POV-Ray : Newsgroups : povray.off-topic : Most incomprehensible films ever Server Time
9 Jun 2026 12:43:34 EDT (-0400)
  Most incomprehensible films ever (Message 269 to 278 of 278)
Subject: Re: Most incomprehensible films ever
Date: 16 Jan 2008 23:35:40
Message: <478edb1c@news.povray.org>
Phil Cook wrote:
> And lo on Wed, 16 Jan 2008 02:49:42 -0000, Chambers
> <ben### [at] pacificwebguycom> did spake, saying:
>> Air resistance might not apply, but manueverability does.  Applying a
>> force to different parts of the ship will stress different sections in
>> different ways.  That's a whole lot of differences there!
> Yes except what might be deemed 'travel' ships shouldn't be engaged in
> high stress producing maneuvers; those are reserved for the
> fighters/escorts/shuttles, which I agree need to be smaller.
>> Besides which, weight is out, but mass is in.  So smaller is still
>> better.
> No because a) although you need more oomph to get the ship
> moving/stopping that's a one-off cost
It's a four-off cost.
1) Cost of materials to build a larger room
2) More fuel needed to accelerate the additional mass
3) More fuel needed to decelerate (brake)
4) More fuel needed to carry the additional fuel for 2) and 3) above.
> and b) volume doesn't directly
> equal mass; if I increase the height of a room the only mass increase is
> in the walls and 'air'.
While volume != mass, as your rooms grow in volume, the mass needed to
enclose them also grows.  It's not a linear relationship, but it is there.
> Create a 7 unit cubic room with walls massing 1kg per square unit (all
> the same thickness). You're pumping it full of a gas that masses 0.1kg
> per cubic unit. So the mass of the initial room is 328.3kg. Now increase
> the height of the room by 1 unit and you get 361.2kg a ~10% increase in
> mass for a ~14% gain in volume. Make it all 8*8*8 and you get a ~49%
> volume increase for a ~32% mass increase.
But what is that 32% mass increase is not feasible?  What if an
additional 10% isn't feasible?  This is a government funded project,
remember, and their budget is spread over many things - not just the rec
room for the astronauts.
> Not that I'm saying 'Hey why not make all the rooms 300ft square' at
> some point you hit overkill, what I am saying is make the rooms the size
> they need to be for everyone to use them comfortably. So no ducking
And the point was that it's not reasonable to just make it as big as you
want; due to the (assumed) constraints, this is the ship that was
created.  A bit cramped, yes, but it gets the job done.
...Ben Chambers
www.pacificwebguy.com
Date: 17 Jan 2008 04:24:46
Message: <op.t42hqecoc3xi7v@news.povray.org>
And lo on Thu, 17 Jan 2008 04:35:39 -0000, Chambers
a
in
in
>>> better.
But like mass/volume the cost is not necessarily proportional to the vol
ume
Except by default the mass of the fuel has to be less then the mass that
fuel can move and as I've already shown mass and volume are not
proportionate.
>> and b) volume doesn't directly equal mass; if I increase the height o
f
>> a room the only mass increase is in the walls and 'air'.
to
No not really if you break it down to the simplest situation which is ju
st
the one room, simply expand the room and section it. Okay the external
walls may be thicker then the internal ones, but the principal stilll
holds.
l
g
>> increase the height of the room by 1 unit and you get 361.2kg a ~10%
>> increase in mass for a ~14% gain in volume. Make it all 8*8*8 and you
>> get a ~49% volume increase for a ~32% mass increase.
ec
No you're conflating feasible with cost, the budget that has been set is
simply someone's guess. If you look at almost any government project fin
al
cost is always greater then initial budget, yet amazingly they've manage
d
to locate the additional funds.
Now if you were saying "But we need to make these on Earth then transpor
t
them up into space" then I'd agree that volume and mass are important.
Before anyone mentions raw materials we're discussing 2001:ASO and if
they're sending a manned spacehip out to Jupiter I'm betting they're
mining asteroids.
>> size they need to be for everyone to use them comfortably. So no duck
ing
ou
Except what I'm saying is there was no need for it to be "a bit cramped"
at all. Having a 300ft square bedroom is overkill, having a 7.5 cube
instead of a 7 cube isn't.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 17 Jan 2008 12:30:19
Message: <478f90ab$1@news.povray.org>
Phil Cook nous apporta ses lumieres en ce 2008/01/16 09:28:
> through doors or having a shared up/down ladder. It serves no purpose
> other then being able to use those surplus navy submarine doors.
The small doors do have a purpose: They need to be airtight when closed.
In that case, the key factor is the length of the perimeter. You need it to be
as short as possible, while still be usable as a door. Surface is also a big
factor if you may, even remotely, need to close it toward the high presure area.
WARNING: The consumption of alcohol may lead you to think people are laughing
WITH you.
Date: 17 Jan 2008 20:41:46
Message: <479003da$1@news.povray.org>
> final cost is always greater then initial budget, yet amazingly they've
> managed to locate the additional funds.
Only when nobody stops you from using guns or fiat money to get
additional funds. Lots of state-level programs fail in the US for lack
of budgetted funds.
     It's not feature creep if you put it
     at the end and adjust the release date.
Date: 17 Jan 2008 22:00:23
Message: <47901647$1@news.povray.org>
> just the one room, simply expand the room and section it. Okay the
> external walls may be thicker then the internal ones, but the principal
> stilll holds.
This is like saying, "You're right, but you're still wrong." :)
Tim said, "Space is at a premium in just about any vehicle.  You use as
little as possible. "
My reasoning is that addition volume means additional materials to
enclose it, and additional fuel needed to propel it.  I never stated
that the relationship between volume and mass was a linear one.  In fact...
In other words, volume and mass are related (the relationship is there),
but not in a linear way (it's not a linear relationship).
>>> (all the same thickness). You're pumping it full of a gas that masses
>>> 0.1kg per cubic unit. So the mass of the initial room is 328.3kg. Now
>> rec room for the astronauts.
No, I'm saying "What if".  The point is, you blithely point out that
additional materials are needed, and then say that the additional cost
doesn't matter, while I say that the additional cost may make a difference.
But this room isn't the only one in the spaceship; that extra .5 cube
(?) needs to come from somewhere.
Assuming that the outer hull of the ship is fixed, and cannot be
enlarged, then it means you have to take .5 cube from another room.
Assuming that the outer hull of the ship CAN be enlarged, then we don't
need to change the size of the rooms, but we do need additional materials.
Anyway, the point is that making things bigger has a cost.  It's naive
to say simply, "They should have made that bigger," without at least
examining the costs.
...Ben Chambers
Date: 18 Jan 2008 04:10:48
Message: <op.t44brr2gc3xi7v@news.povray.org>
And lo on Fri, 18 Jan 2008 03:00:21 -0000, Chambers
>> stilll holds.
Yup :-)
> fact...
Which I first pointed out and subsequently kept agreeing with.
>> is
> difference.
But the start of this conversation was about the Jupiter mission in
2001:ASO. A society with a space base and moon bases. So the money is
there I didn't see them ducking through doors on the moon base so Alain's
perimeter argument seems only to apply to ships and not stationery objects.
>> cramped" at all. Having a 300ft square bedroom is overkill, having a
>> 7.5 cube instead of a 7 cube isn't.
> materials.
And again you're correct in the same way I say a 300 ft room is overkill.
Phil Cook
Date: 21 Jan 2008 11:17:03
Message: <4794c57f$1@news.povray.org>
Jim Henderson wrote:
>>> 2^2677009:1 against.
>>> (Name that number!)
>> Picking up Ford and Arthur in the ship (whose name I can't recall) in
>> Hitchhiker's.... ?
> Close enough; it's the odds of being picked up by a passing spaceship in
> deep space within the 30 seconds it takes to asphyxiate.
Surely that's an Islington phone number ? ;-)
Date: 21 Jan 2008 15:00:50
Message: <4794f9f2$1@news.povray.org>
>>>> (Name that number!)
>>> Hitchhiker's.... ?
>> in deep space within the 30 seconds it takes to asphyxiate.
It is also that, except for in the film, where the odds were changed for
some bizzare reason.
Jim
Date: 22 Jan 2008 05:21:26
Message: <4795c3a6@news.povray.org>
>>>>> (Name that number!)
>>>> Hitchhiker's.... ?
Not bizarre; the area codes in London have changed several times since
1979 and the numbers were altered to produce a plausible London phone
number.
Date: 22 Jan 2008 12:54:46
Message: <47962de6$1@news.povray.org>
>>>>>> (Name that number!)
>>>>> in Hitchhiker's.... ?
>> for some bizzare reason.
> number.
Sure, that would make sense, except that the odds as given are somewhat
iconic - there are certain details about H2G2 that shouldn't change IMHO;
that's one of them.  Other things, like the addition of entire new
scenes, however, is part of the H2G2 "culture".
Jim
