
runtime.
Date: 1 Apr 2008 19:27:16
Message: <47f2d2e4$1@news.povray.org>
> runtime.
No, actually, my comment was
*I* was talking about the fact that people discussing real-time GC don't
like reference counting because you have to run an arbitrarily large
number of links to reclaim memory.
When it happens is deterministic. How long it takes is (while
deterministic) too complicated to calculate reliably.
