POV-Ray : Newsgroups : povray.off-topic : Another physical puzzle Server Time
17 May 2026 02:47:43 EDT (-0400)
  Another physical puzzle (Message 1 to 10 of 26)
Subject: Another physical puzzle
Date: 1 Jan 2008 19:13:32
Message: <477ad72c$1@news.povray.org>
You are sitting in a canoe, in a swimming pool, holding a cannon ball in
your lap. You throw the cannonball overboard, and it sinks to the
bottom. Does the level of water in the pool go up, go down, or stay the
same?
(I've asked this of probably a dozen or more scuba dive instructors, and
only one has gotten it right. The reasoning behind the correct answer is
obvious once you hear it. I don't remember if I got it right when I
heard it.)
     It's not feature creep if you put it
     at the end and adjust the release date.
Subject: Re: Another physical puzzle
Date: 1 Jan 2008 22:00:40
Message: <9ivln315r131mcentc5f1v0m6dnl3cpneq@4ax.com>
Is the canoe traveling near the speed of light?
Date: 1 Jan 2008 22:07:21
Message: <477affe9$1@news.povray.org>
I lol'd.
Date: 1 Jan 2008 23:33:29
Message: <477b1419@news.povray.org>
> same?
The water goes up (then down again) in a mostly parabolic manner since
the bowling ball would make a large splash :-)
I won't spoil the real answer for anyone still thinking about it, but
here's another fun physical puzzle that I remember:
If you've been on the beach, you've probably noticed that the sand dries
out around you foot when you step on it, why is this?  Wouldn't you
expect a small puddle of water to form around your foot instead?
Date: 1 Jan 2008 23:40:07
Message: <477b15a7@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:477ad72c$1@news.povray.org...
> same?
I believe it should stay the same.
Date: 2 Jan 2008 00:03:02
Message: <MPG.21e4c8ed2b1f3e4698a0d3@news.povray.org>
In article <477b1419@news.povray.org>, wampler+pov### [at] uwashingtonedu
says...
n
> > same?
It does get wetter, just *outside* the range of displacement from the
pressure you apply to the sand. And, if you stand there long enough that
the grains can rearrange to be less compacted, you *will* end up with
your puddle.
void main () {
    if version = "Vista" {
      call slow_by_half();
      call DRM_everything();
    call functional_code();
  else
    call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 2 Jan 2008 02:41:57
Message: <477b4045@news.povray.org>
>> same?
Incorrect.  Hint - The cannon ball sinks to the bottom.  Think about
what was preventing it doing so before.
Date: 2 Jan 2008 03:36:59
Message: <477b4d2b$1@news.povray.org>
> your puddle.
Indeed, but that doesn't really explain why it dries out initially.
Contrast it with stepping in wet mud for example, or on a wet carpet.
(as far as I understand the phenomenon, by the way, I believe that your
explanation of why the puddle eventually forms is incorrect).
Date: 2 Jan 2008 03:47:37
Message: <477b4fa9@news.povray.org>
> same?
  A classic.
  The answer can be deduced by thinking about volume and weight.
  In the canoe the ball displaces an amount of water proportional to
the weight of the ball. In the water it displaces an amount proportional
to the volume of the ball.
  So the question is basically reduced to: Which is denser, the cannonball
or water?
Date: 2 Jan 2008 07:14:44
Message: <477b8034@news.povray.org>
> or water?
That's where I was headed. Does the cannonball displace more
water "underwater" than in the boat, and the difference being
volume*(DENSITYcannonball-DENSITYwater)/DENSITYwater?
