POV-Ray : Newsgroups : povray.off-topic : A small statistics question Server Time
17 May 2026 06:39:27 EDT (-0400)
  A small statistics question (Message 11 to 20 of 29)
<<< Previous 10 Messages Goto Latest 10 Messages Next 9 Messages >>>
Subject: Re: A small statistics question
Date: 26 Nov 2007 22:58:02
Message: <474b95ca$1@news.povray.org>
Warp wrote:
> Invisible <voi### [at] devnull> wrote:
>> Anybody have any idea how I can make a program generate random numbers
>> between 30 and 30,000, but so that "most" of the numbers generated are
>> actually in the range 100 - 400?
> http://en.wikipedia.org/wiki/Poisson_distribution
	I'd have used a Gaussian - any particular reason to choose a Poisson?
Isn't it counterproductive to have incandescent bulbs in a fridge?
                   /  \/  \ u e e n     /  \/  a w a z
                       >>>>>>mue### [at] nawazorg<<<<<<
                                   anl
Date: 27 Nov 2007 04:21:10
Message: <474be186$1@news.povray.org>
100 and 400 are both nearer to 30 than to 30,000?
Date: 27 Nov 2007 05:50:07
Message: <474bf65f$1@news.povray.org>
Depends on how efficient or accurate it needs to be.
A simple but inefficient way is to create a curve
function that represents the desired distribution,
generate two random numbers representing an
X,Y vector on the chart, then reject the points
above the curve, and use the X value of accepted
points as the random value.
An efficient but more complicated method is
to create a bar graph approximation of the
distribution curve, then "stack" the rectangles.
Then you can create an X,Y vector guaranteed
to be inside the stack of rectangles, then figure
the X offset of the rectangle based on Y and
use X + X offset @ Y as your random value.
Date: 28 Nov 2007 10:34:39
Message: <474d8a8f$1@news.povray.org>
Invisible wrote:
> scott wrote:
>> #if( rand(s1) < 0.1 )
>> #local N = rand(s1) * 29970 +  30;
>> #else
>> #local N = rand(s1) *   300 + 100;
>> #end
> Mmm, yeah, I guess that would work. :-)
I saw the question, came to the same answer, and anticipated the same
response, even it had been in haskell.  Don't you have some flirting you
should be catching up with?
Date: 28 Nov 2007 10:37:50
Message: <474d8b4e$1@news.povray.org>
That requires a partner. :-P
Date: 28 Nov 2007 10:49:49
Message: <474d8e1d$1@news.povray.org>
>> you should be catching up with?
You could always flirt with yourself. Mind you don't go blind, though.
Date: 28 Nov 2007 16:57:14
Message: <474de43a$1@news.povray.org>
Oh that's cute. :-P
Date: 28 Nov 2007 17:09:25
Message: <474de715@news.povray.org>
474d8e1d$1@news.povray.org...
Let's not forget the kittens
http://en.wikipedia.org/wiki/Image:God-kills-kitten.jpg
Marc
Date: 28 Nov 2007 17:27:22
Message: <474deb4a$1@news.povray.org>
http://lolcat.com/godkills.html
Date: 28 Nov 2007 23:54:02
Message: <474e45ea$1@news.povray.org>
Ceiling cat is watching you kill kittens?
