POV-Ray : Newsgroups : povray.off-topic : The Daily WTF [again] Server Time
11 Jun 2026 13:24:44 EDT (-0400)
  The Daily WTF [again] (Message 321 to 330 of 381)
Subject: Re: The Daily WTF [again]
Date: 14 Feb 2008 06:25:41
Message: <47b42535$1@news.povray.org>
Invisible wrote:
> Bill Pragnell wrote:
>> I see a lot of people using laptops, and hardly any of them use
>> tapping the pad as a mouse click, preferring to use the buttons (often
>> with their other hand!). I find this tedious and slow.
> Well, you can't type with one hand anyway, so you might as well use both
> to work the glide pad.
True, but if you're using keyboard shortcuts a lot then you *can* use
one hand (say, moving blocks of text or code around in an editor
window), and then a tap-click is much more convenient.
> As for the scroll pads... now if there was some kind of divider between
> the part of the pad that scrolls things and the part that moves the
> mouse, that would be fine. (Indeed, having a vertical strip of pad would
> probably be easier than a scroll wheel - it's bigger after all.) But
> with no dividing line, it's frustratingly hard to make the thing do what
> you actually want.
My HP windoze laptop has exactly that - a thin strip on the right edge
of the touchpad that does the job of a scroll wheel. It's just so
frustrating, when switching from the Mac to the PC, expecting the (to
me) wonderful, convenient navigation and having to fanny around with
scrollbar buttons or switch to using the keyboard instead... :)
Date: 14 Feb 2008 06:26:32
Message: <47b42568$1@news.povray.org>
> Well, unless you invite the devs to come camp at your place until the next
> time it crashes, and don't let them take any data away with them.
Well yes, but given that half of the dev team is in a different country, and
the other half is in a different continent...
And still, I don't think my superiors would want me to show them what we're
doing, especially since it's one of two industry standard packages - so I
guess they are working with our competitors too...
Date: 14 Feb 2008 09:17:22
Message: <47b44d72$1@news.povray.org>
> Ah-hah! Another thing I really hate... Makes it easy to move the pointer
> half way across the screen, but almost impossible to aim at a 1-pixel dot.
You got that backwards... The non-linear movement is what LETS you aim
at a 1-pixel dot and ALSO move the pointer from one corner of the screen
to the other.
Move twice as fast, cursor moves three times as fast. If you move
slowly, you can surely get 1px precision.
Date: 14 Feb 2008 09:18:11
Message: <47b44da3$1@news.povray.org>
> If you're used to linear pointer speeds
...you can configure the Mac to have linear speed.
Date: 14 Feb 2008 09:23:24
Message: <47b44edc@news.povray.org>
>> pointer half way across the screen, but almost impossible to aim at a
>> 1-pixel dot.
> to the other.
Not IME. Generally it means that no matter how you move your hand, the
pointer shoots off so fast it smashes into the corner of the screen.
Unless you move your finger so slowly it sticks to the pad and pulls all
the skin out from under your nails...
http://blog.orphi.me.uk/
Date: 14 Feb 2008 09:25:04
Message: <47b44f40@news.povray.org>
Yes. The default is the nonlinear though, and by the time I got around
to hunting out the settings I'd got used to it, and preferred it.
Date: 14 Feb 2008 09:46:28
Message: <47b45444@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:47b210da$1@news.povray.org...
> Orchid XP v7 wrote:
> > Darren New wrote:
> >>> Only hyper-nerds are going to be able to get anything remotely useful
> >>> out of a dump file. To everybody else, it's just wasted disk space.
> >> Generally, the source code is sufficient.
> > Cool. Let me just contact the makers of every device driver I'm running
> > and we can see where th... no, wait, that won't work. ;-)
> Or send them the core file.
I had IBM once insist that I attach a debugger to the application that was
crashing, so they could get detailed stack anaylsis.
Let's see, attach a debugger to my production SQL Server, just so I can
track a problem with one ODBC driver. I think not.
Date: 14 Feb 2008 12:35:48
Message: <47b47bf4$1@news.povray.org>
On Thu, 14 Feb 2008 07:31:18 +0000, Orchid XP v7 wrote:
>>> ...which is what I meant. If HP gets to pick what hardware goes in,
>>> they can pick exactly the hardware that works with whichever OS
>>> they're preloading.
>> Sure.  Now, how surprised are you going to be when I tell you that my
>> HP didn't come with openSUSE installed, but with Vista installed, and I
>> installed openSUSE with no problems?
> That's a little different, yeah.
>> (Only thing not working is
>> wireless, and I don't care about that - but I understand there are
>> drivers for Linux for it, just can't be bothered).
> One of the prime areas that doesn't work, so I'm told. (I don't use such
> technology myself, so...)
Um, my wife's wireless card works fine, the one in my t42p works fine,
and the one in my kids' machine (running from a liveCD) works fine.  In
fact, the t42p uses an atheros chipset, and the driver is a reverse-
engineered driver, and it works pretty well (just don't ask about the
access point at the office - that thing is a piece of crap.  The one here
at home works fine).
>> This thing's got an
>> Nvidia chipset ethernet card in it, not exactly a common type of
>> ethernet card, at least not in my experience.
> My motherboard has the nVidia nForce IV chipset. For quite a while I had
> trouble with various distros not recognising either the Ethernet ports
> or the SATA ports. (Guess where my HD is...) Makes installing the OS
> interesting when it can't find your HD. (Also, the early nForce driver
> would enumerate the HDs in reverse order, which is damn confusing...)
Oh, yes, and this HP uses a SATA drive as well.
>>> :-|   <== not shocked face.
>> Given that you're on v7, I'm not surprised. :-)
> Well, so many applications won't uninstall cleanly. :-S
One of the *major* problems I have with Windows.
>>> Like I said, Linux has now become pretty easy to use once it's set up
>>> right. I find it's still tricky to set it up correctly sometimes, but
>>> once it works it's really not much different to Windoze. [Except no
>>> random OS crashes.]
>> It can be, particularly with laptops.  As I said, 5 years ago, it was
>> fairly painful on laptops (in particular), but today the support is
>> very good.
> Something like 8 years ago, I was manually editing the X11 configuration
> file to tell it what DAC chip my graphics card has in it... o_O
That was 8 years ago.  This is now - with OpenSUSE, you use sax2 to do
the configuration.  ATI cards can be a little flakey to get working, but
AMD has opened the specs so real OSS drivers are on the way.  The Nvidia
graphics drivers are quite good, even though they're binary-only (that's
also what's in the HP for video).
Jim
Date: 14 Feb 2008 12:36:57
Message: <47b47c39@news.povray.org>
On Thu, 14 Feb 2008 08:27:59 +0200, Nekar Xenos wrote:
> "Jim Henderson" <nos### [at] nospamcom> wrote in message
> news:47b37404@news.povray.org...
>> On Wed, 13 Feb 2008 21:56:48 +0000, Orchid XP v7 wrote:
>>> I tried to go down that road. I found too many things I couldn't do
>>> without Windoze. Sadly...
>> Like what?  I do have a couple apps that I need Windows for, and I have
>> a VMware machine for those circumstances.  Like the odd MS Excel XML
>> document that won't open in OpenOffice (had one a couple days ago like
>> that).  Usually they open fine, but every once in a while the converter
>> just seizes up.
> I'm considering Ubuntu but I need to know if there is something free
> available like CorelDraw or Illustrator. I need to be able to export
> vectors to pdf and fonts and I like all the advanced capabillities of
> Corel and Illustrator.
I use Inkscape for that kind of work - the latest version is pretty
good.  It ain't Illustrator (which I have running in a VM).
Jim
Date: 14 Feb 2008 12:38:16
Message: <47b47c88@news.povray.org>
On Thu, 14 Feb 2008 02:22:44 -0500, nemesis wrote:
> povray (paths to prism)
I do wish it did a better job with fonts.  I'm always trying to remember
how I got it to work "the last time".  It's something about having to
convert the object to curves, IIRC.
I also have odd problems with it coming up with "nan" values for some of
the points.
But generally, I like that feature a lot.
Jim
