POV-Ray : Newsgroups : povray.off-topic : A Haskell question... Server Time
17 May 2026 02:56:32 EDT (-0400)
  A Haskell question... (Message 11 to 16 of 16)
Subject: Re: A Haskell question...
Date: 4 Feb 2008 16:47:24
Message: <47a787ec$1@news.povray.org>
>>>   Doesn't Haskell support encapsulation?
>> Last time I checked, Java has the same limitation.
>   You said:
>>> struct Point {int x; int y;}
>>    data Point = Point {x, y :: Int}
>> Caution: Note that the names "x" and "y" must be unique within the
>> entire module. For this reason, you'd probably use longer names.
>   I understand to mean that the names 'x' and 'y' in your code above
> actually garbage the global namespace.
No - the namespace of the current module. And in Java it would be the
same - the names are local to this class file.
>   In the original C code they are local to 'Point' and do not affect
> anything outside it.
That's true...
http://blog.orphi.me.uk/
Date: 4 Feb 2008 16:50:11
Message: <47a78893@news.povray.org>
No. In Java it's local to the class, not to the file. You can have
multiple classes in a single source file, as long as only one of them is
public.
Date: 4 Feb 2008 16:53:35
Message: <47a7895f$1@news.povray.org>
> public.
Really? Interesting... I wasn't aware Java had non-public classes.
(Although I did wonder why the hell you have to write "public" at the
start of every class.)
Date: 4 Feb 2008 17:06:01
Message: <47a78c49$1@news.povray.org>
If you don't add 'public', the class is only accessible from other
classes on the same package.
Date: 4 Feb 2008 17:08:21
Message: <47a78cd5$1@news.povray.org>
Well, I didn't know that.
Interesting - once or twice a year that might be useful...
So much for university education, eh? Mind you, we learned Java from the
guy who tried to tell us that the maximum range of a "double" is "more
than the number of atoms in the universe". ;-)
Date: 5 Feb 2008 01:59:18
Message: <47a80946$1@news.povray.org>
Am Mon, 04 Feb 2008 15:28:46 +0000 schrieb Invisible:
> Each Java class has to go into a separate source code file. Each Haskell
Oh, then I have to throw away my Java compiler, because I usually write
all the classes I need for my (admittedly small) mobile phone projects
into one file. And it compiles! Bad compiler!
Ok, it's not good for reusability, I know that...
