POV-Ray : Newsgroups : povray.off-topic : Random vector through a hemisphere? Server Time
16 May 2026 22:57:36 EDT (-0400)
  Random vector through a hemisphere? (Message 1 to 10 of 15)
Subject: Random vector through a hemisphere?
Date: 17 Feb 2008 06:15:13
Message: <47b81741$1@news.povray.org>
I'm trying to create a random uniformly distributed vector through a
hemisphere positioned at the intersection point between ray and an
object. I can already create a random vector but how do I quickly/easily
rotate it based on the desired hemisphere orientation?
I use left-handed coordinate system: x is right, y is up, and z is forward.
Let's have a vector V which is random vector inside a hemisphere which
has a pole at 0,1,0 (just like the northern hemisphere of Earth). I want
to orient the vector inside a hemisphere which has a pole pointing at
vector N. How do I do this? I'd prefer something that can be done
without expensive trigonometric functions or complex transformations -
if possible.
Example:
V = (0.71, 0.71, 0) //The random vector in "northern hemishpere")
N = (-1,0,0) //The pole I want to orientate the random vectors to)
The result should be like this or any other vector that results the same
distribution:
Vnew = (-0.71, 0.71, 0)
Any ideas? I got one idea from comp.graphics.algorithms but it doesn't
seem to work properly:
Vnew = Vec (dot (V, S), dot (V, N), dot (V, T))
Where N = normal, V the initial random vector in northern hemisphere, S
and T are tangents of the normal orthogonal to each other.
Subject: Re: Random vector through a hemisphere?
Date: 17 Feb 2008 07:28:15
Message: <47b8285f@news.povray.org>
I found the answer in this thread. The equation in my first message
really seems to be incorrect:
http://news.povray.org/povray.programming/thread/%3Cweb.453fedef87fb35ab5dbe37df0@news.povray.org%3E/
Date: 17 Feb 2008 13:17:46
Message: <47b87a4a@news.povray.org>
Another way is to generate a random vector:
#local vResult=vrotate(x,<rand(Seed),rand(Seed),rand(Seed)>*360);
#if(vdot(vResult,vN)<0)
   #local vResult=-vResult;
Basically, generate a random vector, and if it's in the wrong
hemisphere, flip its direction.
John
Date: 18 Feb 2008 03:10:13
Message: <47b93d65$1@news.povray.org>
vResult is not uniformly distributed over the sphere with this approach
though...
Date: 18 Feb 2008 03:38:27
Message: <47b94403@news.povray.org>
> though...
I use this:
y = sqrt(rand(0..1))
theta = acos(y)
phi = 2*PI*rand(0..1)
x = sin(theta)*cos(phi)
z = sin(theta)*sin(phi)
What I don't get is the sqrt(rand()). Why sqrt? Why not just rnd()? Does
the sqrt give us the cosine distribution and should remove the need to
later scale by taking cosine of the angle between normal and the light ray?
Date: 18 Feb 2008 03:57:27
Message: <47b94877$1@news.povray.org>
> I use this:
> theta = acos(y)
> ray?
No, you are simply choosing a fixed Y position, which then defines a ring
around the sphere of possible points.  Then phi is used to choose a point at
random on this ring which gives you the final point.
The reason for using sqrt for y is because you want points equally
distributed over the surface of the sphere, not between y=0 to 1.  You can
visualise this by drawing a straight line alongside a circle.  If you
distribute points evenly on the line, then trace them across to the circle,
they won't be distributed evenly on the circle.  The sqrt fixes that.
Date: 18 Feb 2008 05:12:33
Message: <47b95a11@news.povray.org>
>> theta = acos(y)
Hmm. Ok. I think I got it. So without sqrt() we get too few rays going
through the top part? A few more questions.
1. Is this equally good as the above - at least it looks to be. And a
bit faster.
    double y = sqrt((double) rand()/RAND_MAX);
    double phi = 2*M_PI* (double)rand()/RAND_MAX;
    double x = sqrt(1-y*y)*cos(phi);
    double z = sqrt(1-y*y)*sin(phi);
What is the proper way to actually test the uniformity?
2. I read about "cosine weighted distribution" which should remove the
need to scale with cosine term. This sounds ideal solution. But
according tho this:
http://www.cs.kuleuven.be/~phil/GI/TotalCompendium.pdf
"Generating points uniformly on the disk (see 19), and then projecting
them on the hemisphere, also gives a cosine-weighted distribution of
points on the hemisphere."
I also tried that:
    do{
        x = (double) 2.0*rand()/RAND_MAX -1.0;
        z = (double) 2.0*rand()/RAND_MAX-1.0;
    while(x*x+z*z > 1.0);
    y = sqrt(1.0-(x*x+z*z));
And the results are very close to the 2 other methods.
This is what I read from comp.graphics.algorithms:
"One other way to reduce variance in this situation is to shoot rays
with a cosine-weighted distribution. Generate points distributed
uniformly on the unit disk, then project up to the unit
hemisphere. Each point will define a ray drawn from the proper
distribution. Then, at least for the indirect lighting, you don't need
to include the cosine explicitly at all. But that's not the real win:
the win is that each sample actually contains more information about
the mean value, so variance will be less with the same number of rays."
So what is the truth here? Do I need to account the angle of the ray or
not?
Date: 18 Feb 2008 05:15:35
Message: <47b95ac7$1@news.povray.org>
> I also tried that:
>     do{
And this is also the fastest algorithm of the tree.
Date: 18 Feb 2008 05:34:11
Message: <47b95f23$1@news.povray.org>
> bit faster.
Looks ok to me.
Either mathematically proving it, or write a test program that measures the
density of points over the surface.
> I also tried that:
>    do{
This result is different to the above and not spread uniformly over the
surface of the sphere (it is uniform only in the xz plane).
Date: 18 Feb 2008 05:49:58
Message: <47b962d6$1@news.povray.org>
> Or:
>>    do{
Ok, that makes me wonder, because:
1. The 2 methods above produce 100% identical images. It was a scene of
one light emitting sphere, ground and 3 diffusing spheres of different
colors. (I did use the cosine ratio relative to the angle of light
falling on surface.) I can post the images if needed. The only
difference is that the second method is faster - with a great margin.
2. If the distribution is not identical by the 2 methods, why are the
images still 100% identical?
