POV-Ray : Newsgroups : povray.off-topic : And today, C# Server Time
1 Jul 2026 15:03:45 EDT (-0400)
  And today, C# (Message 81 to 82 of 82)
Subject: Re: And today, C#
Date: 21 Feb 2008 05:17:06
Message: <47bd4fa2@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> > Since having to access all member variables indirectly would be a
> > completely useless overhead in non-diamond-inheritance situations, this
> > is not done by default.
> It sort of sounds like this would be just the thing for a runtime with
> JIT to deal with, wouldn't it?
  And then you lose the advantage of shared libraries because each library
would have to be JIT-compiled for each program which uses it. Which was
the whole point.
Date: 21 Feb 2008 11:26:04
Message: <47bda61c$1@news.povray.org>
> the whole point.
Well, I think JIT-compiled code is easier to compile than C#, for
example. But yeah, the actual executable bytes would be different for
each process running, or at least each program, if that's what you're
trying to avoid.
I suppose you could also have two copies of the code in each library,
one with and one without. Doubles the size somewhat of any routine that
is affected by that. Select the right set of routines when you start up
the program, or when you link the child class, or some such? I'm not
sure when you'd pick in this case.
     On what day did God create the body thetans?
