POV-Ray : Newsgroups : povray.off-topic : Adventures with digital painting Server Time
4 Jul 2026 06:55:23 EDT (-0400)
  Adventures with digital painting (Message 158 to 167 of 197)
Subject: Re: Adventures with digital painting
Date: 12 Mar 2008 22:09:00
Message: <47d89acc$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> outint'endian = little;
>   Exactly which language is this?
Ada.  I am pretty sure it supports this.
> And have you actually corroborated by
> examining the resulting machine code that it indeed does as you say?
No. Never needed to. It's not the sort of thing you leave out of a
language you're programming flight control software in.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 12 Mar 2008 22:44:29
Message: <47d8a31d$1@news.povray.org>
It turns out the syntax is
(The ' indicates a compile-time value, in much the same sense that
sizeof() is a compile-time function in C. Ada lets you read dozens of
these and set others, like the address, volitility, atomicity, etc.)
It also turns out it's not *quite* so straightforward especially for .
But clearly it's better to let the compiler do it in cases where it can
than to code different routines with #ifdef in there.  Autoconf doesn't
make C portable - it rewrites your code to be non-portable to that
specific machine. :-)
Date: 13 Mar 2008 04:27:07
Message: <47d8f36b@news.povray.org>
>> Tcl encodes all data types as strings. I've been bitten by this
>> before... You write a Tcl script, it works fine, and then it
>> encounters some input that happens to contain a curly-bracket or a
>> dollar sign and Weird Crap happens...
> Only if you don't treat your lists as lists and your strings as strings.
> Otherwise, the rules are extremely straightforward.
>> [I'm sure there's a way to avoid this. It's just tricky, and it makes
>> me nervous.]
> I never get bitten by this. The only time this happens is when you pass
> a string to something that indexes into a list, without first splitting
> the string into lists appropriately.
I'm pretty sure I remember several occasions where if a certain
expression happened to return only 1 item, it tried to interpret the
item as a list. IOW, when the expression finds multiple matches,
everything works fine, but when it finds exactly 1 match it malfunctions
horribly. Took me ages to figure out why...
http://blog.orphi.me.uk/
Date: 13 Mar 2008 04:28:04
Message: <47d8f3a4$1@news.povray.org>
>> before... You write a Tcl script, it works fine, and then it encounters
>> some input that happens to contain a curly-bracket or a dollar sign and
> That's one of the potential pitfalls with most scripting languages.
Now you know why I dislike scripting languages in general. ;-)
Date: 13 Mar 2008 09:39:51
Message: <47d93cb7@news.povray.org>
> Autoconf doesn't make C portable
  It only makes the C program to compile and work in a multitude of
different architectures. Yeah, it doesn't make it portable, only portable.
Date: 13 Mar 2008 14:48:17
Message: <47d98501$1@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:47d6ca98@news.povray.org...
> Again, I tend to work with tens of thousands of files at once.
      Tens of THOUSANDS?? I'm not that shocked at what a programmer can do,
but fair play for handling that.
       ~Steve~
>   Darren New / San Diego, CA, USA (PST)
Date: 13 Mar 2008 16:32:38
Message: <47d99d76$1@news.povray.org>
Yeah. A couple weeks of raw audio, in 20-second chunks. Sadly, we throw
most of it away. :-)
Date: 13 Mar 2008 16:34:43
Message: <47d99df3$1@news.povray.org>
You would need to either return a list, or return one item. If you want
to return either, you need to return a list of one item. Otherwise, yes,
if you sometimes return a list, and sometimes return one item that looks
like a malformed list, then you're going to confuse yourself.
if {$count > 1} {return $a}
if {$count == 1} {return [list $singleton]}
# Wrong:
# if {$count == 1} {return $singleton}
Date: 13 Mar 2008 16:35:45
Message: <47d99e31@news.povray.org>
> Eero Ahonen wrote:
>> Well ok, after that you wrote about chopping the file, which
>> practically is what split does, but it should be able to work without
>> creating millions of (temp)files in the middle of the process.
> The problem is the size of the file. If I split it after the fact, I now
> have *two* files, the original and the new one. So now instead of half
> an hour of deleting directory entries, I have three hours of copying
> data, followed by five minutes of deleting one directory entry.
> Split doesn't split a file. It writes new files, each of which contain
> pieces of the previous file.
With dd you could copy any section of the file into a new one.
Date: 13 Mar 2008 16:48:30
Message: <47d9a12e$1@news.povray.org>
>> malfunctions horribly. Took me ages to figure out why...
If was more that I was processing a list, filtering out some of its
content, and if it turned out that the result was exactly 1 element the
script behaved in a different way than it did when the filtering yielded
several elements.
But anyway, why worry? Just stop using Tcl. ;-)
