POV-Ray : Newsgroups : povray.off-topic : Does anybody know this? Server Time
12 Nov 2026 09:02:52 EST (-0500)
  Does anybody know this? (Message 11 to 31 of 31)
<<< Previous 10 Messages Goto Initial 31 Messages
Subject: Re: Does anybody know this?
Date: 1 Dec 2007 06:39:10
Message: <475147de$1@news.povray.org>
Warp wrote:
> Orchid XP v7 <voi### [at] devnull> wrote:
>> How does this stuff work with Windoze?
>   When you have your compiler installed, you download the Windows SDK
> which contains the necessary header files. Then you call the functions
> defined in these header files.
Fair enough, but how exactly does it work under the covers? As in, how
does it ultimately find the address of the code you want to call?
(I'm sure in the normal course of events you'll never need to know or
care about this stuff. I'm just curios...)
Date: 1 Dec 2007 11:10:34
Message: <4751877a$1@news.povray.org>
John VanSickle nous apporta ses lumieres en ce 2007/11/30 16:35:
> Orchid XP v7 wrote:
>> I'm just being nosy now... How do you call OS functions on Windoze?
>> Back in the days of the Commodore 64, the "operating system" (I use
>> the term loosely) was stored in a big ROM chip. To call the OS
>> (assuming you actually wished to do such a thing!) you simply jump to
>> the right magic address. Since it's in ROM, it never moves. And
>> indeed, you could buy big tables of addresses and the expected
>> parameters...
> Commodore released a manual for the C64 that had EVERYTHING about the
> machine, including schematics.  It contained everything you needed to
> write any application.
Apple did the same with the Apple ][. In fact, one of the included manuals
included the source code of the ROM and the scematics. Still have them.
There where also several third party sources for much of what's in the Applesoft
basic ROM.
A true friend is someone who reaches for your hand and touches your heart.
Date: 1 Dec 2007 11:53:14
Message: <4751917a@news.povray.org>
The compiler recognizes that you are calling functions that aren't being
directly compiled into the code, and leaves dummy values in the Jump
instructions. During the linking or loading phase, those values are
replaced by addresses in memory.
At a lower level, the object files/DLL have a table that instructs the
linker/loader as to how far into that file a certain function is. When
that gets loaded into memory, in the case of a DLL at run time, the
linker/loader can take that memory location and basically do a search
and replace.
There is another level of misdirection, in that most of the time the
library is loaded into the user processes' virtual memory. This means
the address isn't really the actual location of the library in RAM, but
that is more a hardware level thing.
Date: 1 Dec 2007 12:15:39
Message: <475196bb@news.povray.org>
  AFAIK the system libraries perform kernel calls (in both Windows and
Linux). Basically the kernel knows the library and accepts its calls
(while it's not possible to do it directly from user code). A kernel
function call is probably little more than a 'call' machine code to
a certain address in the kernel space. A 'call' machine code is more or
less equivalent to 'gosub' in BASIC. (The CPU can be instructed to allow
or disallow such calls depending on what code is attempting to do it.)
Date: 1 Dec 2007 12:50:09
Message: <47519ed1$1@news.povray.org>
John VanSickle wrote:
> Addison-Wesley released a very extensive set of docs for the Amiga,
> consisting of five volumes.
Yup. Or any Amiga compiler came with it. Considering I owned both the
books and a couple of compilers in college, I don't think it was *that*
much money.  $99 for a C compiler, if I recall. I think I still have the
books somewhere.
>> How does this stuff work with Windoze? (Or Linux, for that matter...)
> For Windows, I think that the library code is mostly in DLLs, and that
> your linker will add the appropriate OS calls to get any needed DLLs
> into memory.
Yep. That's what user.dll, graphics.dll, stuff like that are.
At the lowest lowest level, I'm pretty sure the libraries load up
arguments into registers and execute an INT instruction, which is a
"software interrupt", aka a trap, which causes a branch to an address
loaded into a specific area of memory. I.e., just like handling an
interrupt, or just like branching to a jump table in a library, except
that you get privilege bits flipped around.
I don't know of any modern multiuser OS that doesn't use that technique
to get into the kernel, as it's pretty much the only way to bypass
memory and execution permissions in a controlled way.
     It's not feature creep if you put it
     at the end and adjust the release date.
Date: 1 Dec 2007 13:08:02
Message: <4751a302$1@news.povray.org>
That's called a "call gate". Not many CPUs use that any more, especially
those with memory mapping and VM handling.
Wikipedia is your friend: http://en.wikipedia.org/wiki/System_call
(BTW, this is why C isn't particularly better than any other language
for this stuff. There's no way to specify something like "load register
EAX with 0x80 and then do a system interrupt call.)
BTW, even CP/M on the 8080 and DOS on the 8086 used interrupt calls to
dispatch to the OS, even tho there were no privilege reasons to do so.
If you're not familiar with how modern systems do interrupts and
privileges and such at the assember/hardware level, it's hard to go into
too much detail. If you *are* familiar, then it should be pretty
obvious. :-)
Date: 1 Dec 2007 14:15:44
Message: <4751b2e0$1@news.povray.org>
A lookup table of some sort.
Jim
Date: 1 Dec 2007 14:16:44
Message: <4751b31c$1@news.povray.org>
I don't know about GCC, but I know in BorlandC and TurboC, you could do
inline assembler - I used to use that functionality a lot back in the
dark ages...
Jim
Date: 1 Dec 2007 16:36:41
Message: <4751d3e9$1@news.povray.org>
> dark ages...
Yup. Note that inline assembler isn't C. :-)   I was thinking more of
Ada, which actually has language constructs for hooking and invoking
interrupts, for example. You can declare a procedure as one that gets
executed by an interrupt at a certain priority, and where it gets its
arguments from, and so on.
Date: 1 Dec 2007 17:32:19
Message: <4751e0f3@news.povray.org>
Well, true. :-)
But it wouldn't be hard to write a function that does the low-level
stuff, either, I don't think - just a question of linking to a library
with an appropriate function.
Jim
Date: 1 Dec 2007 22:09:21
Message: <475221e1$1@news.povray.org>
> stuff, either,
Unless you're going to do something like write into a char[], then cast
the char[] to a function pointer, I'm pretty sure you can't invoke
arbitrary machine code from C. :-) *Somewhere* there's assembler.
Date: 2 Dec 2007 14:28:29
Message: <4753075d$1@news.povray.org>
>> stuff, either,
I'd think that'd be true for pretty much any language, though - even Ada.
But I was thinking along the lines of what you said.
Jim
Date: 2 Dec 2007 15:07:51
Message: <47531097$1@news.povray.org>
Actually, no. It has an explicit construct for catching interrupts by
invoking a routine. (The routine would be in what Java calls a
synchronized class.)  You specify the priority of the interrupt, and
which interrupt it is, and all that.  I am not sure you can actually say
what registers wind up in which arguments within the language, granted. :-)
Yeah, but that's still not actually C. That just happens to be knowing
what your particular C compiler outputs for a program that has no
semantics in C. It's really not C any more than inline assembler is. :-)
Date: 2 Dec 2007 15:41:59
Message: <47531897$1@news.povray.org>
>> Ada.
See, to me, that's not much different than a function call - just a very
directly implemented function call. :-)
But probably closer to invoking, say, INT21 than you would do from C
using inline - though the generated code by the compiler would probably
be very close.
True; but I'm guessing you're talking at a level in the language/compiler
that I'm much less familiar with - in the end, you end up with machine
code no matter what you do, since that's all the machine actually
understands.
Jim
Date: 2 Dec 2007 15:53:55
Message: <47531b63$1@news.povray.org>
Well, yah, except you say "invoke this function when you get that
interrupt", and you don't set up the interrupt table yourself, and you
don't have to deal with turning interrupts on and off, generating
special return instructions, managing the priorities, etc.
Kind of the difference between having threading or dynamic loading in a
language, and invoking an OS-specific library for it. Functionally
pretty similar, except you only have to learn it once and it generally
works out better/easier to use.
> be very close.
I'm talking about handling interrupts, like in the kernel or a device
driver, rather than generating interrupts. If that's the confusion... :-)
Date: 2 Dec 2007 19:43:59
Message: <4753514f$1@news.povray.org>
>> very directly implemented function call. :-)
>> be very close.
Ahhhh, I was thinking you/we were talking about calling interrupts -
chaining interrupts is definitely something different.  I think back in
the early 90's I wrote an interrupt chain in C, and you're right, it
wasn't very straighforward.  I'd have to pull out a couple of my old
books on interrupt programming to remember how I did it.
I know I did do it, though, because there were some undocumented DOS
interrupts that I used for doing various tricky things in NetWare login
scripts in the 3.x days - things like changing the master DOS environment
table from within a DOS login script; I'm fairly sure I didn't write them
in assembler, but it has been 20+ years since I did that, so maybe I did
do that.
Jim
Date: 2 Dec 2007 20:16:50
Message: <47535902@news.povray.org>
Now you got me curious, and I pulled down my Ada textbook.
Turns out the interrupt procedures don't have arguments (other than, of
course, knowing which interrupt it was). I suppose that makes sense at a
machine level, except for the software interrupts.
You can have declarations like
   for X'address use A;
to make X get allocated at the address represented by A. Works for code
or data, meaning you don't have to do anything funky to put code in a
particular ROM address, for example.
You can, of course, say
   for X'address use Y'address;
to alias X and Y together, if they are, say, different types for the
same hardware or something.
(Note: X'Y is the syntax for accessing compile-time property Y of object
X, so in Ada, it would be something like X'size instead of sizeof(x))
There's also decomposed addresses, letting you extract the segment and
offset from a segmented address.
There's also Atomic and Volatile declarations (with the obvious
semantics), the 'alignment attribute, the 'bit_order attribute (to
control the order of allocations that C would use for bitfields in
structs), the 'storage_size expression that lets you overallocate
storage for an object (so you can, for example, allocate one block of
flash to a particular set of routines or data).
You can set the dispatch policies (like whether tasks are FIFO within
the priorities, or whether they run to completion, or whatever), and
(hey Warp) the 'Immediate_Reclamation attribute, which means storage for
a declared object is reclaimed as soon as the object ceases to exist. ;-)
Given all that, it still can be a pretty annoying language to use.
> do that.
I'm guessing you did the same sort of thing that old BASIC programs did,
which was machine code in DATA statements poked into memory and then
executed.  If your compiler translates integers to addresses in a
straightforward way, it would be pretty easy to do that in C.
Date: 3 Dec 2007 04:46:34
Message: <4753d07a$1@news.povray.org>
OK, that's what I wanted to know...
(PS. Is there more than one interrupt level available? Or does it decide
which routine to call based on some other parameter?)
Date: 3 Dec 2007 10:04:21
Message: <47541af5$1@news.povray.org>
Invisible nous apporta ses lumieres en ce 2007/12/03 04:46:
>> technique to get into the kernel, as it's pretty much the only way to
>> bypass memory and execution permissions in a controlled way.
If my memory is good. On the 8086, there where about 256 programable software
interupts available to programmers. Interupts 0 to 15 are special periferals
interupts. There where also some hardware interupts, but I don't know how many.
The "Reset" switch triggers one of them.
   I'm so ugly I stuck my head out the window and got arrested for Mooning.
   	Rodney Dangerfield
Date: 3 Dec 2007 12:51:27
Message: <4754421f$1@news.povray.org>
Yep, on that point we agree. :-)  I did always think the exception
handling being able to handle things at the hardware interrupt level was
cool in Ada.  Just not cool enough to justify the memory usage of
machines 20 years ago (which is nearly when I learned it, doesn't seem
possible it was almost that long ago).
>> did do that.
Very likely that is what I did.  Either that or I did inline assembly
since my compiler supported that option.  I used information/techniques
from the books Undocumented DOS (1e) and the Abacus book on DOS
programming.  Still have both of those on the bookshelf at home.
Jim
Date: 3 Dec 2007 23:26:35
Message: <4754d6fb$1@news.povray.org>
I have learned I have a knack for figuring out what technical question
someone is *really* asking. I wish I knew why, so I could teach others
to do it.
It depends on the CPU. Often there are multiple software interrupts
available, but most OSes only use one, with a parameter passed in a
register to indicate which one. Under MS-DOS, for example, it
was INT 21 (hex 21) to call DOS. The BIOS had a different interrupt
(13?) for disks, and maybe one for the other stuff like video and all.
Learning how basic CPU stuff works is often very useful. Like,
understanding that interrupts are nothing but polling the interrupt
hardware wire at the start of each instruction can make you go "Oh! I
see!" :-)
