POV-Ray : Newsgroups : povray.off-topic : Microsoft may have done something right... Server Time
17 May 2026 01:56:13 EDT (-0400)
  Microsoft may have done something right... (Message 31 to 40 of 44)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Microsoft may have done something right...
Date: 25 Mar 2008 15:25:00
Message: <web.47e95e9259c8691a773c9a3e0@news.povray.org>
>   So Haskell is really a two-paradigm language: Functional and modular?
The functions are defined inside of modules.  Modularity is a good thing
anywhere.
Date: 25 Mar 2008 19:04:21
Message: <47e99304@news.povray.org>
Fredrik Eriksson <fe79}--at--{yahoo}--dot--{com> wrote:
> On Tue, 25 Mar 2008 17:34:14 +0100, Nicolas Alvarez
> <nic### [at] gmailisthebestcom> wrote:
> > C++ STL vector template class has a specialization for 'bool' that uses
> > 1 bit per element too. That is, a vector<bool> takes 1 bit per element.
> Yes, but that specialisation is largely considered a mistake
  The alternative would be that there's no specialization, in which
case each element could take even 4 bytes (from which only 1 bit is
actually used).
  I don't see any problem in having an efficient boolean vector.
If it doesn't work with some STL algorithms, then it doesn't. In
the vast majority of cases there isn't any logical use for STL
algorithms for a bool vector anyways (why would you, for example,
try to sort a bool vector? It doesn't make any sense).
  Of course std::bitset should be used whenever possible. However,
it's not always possible. In that case std::vector<bool> is the
next best thing.
Date: 25 Mar 2008 19:15:15
Message: <47e99593@news.povray.org>
Orchid XP v7 <voi### [at] devnull> wrote:
> If you consider "modular" to be a programming paradigm then... yes, I
> guess.
  Yes, modular programming is usually considered a programming paradigm
of its own (a type of precursor of object-oriented programming).
  I think that the quintessential example of a modular programming
language is Modula-2: Its modules are more or less full-fledged classes
(public and private parts, member variables and functions, instanciation,
references to such instances...), except for what would make it an
object-oriented programming language: Inheritance.
  (Modula-3 added inheritance, making it an OOP language.)
> (Does Pascal count as "module" too?)
  Pascal is a programming language, not a module. :P
> Did I mention that Haskell also has "classes"? (Though they don't work
> quite the same as in OOP.)
  If you can inherit and have dynamic binding (or a messaging system,
ie. delegation) then it would more or less make it an OOP language,
else it's just a modular programming language.
Date: 26 Mar 2008 06:14:16
Message: <47ea3008$1@news.povray.org>
>> guess.
I thought that was structured programming?
I've heard legend of Modula-2. Never actually seen it though.
(Actually, I've heard legend of another functional language where
apparently modules *do* have inheritance... There are often debates
about whether Haskell should do this - with most people agreeing the
vast increase in complexity isn't worth it.)
Gah! The difference a few characters makes... :-S
[Obviously I meant "does Pascal count as modular?"]
Dynamic binding? Sure. That's the entire purpose.
Inheritance? Mmm, not really, no.
[In Java, a class *is* a type. In Haskell, a class is something a type
may or may not be a member of. For example, the "Show" class provides a
"show" method. Any type that is a member of the Show class can be
converted into a string by calling the show function. It is possible to
make it so that no type can be a member of class X without first being a
member of class Y - but that's not exactly inheritance.]
http://blog.orphi.me.uk/
Date: 26 Mar 2008 06:59:47
Message: <47ea3ab2@news.povray.org>
> >> guess.
  Structured programming is more related to principles related to the
control flow of the program, ie. related to control structures (such as
conditionals, switch-blocks and different types of loops). It's a kind
of subset of the more general procedural programming paradigm.
  I don't think the concept of "module" is part of the structured
programming paradigm. A modular programming language may follow the
principles of structured programming (and make its own additions), but
that doesn't mean it's the same in the other way. And I don't think
there's any requirement for a modular language to use structured programming
principles (in the same way as an OOP language doesn't necessarily have
to follow procedural programming principles).
  I have never understood why adding *optional* features, which you are
in no way forced to use, to something would make it "too complex".
  I don't know enough about Pascal to answer that question. (Is there
a "standard" Pascal language anyways? I have the impression that each
compiler company has created their own variant of Pascal, and that there's
no official standard. I may perfectly be wrong, of course.)
  That's a bit contradictory given that dynamic binding (or its
alternative, delegation) is inherently related to inheritance.
Date: 26 Mar 2008 07:30:15
Message: <47ea41d7$1@news.povray.org>
My take on it is that BASIC [the *original* language] was an
unstructured language - the entire program is basically a vast list of
mostly sequential commands. And then we have Pascal, which is a
structured programming language. It has user-defined data structures,
subroutines and local variables. Things are more "structured".
As to whether modularity is orthogonal or not... I hadn't really thought
about it.
Well, take multiple inheritance for example. If your language supports
multiple inheritance, it can't support using the "super" keyword,
because it could refer to several different classes. (With single
inheritance, it is obviously quite unambiguous.) So even if you never
ever actually use MI, if the language your using supports it, it stops
you from being able to have a super keyword to use. You'll have to refer
to superclasses some other way.
It's a minor increase in complexity, but it's an example of how even if
you don't use a particular feature, if it's available the language
design has to cope with it.
Well, there are many dialects of BASIC. [And I'm not talking about VB,
I'm talking about the *real*, unstructured BASIC.] Each one has its own
little quirks, but you can still make general statements about BASIC
overall.
Dynamic binding just means choosing between several possible method
implementation at runtime rather than compile time depending on the type
of a particular value. You don't actually need inheritance for that.
[For example, in Haskell the "+" function has several implementations -
for integers, doubles, ratios, and any user-defined types you care to
add. When you add two values, it needs to pick the correct one. Often
this can be done at compile-time, if the types are known. Otherwise it
must happen at runtime...]
Date: 26 Mar 2008 09:56:49
Message: <47ea6431@news.povray.org>
  The solution is rather simple: One of the base classes is the "super"
class, the rest aren't. (This can be differentiated with keywords when
inheriting, or even by the order in which the inheritance list is
specified: The first base class mentioned can be the "super" class.)
  Think of it as the rest of the base classes being interfaces with
support for member variables and function implementations.
Date: 26 Mar 2008 10:44:43
Message: <47ea6f6b@news.povray.org>
Structured programming is if/while/for and functions/methods/whatever
instead of goto.
Date: 26 Mar 2008 11:36:18
Message: <47ea7b82@news.povray.org>
It is. Note that it has been superceded, but at the time the term was
coined, it was quite a revolutionary idea.
No.  :-)  One of the fundamental features of modules is information
hiding. You can't hide the types in a Pascal program.  At least, not
standard pascal.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 26 Mar 2008 11:40:22
Message: <47ea7c76$1@news.povray.org>
Because you still have to learn these features to understand code that
someone else has written.
Using the C preprocessor is optional in C. Yet if you don't know how it
works, you're unable to read 99.44% of all the C code out there.
There's an official standard, but it was too weak (no modularity, no way
of (for example) opening a named file, etc) to be useful for work on
desktop type machines. Worked great on mainframes where you had the JCL
set up to do stuff like open the files for you.
Not really. Javascript has no inheritance but has dynamic binding.
Anything with "duck typing" could be said to have dynamic binding
without requiring inheritance.
