POV-Ray : Newsgroups : povray.off-topic : A small project Server Time
2 Jul 2026 15:20:08 EDT (-0400)
  A small project (Message 21 to 23 of 23)
Subject: Re: A small project
Date: 21 Mar 2008 11:28:34
Message: <47e3e232$1@news.povray.org>
Invisible wrote:
> Right. And now how do I figure out how big the system tray is? (You
> realise it's resizable, right?)
I realize. I don't know the answer. Give it a try. :-)
> I find the documentation for Tcl/Tk to be especially difficult to
> follow. For example, I *still* can't figure out the correct way to
> specify a font name. The page that's meant to tell you just rambles on
> about a bunch of C functions... WTF?
Fonts are a mess in every language. And it depends on the underlying
screen driver. On Windows, you just give the font name and size.
set font1 {courier 8}
set font2 {courier 10 bold}
set font3 {"Lechter Normal" 10 bold}
> Right. So when the server runs out of disk space, my Tcl script
> unceremoniously halts, and rather than the interpretter shutting down,
> it just *sits* there.
Is that because you're not checking the return result from writing?
> And since it's a background task, I have *no way*
> of discovering what the hell went wrong, and no way of shutting it down
> other than forcably killing the interpretter. Cool. Is that what the
> spec says?
Why would you not have a way of shutting it down. You have to *code* a
way of shutting it down, sure. Or use tclsvc to make it a real windows
service and then use all the normal windows service management stuff
(e.g., "net start" and "net stop") to turn it on and off.
What's the code that runs out of disk space and hangs the interpreter?
If it's a bug, I'll report it for you.
> Frobbing bgerror is just painful. catch looks more useful...
Both do the same basic job. Granted, by the time you get to bgerror,
it's not going to be very easy to correct the problem, but at least you
can log it, start over, look at globals to figure out what happened,
write a stack trace, etc.  You really kind of need both if you're using
the event loop.
> No, not really. Just recursing over some directories. Memory usage
> starts at about 2 MB, and grows linearly by about 50 KB every second.
> Usually the script finishes before it actually reaches more than 8 MB,
> but on occasion it doesn't.
If you're recursing over directories and saving the information
somewhere, I wouldn't be at all surprised you're using 8MB. Did it ever
actually run out of memory?
>> Granted, there is occasionally a leak in Tcl's memory handling
>> described in the bug tracker. But it's rare, and they're all high
>> priority to get fixed because people build real systems with Tcl.
> How would I know about that?
You look at the Tcl bug tracker?
> I downloaded Freewrap a few years back and
> have been using it ever since. Still on the same version number.
Get the new one. It still works.
> So... you're saying that my particular Tcl interpretter just has a
> memory bug in it?
If I recall correctly, there was one version of Tcl that had a memory
leak in it, fixed shortly after it was reported. I don't think it was a
general memory leak. I'm more suspecting that you *think* you have a
memory leak that you really don't.
Tcl's actually amazingly solid. People reporting bugs of that nature in
Tcl is like reporting bugs in your compiler - chances are *much* better
that the code you've written is wrong than that your code is right and
the compiler is wrong.
But show me the code, and I'll see if I can easily spot where you're not
freeing something you should be.
> The whole "hey, let's not bother with datatypes and stuff, let's just
> store everything as flat strings and reparse them every time we need to
> touch something" concept simply *wreaks* of quick and dirty prototyping.
A - That's pretty much how most extensible languages work, due to the
nature of extensible languages.
B - Tcl doesn't store everything as flat strings and reparse. It just
makes it possible to look at it that way. If you're still on a version
that works that way, you need to upgrade, because it's been like 8 or 10
years since Tcl did that.
C - Yes, it's annoying that there aren't syntax checks before you run
the code. It comes with the extensible nature of the language. Don't
write code that you put into production without ever having run it first.
> No sane person would design production-grade software this way, with no
> safety checks or anything.
It has safety checks.  It just checks in different places.  It's no less
sane than using a language that doesn't have array bounds checking.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 21 Mar 2008 11:41:25
Message: <47e3e535$1@news.povray.org>
Well, it's famously hard to check *everything* that could possibly go
wrong at every possible moment in your program. The code is unreadable
enough already... :-(
>> And since it's a background task, I have *no way* of discovering what
>> the hell went wrong, and no way of shutting it down other than
>> forcably killing the interpretter. Cool. Is that what the spec says?
It's a backup script. It backed up so much data that there was no furter
space available. Not really Tcl's fault, but it didn't handle it
terribly gracefully.
> the event loop.
...event...loop...?
Doesn't actually store the data anywhere. It's just trying to delete a
folder recursively. (I discovered that if you don't manually walk the
thing yourself, it gives up at the first file it hits that can't be
deleted. I want it to delete EVERYTHING that can be deleted.)
>> I downloaded Freewrap a few years back and have been using it ever
IIRC, I tried to use a newer version of Freewrap and a few scripts
broke. It's probably not hard to fix, but I haven't got round to it yet.
Well, I was under the impression that local variables get automatically
freed when you exit a procedure - maybe I was wrong?
>> to touch something" concept simply *wreaks* of quick and dirty
>> prototyping.
Define "extensible language".
>> no safety checks or anything.
I would question the sanity of that too. ;-)
http://blog.orphi.me.uk/
Date: 21 Mar 2008 12:33:35
Message: <47e3f16f$1@news.povray.org>
If you're going to fill up the disk, you need to check you're not going
to fill up the disk, or you need to catch all errors, or you need to
accept you're going to bomb out. I don't see any way around that.
Tcl handles it fine. You didn't write code to account for filling up the
disk, so you probably got stuck in a loop trying to write data and
having it fail, is my guess.
> ....event...loop...?
Yeah, OK. You know, that thing you use with Tk, vwait, fileevent, that
stuff?
Not knowing what the event loop is in Tcl is like using C and saying
"Wait, function? Header file? What's that?"
Obviously, if you're recursing, you're at least storing the list of
entries in each directory from where you are to where you started. 8M
doesn't seem like a lot, depending on the directories.
Yes, they do. But the memory gets reused rather than being freed, so the
process will grow to the biggest size you allocate at one time.
One where you can change the syntax of the language, basically. FORTH,
LISP, Tcl, etc.
When you can redefine the meaning of "if" or "proc" at runtime, it's
fairly difficult to have a code checker that will check you're passing
the right types.
On the gripping hand, there *are* code checkers for Tcl, if that's your
thing.
Me too. I'd much rather have runtime checks than no runtime checks.
