POV-Ray : Newsgroups : povray.off-topic : Printer issue Server Time
2 Mar 2026 05:56:20 EST (-0500)
  Printer issue (Message 1 to 9 of 9)
Subject: Printer issue
Date: 12 Mar 2008 11:19:33
Message: <47d80295$1@news.povray.org>
I bought 5 identical PCs and set them up. Now 4 of them can't print
properly. 20% of the time they print, 80% of the time it says "an error
occurred sending the page to the printer". Very helpful.
(Oh yeah, and the 5th PC? That prints perfectly, 100% of the time.)
Looking in the event log, I see that a bunch of services start up the
first time you try to print anything. (E.g., "application layer
gateway".) I also notice an error in the event log saying that
"ntdll.dll failed to load". Anybody have any clue what that means?
Indeed, anybody have any clue at all?
I just completely reinstalled Windoze on one of the PCs, and still it
won't print properly. Go figure...
http://blog.orphi.me.uk/
Subject: Re: Printer issue
Date: 12 Mar 2008 22:31:43
Message: <47d8a01f$1@news.povray.org>
Both google and msdn do. :-)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 13 Mar 2008 04:29:48
Message: <47d8f40c$1@news.povray.org>
Google just tells me that an error with this DLL "could mean anything".
That doesn't help me terribly...
Date: 13 Mar 2008 04:37:03
Message: <47d8f5bf@news.povray.org>
How is the printer configured?  ie when you set up the printer within
Windows, do you give it the IP address of the printer and print directly, or
do you use some print server?
We had this exact problem, and it turned out to be buggy print drivers
installed on the print server.  Installing a local copy of some unbuggy
drivers and printing direct to the printer (via IP address) fixed the
problem.
Date: 13 Mar 2008 04:59:01
Message: <47d8fae5@news.povray.org>
> directly, or do you use some print server?
We have a print server. You select the printer you want and it downloads
the drivers from the server and installs them, configures all the
settings, etc.
> problem.
Well, this print server has worked for the last 5 years. Why would it
suddenly not work for just 4 of the PCs?
Date: 13 Mar 2008 05:22:13
Message: <47d90055$1@news.povray.org>
> settings, etc.
Right.  First step is to download some drivers from the web and print
directly to the printer (via its IP address, you do this by choosing "local
printer" and then port as TCP/IP) and bypass the print server.
Once you know the result of that test, you can decide what to do next...
Date: 13 Mar 2008 07:24:40
Message: <47d91d08$1@news.povray.org>
Have you tried using 'Print Test Page' and then 'Troubleshoot'?
<run away run away>
Tom
Date: 13 Mar 2008 08:00:40
Message: <47d92578@news.povray.org>
Yes.
It asked me all the usual things - is the printer plugged in, switched
on, etc. Eventually it was unable to fix the issue.
Date: 13 Mar 2008 10:14:53
Message: <op.t7ynb2scc3xi7v@news.povray.org>
And lo on Thu, 13 Mar 2008 13:00:38 -0000, Invisible <voi### [at] devnull> did
spake, saying:
> Yes.
Ah but did it ask you *which* socket it was plugged into :-P
I'll echo Scott try bypassing the server and try the Generic/Text printer
drivers in XP.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
