POV-Ray : Newsgroups : povray.off-topic : The Daily WTF [again] Server Time
14 Jun 2026 17:42:35 EDT (-0400)
  The Daily WTF [again] (Message 102 to 111 of 381)
Subject: Re: The Daily WTF [again]
Date: 12 Feb 2008 13:25:28
Message: <47b1e498$1@news.povray.org>
Invisible wrote:
> Personally, I don't think so. People have created products like
> OpenOffice and KOffice and so forth, and they work. Reliably.
Yet, funny enough, when I boot Linux, it screams "FAT support is ALPHA!"
  Depends on your priorities. I haven't ever had Word actually crash on
me, either.
> Interesing you should say that. You're aware of course that the fist
> Amiga was a 16-bit machine, and the later ones were 32-bit?
If you're going to go along that line, the first Windows machine was
8-bit, and now they're up to 64-bit. :-) The first Amiga was a 32-bit
machine running on a 16-bit bus.
> And - most importantly - you can take an application written back when
> we only had 6 bits per pixel, and run it on a screen operating at 8 bits
> per pixel. And it can share the screen with other applications and
> change parts of the colour table and so on and so forth, and WORK.
Yeah. Better than X-Windows used to be at the same time.
> [Assuming it does all this through the OS. The Big Problem the Amiga had
> is that since the hardware is "always" the same, a lot of software
> bypasses the OS. Obviously this breaks horribly when the hardware
> changes...]
Yep. On the other hand, the original Amiga books described how to frob
the hardware.
Note that Windows supports DOS programs that bypass the OS in exactly
the same way, and it WORKS.
> So Windows is designed to do a bunch of unecessary stuff in the
> background by default. I consider this a design flaw. What *useful*
> stuff does Windows do that AmigaDOS doesn't?
It depends who you are. Aren't you the one complaining about lack of USB
support in your NT machines?
> I mean, sure, it tells you what was happening at the exact instant the
> crash happened, but how do you find out what the actual problem is?
Same way you do for Linux errors. You google the text of the error
message, or search for it on MSDN.
> If there were anything I could do to find out, I'd do it. Unfortunately,
> there isn't.
There's lots you can do. You just don't know how. That's why they give
you the stack dump and such.  "Wow, if only I could read a core file,
I'd be able to tell which program is dumping core!" :-)
     On what day did God create the body thetans?
Date: 12 Feb 2008 13:36:23
Message: <47b1e727$1@news.povray.org>
Invisible wrote:
>> And you could use the same OS version with all these hardware
>> configurations?
> No - principly because much of the OS is in ROM. If it weren't, they'd
> have probably designed it so you can.
Probably not.
>> Virtual memory
> OK. The Amiga lacked the necessary hardware for that.
Unnecessary, obviously.
>> automatic updates
> Which is only necessary because the software wasn't done right in the
> first place.
Which is why only one version of Kickstart was ever released, yep yep.
>> protecting itself from nasty programs that try to access things they
>> shouldn't
> Hasn't UNIX been doing this for the last 40 years?
Lots of machines did. Amiga didn't. That's the point.  You didn't ask
for what MS did that nobody else did. You asked for what MS did that
Amiga didn't.
>> plug and play
> The hardware for that didn't exist at the time.
Yes it did. It was called SOTS (Slap On The Side). And the Amiga even
had a very clever mechanism for finding the drivers and initializing a
change of devices. Few vendors used it, tho.
> (Although AmigaDOS does
> support hot-swapping PCMCIA cards seemlessly.)
Not the A1000. Oh, wait, everything was perfect, so they couldn't have
added that.
>> hibernating
> Doesn't really require much OS support, does it?
It requires a tremendous amount to do it right.
>> encryption
> Would be fairly trivial to add.
You would be surprised.  It requires, amongst other things, protected
memory.
>> It is *not* normal behaviour, no matter what you might think of MS.
> Ah, I see. So all PCs that use M$ products do this, but it's not
> "normal"? Interesting definition. ;-)
But not all PCs that use MS products do this. Maybe all *yours* do, but
there are global businesses that run on Windows machines. I'm working
with one that actually abandoned Linux because it was too unreliable for
their purposes, and they have something like 30,000 computers running
24x7 scattered across the USA.
Date: 12 Feb 2008 13:37:56
Message: <47b1e784$1@news.povray.org>
Nicolas Alvarez wrote:
> DCOM launch, I can't disable this one,
That means you need it.
> Machine Debug Manager (C:\Program files\Common files\Microsoft
> Shared\VS7DEBUG\MDM.EXE), which I don't need since I use gdb, not Visual
> Studio debugger. Why is this even *installed*??
Because you asked it to be at one point. I think it's also a kernel
debugger, btw.
Date: 12 Feb 2008 13:39:31
Message: <47b1e7e3$1@news.povray.org>
Invisible wrote:
> So why bother making a quality product when people will buy crap?
Right.
> Of course, if there were actually some viable competition, people would
> realise that it is *not* "normal" for computer software to be buggy and
> unreliable, and people would switch.
What's not "viable" about Linux et al?
> Unfortunately, thanks to M$, this
> situation will never arise. If anybody starts making really good
> software, they'll just get bought...
And how does MS "buy" Linux?
Date: 12 Feb 2008 13:42:30
Message: <47b1e896$1@news.povray.org>
Invisible wrote:
> No - but selling cars which you know are going to crash at least once
> every 52 days... well, if a company tried to do that, they'd be shut
> down. However, for software it seems it's OK to sell a malfunctioning
> product.
I don't know what you're doing, but I've had production servers that ran
for years on Windows without a problem.
> Well, sure, if there were an alternative,
And why isn't Linux an alternative?  Why isn't Mac OS X an alternative?
> But what about, say, Word? There's quite a few other word processors out
> there - and in past times there were even more. And most of them were a
> lot more reliable than Word...
So why aren't they alternatives? MS isn't buying every word processor
company.
> Apple requires you to buy new hardware, so it's not purely a software
> decision. Linux is nice, but... well, it's fundamentally designed for
> UNIX nerds. So if you're not, good luck... Besides, I'm not convinced
> that the whole UNIX design is particularly coherant. (E.g., autoconf
> exists.)
Ding ding ding!  MS's product advantage is that it *can* be used by
naive users without a lot of expense.
Date: 12 Feb 2008 13:44:43
Message: <47b1e91b@news.povray.org>
hi, I can't help but notice your timezone is wrong.  This is 2008.  We
can write to NTFS partitions from LiveCDs, let alone simple FAT which
BTW is the standard format in thumbdrives, which work just fine as well.
Perhaps it's time to test a new Linux distribution?  From the 2000's?
Date: 12 Feb 2008 13:46:19
Message: <47b1e97b$1@news.povray.org>
Darren New wrote:
> Aren't you the one that's still using 10-year-old Word97?
yeah, he should update Word and you should install a decent modern Linux
distro.
Date: 12 Feb 2008 13:50:35
Message: <47b1ea7b$1@news.povray.org>
>> had is that since the hardware is "always" the same, a lot of software
>> changes...]
> the hardware.
The PC has the hardware necessary to do this with sane performance
levels. The Amiga didn't.
OK, so USB support goes into the list of useful things Windows can do
that AmigaDOS can't.
>> Unfortunately, there isn't.
Only hyper-nerds are going to be able to get anything remotely useful
out of a dump file. To everybody else, it's just wasted disk space.
http://blog.orphi.me.uk/
Date: 12 Feb 2008 13:57:37
Message: <47b1ec21@news.povray.org>
Linux is cheap but doesn't run Windows software or ports of major
popular commercial software like Photoshop, AutoCAD or World of Warcraft
without Wine and crashes.
Mac does run ports of most of them but is too expensive.
I'm still confident Linux will make more inroads in the desktop to the
point of Adobe feeling an urge to port its major apps.
> company.
The issue is that any word processor coming by should handle doc format
perfectly -- no matter how good it is at an open format like ODF --
because that's what people send you and expect from you.  Not an easy
task reverse enginneering an obscure, undocumented format like that.
I've never had any trouble opening any doc, xls or ppt from email
attachments friends mail me, but those are hardly office production
examples, so I can't be 100% sure.
OTOH, I've successfully opened older doc formats with OpenOffice while
Word was complaining the format was too old. :)
Date: 12 Feb 2008 13:58:58
Message: <47b1ec71@news.povray.org>
  I must have missed that. Where does it say it?
  I have never had any problems with FAT support. Maybe it's just me.
  Yes, Unix sucks big time. You should never use it. Demand your money
back immediately.
  I believe the list of DOS games which don't work anymore in current hardware
with the current Windows is larger than the list of DOS games which do.
  Yes, like once I tried to install some modem drivers into a WinXP
system, and at the end of the installation it said "failed to install
driver", nothing more, nothing less. Not a single hint about why it
failed.
  Now, try to google without an internet connection because you just
failed to install the driver necessary for the internet connection.
