POV-Ray : Newsgroups : povray.off-topic : NearInfinity game demo Server Time
16 May 2026 23:06:41 EDT (-0400)
  NearInfinity game demo (Message 15 to 24 of 24)
Subject: Re: NearInfinity game demo
Date: 26 Mar 2008 14:05:21
Message: <47ea9e71@news.povray.org>
> OK, let me rephrase: "Especially since most hardware manufacturers still
> don't support Linux yet." That better?
http://www.nvidia.com/object/unix.html
(Very crappy) edited image attached. Don't kill me.
Bah why do I bother saying "don't kill me". I know you will anyway.
Download 'anything.png' (73 KB)
Preview of image 'anything.png'
Date: 26 Mar 2008 14:07:23
Message: <47ea9eeb@news.povray.org>
Ahahaha. "I'm doing it wrong!"
Now with alpha channel deleted. I used it to temporarily save a mask,
forgot to remove it, made it look weird :)
Download 'anything.png' (62 KB)
Date: 26 Mar 2008 14:08:29
Message: <47ea9f2d$1@news.povray.org>
"Nicolas Alvarez" <nic### [at] gmailisthebestcom> wrote in message
news:47ea9e71@news.povray.org...
   Was that actually worth posting at all?
       ~Steve~
Date: 26 Mar 2008 14:10:32
Message: <47ea9fa8$1@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:47ea9f2d$1@news.povray.org...
       LOL! OK, you're forgiven.  ;)
         ~Steve~
Date: 26 Mar 2008 14:18:38
Message: <47eaa18e$1@news.povray.org>
We have already covered working 3D-on-Linux for Ati, Nvidia, Matrox and
Intel on this thread. Who else is there to blame?
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 26 Mar 2008 15:03:54
Message: <47eaac2a@news.povray.org>
On Wed, 26 Mar 2008 18:28:04 +0000, Orchid XP v7 wrote:
> Nicolas Alvarez wrote:
>> Orchid XP v7 escribió:
>>> (Especially since Linux doesn't really support 3D hardware
>>> acceleration yet...)
>> I think I'll let Warp answer that.
ATI, NVidia, Matrox so far.  Oh and Intel.
Take a look at the support for cards in XGL.  XGL requires HW
acceleration in order to work at all - software only won't cut it.
Jim
Date: 26 Mar 2008 16:54:53
Message: <47EAC649.7080705@hotmail.com>
stbenge wrote:
> Hello everyone,
> I made a game demo featuring a near-infinite landscape. I say
> "near-infinite", because computers as they stand now cannot produce a
> string of random numbers which do not repeat. But you can get close, so
> close in fact that I bet you will never see my demo repeat itself.
> Here's the file:
> http://www.caltel.com/~abenge/NearInfinity.zip
> And a screen shot:
> http://www.caltel.com/~abenge/NIscreen.jpg
> You can change many aspects of the program via "NI.ini", included in the
> zip.
> You will need DirectX 8.0 or higher and the Windows operating system to
> run this program.
It doesn't work on my win2000 machine. reinstalled DirectX 8.1 but still
no luck. I get the HGE splash screen followed by a notice that NI
generated errors and that I had to restart the program. NI.log does not
seem too informative:
HGE Started..
HGE version: 1.70
Date: 26.03.2008, 22:53:37
Application: NearInfinity 2008 Sam Benge
OS: Windows 5.0.2195
Memory: 1048032K total, 453348K free
D3D Driver: nv4_disp.dll
Description: NVIDIA GeForce FX 5200
Version: 6.14.10.9371
Mode: 640 x 480 x X8R8G8B8
Init done.
Date: 26 Mar 2008 19:34:06
Message: <47eaeb7e@news.povray.org>
Hmm, that log file is never very informative :(
What video mode are you running under? More specifically, what bit
depth? My program runs under 32 bit color, but I didn't consider making
it changeable since HGE seems to always detect the right mode. I can
think of one other problem which might be causing the error, but that
will also require a new release....
Sam
Date: 27 Mar 2008 03:28:45
Message: <47eb5abd$1@news.povray.org>
> Thanks! Is the collision detection too bouncy? I kind of like it that
> way, as it makes the game feel "softer".
No, I like it too, it gives a different feel to the game (more fun) rather
than if you just exploded or got damage when you hit into something.
> Thanks, I will read that. I tried to implement a lower limit to the FPS,
> but everything I did resulted in an exponential speed increase, hence my
> crappy patch in the config file. At least I'm learning to control the
> framerate without compromising functionality (ie. collision detection).
The key is to run your physics calculations (movement, collision detection,
etc) totally separately from the graphics.  You do your physics calculations
with fixed time intervals (eg 50 or 100 times per second, whatever is the
minimum needed), and just draw the graphics as often as you can.
> I thought all monitors were backward-compatible.
Yes, but 640x480 looks very poor on a 1920x1200 24" LCD ;-)  And very small
when it's in a window.
> What resolution would
> you suggest? 1280x880?
In my programs (when running full screen or switching to it) I usually start
by running in the same resolution that the desktop was in.  Then you can be
sure that is working, and always give the option to choose some other
resolutions.
> I think maybe I could get away with having a
> variable resolution, as it appears any speed bottleneck occurs when more
> pixels are drawn to the screen. A person could choose a lower res if a
> high one is too slow.
Yes, your game looks like it uses a very small amount of geometry as I
assume all the sprites as just drawn as two triangles.  So the limiting
factor will be the pixel throughput of the graphics card, then of course
higher resolution will mean lower frame rate.
> That's a good idea. It is possible to do this, and I could change the
> color at each corner of every sprite for a smoother look. Maybe I could
> do it with a perlin noise function, although the only one I found repeats
> rather quickly, hence my question in p.programming.
If I understand Perlin noise correctly, you can just scale it up and then
add more iterations to keep the same fine detail level?  This would increase
the repeat length.
Or just generate some number based on the x,y coordinate rounded to the
nearest (say) 1000 pixels, then use those values to interpolate the colour
for all other pixels.
Date: 27 Mar 2008 15:12:04
Message: <47EBFFB1.3010509@hotmail.com>
stbenge wrote:
>> still no luck. I get the HGE splash screen followed by a notice that
>> NI generated errors and that I had to restart the program. NI.log does
>> not seem too informative:
> depth?
1024*768*32 bit (first generation flat screen)
Your 'Lights Out' and 'Maze' do work here.
