POV-Ray : Newsgroups : povray.off-topic : Adventures with digital painting Server Time
25 Jun 2026 21:55:30 EDT (-0400)
  Adventures with digital painting (Message 48 to 57 of 197)
Subject: Re: Adventures with digital painting
Date: 8 Mar 2008 13:57:16
Message: <47d2e18c@news.povray.org>
Nicolas Alvarez <nic### [at] gmailisthebestcom> wrote:
> >   In a graphical user interface it's more difficult to make them
> > interoperate, which is probably one reason why they usually don't.
> And also one reason why command-line tools are better for many things.
  True, although I have to admit that sometimes a graphical user interface
just makes some things easier, faster and more practical (although not so
many things as many people seem to believe.)
> (image editing probably not one of them)
  Basically anything involving heavy amounts of multimedia.
  (Playing video/music files may be a borderline case, though. For example
mplayer is a superb command-line media player, and mencoder is a good
command-line tool for converting videos and a good "ripping" tool.)
Date: 8 Mar 2008 14:15:58
Message: <47d2e5ee@news.povray.org>
> I love the Unix philosophy of making specific, lightweight tools that
> interoperate, rather than gargantuan monolithic beasts that do
> everything rather poorly.
See, now, personally I hate that. It annoys the hell out of me that the
Unix way is to use 50,000 tiny tools with all have far too many
backwards compatibility modes, bugs and "features".
["This makes it read from a file. Unless the file is named '-', in which
case it reads from stdin." OK, so how do I make it read from a file
that's actually named '-' then? And other surprising ad-hoc behaviours...]
But then, I guess that's just my opinion.
http://blog.orphi.me.uk/
Date: 8 Mar 2008 14:18:55
Message: <47d2e69f$1@news.povray.org>
Date: 8 Mar 2008 14:20:57
Message: <47d2e719$1@news.povray.org>
>> which case it reads from stdin." OK, so how do I make it read from a
>> file that's actually named '-' then? And other surprising ad-hoc
>> behaviours...]
OK. But it now means that if you write a script that does this, you need
to explicitly check whether the file you're going to process just
happens to be called "-" and manually escape it if it is. And just
think, if you didn't realise that, your script might be used for *years*
before somebody tries to use it in that specific way and makes it crash
spectacularly.
Urg. Anyways...
Date: 8 Mar 2008 14:24:42
Message: <47d2e7fa$1@news.povray.org>
>>> behaviours...]
> spectacularly.
1. If the file is called -, you're calling for trouble anyway.
2. Whoever passes a filename to your script should be using the ./- thing.
Date: 8 Mar 2008 14:29:58
Message: <47d2e936@news.povray.org>
  He was talking about the unix philosophy, not how this philosophy has
been implemented in some environments.
Date: 8 Mar 2008 14:50:20
Message: <47d2edfb@news.povray.org>
  Many shellscripts break with file names with spaces in them. This is
because surprisingly few unix geeks know that in shell scripts you have
to use "$@" to refer to all the command-line arguments, not $*.
Date: 8 Mar 2008 14:54:06
Message: <47d2eede$1@news.povray.org>
Actually, it's worse. There are surprisingly few utilities that don't
break on *any* possible file name.
Here's a contest. Given the directory /tmp/stuff, delete all the files
in that directory that end with ".tmp".
Let's see how many iterations it takes to get actually right.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 8 Mar 2008 14:59:54
Message: <47d2f03a@news.povray.org>
Then I guess rm /tmp/stuff/*.tmp isn't good enough? :)
Date: 8 Mar 2008 15:10:42
Message: <47d2f2c2$1@news.povray.org>
That doesn't even work if there *aren't* funky characters in the file name.
