POV-Ray : Newsgroups : povray.off-topic : Adventures with digital painting Server Time
1 Jun 2026 00:47:21 EDT (-0400)
  Adventures with digital painting (Message 71 to 80 of 197)
Subject: Re: Adventures with digital painting
Date: 8 Mar 2008 21:09:36
Message: <47d346e0$1@news.povray.org>
On Sat, 08 Mar 2008 14:51:02 -0800, Darren New wrote:
> Jim Henderson wrote:
>> On Sat, 08 Mar 2008 11:54:07 -0800, Darren New wrote:
>>> Here's a contest. Given the directory /tmp/stuff, delete all the files
>>> in that directory that end with ".tmp".
>> cd /tmp/stuff; find -type f | grep tmp$ | awk '{system("rm \"" $0
> Great. Now try it on a directory with the following names in it:
> -rf\n.tmp  (where the \n means newline, of course) <.tmp
> .xyz.tmp
> hip"hop.tmp
> hop'hip.tmp
> this.tmp;that.tmp
> this\bthat.tmp   (where the \b means bell) this\bthat.tmp   (where the
> \b is two characters, backslash and b)
> Two for zero... ;-)
I *think* if I were to do a single quote rather than a double, that would
solve most of those problems.  Maybe not the one with the single tick in
it, but a gsub for a pattern of special characters would do it.
But of course, I try not to name files with special characters - not
always successfully (occasionally torrents that I pull down have names
that are stupidly in violation of all standards for file naming).
But if I wanted it to work all the time, I'd write it in C and be done
with it - then the shell doesn't come into play. :-)
> (I work with big directories, and big files. Often I'll have a program
> that runs 3 hours, then takes half an hour to delete its input files. Or
> individual files that take 2 minutes of disk I/O to delete. Or empty
> directories that take several minutes to delete because they used to
> have six or seven million files in em.  And of course, the machine
> becomes completely unusable during any sort of operation like that.)
I occasionally do things like this myself - that's the reason I didn't
try to pass all the files on the command-line to a single rm command.
BTDTGTTS. :-)
Jim
Date: 8 Mar 2008 21:10:17
Message: <47d34709$1@news.povray.org>
On Sat, 08 Mar 2008 17:44:45 -0500, Warp wrote:
>   Why does it need to be so complicated?
>   find /tmp/stuff -name "*.tmp" -exec rm {} \;
Because there's a million ways to do it, and I haven't memorised all the
options for the find command.
In the time that it would take me to look up the options for find, I've
written the command-line out.
Jim
Date: 8 Mar 2008 21:12:09
Message: <47d34779$1@news.povray.org>
Can filenames have null characters on them? :)
Date: 8 Mar 2008 22:04:09
Message: <47d353a9$1@news.povray.org>
Orchid XP v7 wrote:
> Chambers wrote:
>> So what you're really saying, is that we need a modern implementation
>> of traditional Unix style tools, distributed as a package.  It
>> wouldn't need a ton of that backwards-compatibility stuff, because all
>> of the included tools are fresh implementations that we know work
>> together.
> What I'm saying is that "Unix" isn't a single coherant design. It's
> 50,000 random people all doing their own seperate thing, and expecting
> the result to actually function. Which, almost unbelievably, it does.
> But *damn* is it messy...
When you're writing a single, simple tool, with well defined inputs and
outputs, it's much easier to make it work *no matter what*.  When each
tool is maintained by a separate group of people, they may not share the
same design ideology, but they're much more likely to operate correctly
under unexpected circumstances.
So the fact that it works as often as it does shouldn't really surprise
anyone.
...Ben Chambers
www.pacificwebguy.com
Date: 8 Mar 2008 23:06:56
Message: <47d36260$1@news.povray.org>
A null character can be represented as a value, so yes.
Jim
Date: 9 Mar 2008 03:17:01
Message: <47d39cfd$1@news.povray.org>
Darren New wrote:
> % cat a b c >d
> Can't create d: permission denied
> % sudo !!
> Of course, the real line was much longer, so a simple "su" meant
> retyping the line (or using copy-and-paste to retype it for you) instead
> of just !! or up-arrow. :-)
<up arrow><home>su -c <enter>
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 9 Mar 2008 04:55:23
Message: <47d3b40b@news.povray.org>
  But now you know. The -exec option of find is actually quite useful.
Learn to use your tools. :)
Date: 9 Mar 2008 11:37:27
Message: <47d41247$1@news.povray.org>
> Darren New wrote:
>> % cat a b c >d
>> % sudo !!
>> instead of just !! or up-arrow. :-)
On some ssh sessions, and on MSYS bash shell, pressing home or end keys
types a ~ symbol instead of moving the cursor. Probably something I have
to configure...
Date: 9 Mar 2008 15:25:27
Message: <47d447b7@news.povray.org>
>> the options for the find command.
Yes, now I know - and I never would claim to "know it all" (been burned
too many times with things I do know more than the average person about -
and then had something pointed out I didn't know <g>).
So I do appreciate you teaching me that one.  New weapon for the
arsenal. :-)
Jim
Date: 10 Mar 2008 04:20:23
Message: <47d4fd56@news.povray.org>
> to configure...
  ctlr-a to get to the beginning of the line, ctrl-e to get to the end.
(ctrl-u to erase the entire line is a good shortcut to know too. ctrl-l
clears the console (in interactive full-console programs it usually
refreshes the console).)
