POV-Ray : Newsgroups : povray.off-topic : Suggestions: Text editors Server Time
17 May 2026 10:58:53 EDT (-0400)
  Suggestions: Text editors (Message 51 to 58 of 58)
Subject: Re: Suggestions: Text editors
Date: 4 Jan 2008 00:36:17
Message: <477dc5d1$1@news.povray.org>
nemesis wrote:
> I like hypertext.
Hypertext is great for reference. It's lousy when you're trying to
figure out you've read the whole thing.
Similarly, I like both index *and* table of contents in my textbooks. :-)
     It's not feature creep if you put it
     at the end and adjust the release date.
Date: 7 Jan 2008 03:24:19
Message: <4781e1b3$1@news.povray.org>
>I used to use Notepad to write everything. As some of you might know,
> Notepad sucks.
I use TextPad.
Date: 9 Jan 2008 20:25:02
Message: <478573ee$1@news.povray.org>
nemesis wrote:
> Every software has its quirks.  Read that as "Yank 3 blocks", "}" used because
> of its widespread use in computer programming as a block terminator.  Now, I
> understand "CTRL+C" as copy, because of C, but why Paste uses "v"?!  quirks...
Often used operations like Cut, Copy and Paste should be easy to do,
so it is wise to choose keys for those that are close to a special key,
like e.g. Ctrl.
The X, C and V keys are next to each others and so close to Ctrl that
you can keep your little finger on Ctrl while pressing them.
If you are writing on paper you can indicate were some text is to be
inserted by drawing something similar to a V between two words and a
little bit above them, and then the text to be inserted above the V.
V is therefore not a bad choice for Paste.
If you want to remove some text you could draw something similar to an
X over it. X is therefore not a bad choice for Cut.
And then you have C that is easy to remember as an abbreviation for
Copy.
Tor Olav
http://subcube.com
Date: 9 Jan 2008 20:39:06
Message: <4785773a$1@news.povray.org>
That works great (NOT) in Dvorak keyboards, though.
Date: 9 Jan 2008 21:00:36
Message: <47857c44$1@news.povray.org>
Mmmmm. Geek ret-conning. :-)
Date: 9 Jan 2008 22:40:00
Message: <web.47859322af0f26ec5f1fd4270@news.povray.org>
he's right.  V looks like an arrow pointing down, like "place it here".  And X
is for eXtract.  or it could be just for the proximity...
BTW, folding commands in vim begin with z.  why?  because z looks like a folded
paper looked from the side... :)
Date: 10 Jan 2008 09:11:21
Message: <op.t4pv9lumc3xi7v@news.povray.org>
And lo on Thu, 10 Jan 2008 03:38:10 -0000, nemesis
<nam### [at] gmailcom> did spake, saying:
> And X
I always thought it was becaue Ctrl+C was Copy so they just put Cut and
Paste either side of it.
Anyway I always say that X looks like a pair of scissors, so you just
remember "Cut, Copy, Paste" and that's it for the shortcuts.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 10 Jan 2008 11:32:09
Message: <47864889$1@news.povray.org>
Look at the icon for cut, the scissors. Looks like an X too.
