POV-Ray : Newsgroups : povray.off-topic : Auto-skipping in WinXP? Server Time
22 Jul 2026 12:25:52 EDT (-0400)
  Auto-skipping in WinXP? (Message 31 to 37 of 37)
Subject: Re: Auto-skipping in WinXP?
Date: 3 Dec 2007 15:27:30
Message: <475466b2$1@news.povray.org>
On Mon, 03 Dec 2007 14:55:54 -0500, Warp wrote:
> Jim Henderson <nos### [at] nospamcom> wrote:
>> Personally, I use ctrl+shift+c and ctrl+shift+v in a GNOME terminal
>> window...
>   That's a terminal emulator and thus not the same thing as a bare
>   terminal.
True....
Jim
Date: 3 Dec 2007 20:54:05
Message: <4754b33d$1@news.povray.org>
Darren New wrote:
> It always throws me also that some programs will do the copy as soon as
> you highlight text. Or, if the text is still highlighted when you give
> the program focus, it'll replace whatever's in the copy buffer with
> whatever is highlighted.
I've never seen the latter happen. Can you give an example?
As for the former, usually if you explicitly copy something (using ^C or
^Ins), highlighting something won't erase that from memory. I guess
there may be exceptions.
Do Not Attempt to Traverse a Chasm in Two Leaps...
                   /  \/  \ u e e n     /  \/  a w a z
                       >>>>>>mue### [at] nawazorg<<<<<<
                                   anl
Date: 3 Dec 2007 23:30:49
Message: <4754d7f9$1@news.povray.org>
I'll keep it in mind to remember the circumstances next time it happens.
It tends to be old apps (like interpreters that have been around since
before Linux) that I see it happen in, IIRC.
Depends how old the app is, and which copy/paste buffer it uses, I think.
     It's not feature creep if you put it
     at the end and adjust the release date.
Date: 3 Dec 2007 23:32:07
Message: <4754d847@news.povray.org>
Jim Henderson wrote:
> Lots of seemingly simple things get overlooked in test cases for QA
Maybe it's just me, but if a URL can't have a space in it, I'd strip
spaces from what comes in from the user before trying to use it, without
even thinking about it. It just rather surprised me.
Date: 4 Dec 2007 05:34:30
Message: <47552d36@news.povray.org>
Just like if you have a folder name coming in, and you're using it to access
a file, you append a "/" or "\" to the end if it isn't there already.
Date: 4 Dec 2007 12:14:38
Message: <47558afe$1@news.povray.org>
>> without even thinking about it. It just rather surprised me.
> access a file, you append a "/" or "\" to the end if it isn't there
> already.
That is something the webserver does (redirect /dir to /dir/), not the
browser.
Date: 4 Dec 2007 17:33:54
Message: <4755d5d2$1@news.povray.org>
Well, if it were me, I'd code that way, too - but it could also be that
they replace the space internally with %20, which would be valid in a
URL.  Could be that's the case they picked instead.
Jim
