POV-Ray : Newsgroups : povray.off-topic : Good widescreen LCD Server Time
11 Oct 2024 07:14:05 EDT (-0400)
  Good widescreen LCD (Message 1 to 10 of 30)
Subject: Good widescreen LCD
Date: 17 Nov 2007 02:51:52
Message: <473e9d98@news.povray.org>
My 19" LCD packed up the other night, and I thought I'd replace it with a
widescreen (20" or 21") LCD
I've heard good things about the BenQ 20" and about the LG monitors.
Anyone with personal experience with widescreen LCDs? It's going to be used
for graphics, movie watching (a little) and gaming.
I checked Tom's hardware, but all the LCD reviews I could see were last year
Subject: Re: Good widescreen LCD
Date: 17 Nov 2007 06:21:34
Message: <473ecebe$1@news.povray.org>
I had a bad experience with an LG monitor, though it wasn't widescreen. I
can no longer remember its name, but the problems were these two details:
1) The monitor used that technology (I've forgotten the name) where the
brightness and colors are different depending on which angle you look at the
monitor from. Most laptop monitors are like this too, but it was very
uncomfortable for a stationary monitor, especially when working with
graphics.
2) The monitor was not true 24-bit. Again, I have forgotten what it actually
was, but it had fewer than 256 colors per channel, which were then
interpolated. You couldn't see it most of the time, but when working with
subtle gradient, like a blue sky, it was visible and annoying.
If you find an LG monitor that uses the angle-independent technology and is
true 24 bit, then these observations don't apply of course.
Rune
Date: 17 Nov 2007 10:58:42
Message: <473f0fb2$1@news.povray.org>
Wow that sucks. I'm finding 256 colors per channel being not enough!
(like on grayscale images :P)
Date: 17 Nov 2007 11:02:33
Message: <473f1099$1@news.povray.org>
That's... interesting. I'm fairly sure I read somewhere that for
*greyscale* the human visual system can only distinguish about 16
different levels. (Not sure whether that's *linear* though...)
Date: 17 Nov 2007 11:29:59
Message: <473f1707$1@news.povray.org>
Yeah, if I have 16 *consecutive* grayscale values (185, 186, 187, 188,
189...) on an image, I can definitely distinguish them!
Date: 17 Nov 2007 12:19:23
Message: <473f229b@news.povray.org>
> different levels.
  That's unusually easy to prove wrong. How many bars can you count in
this image? http://warp.povusers.org/images/grayscales.png
  The number you counted is the amount of grayscales you can distinguish
at least. (The true number is probably at least that times 10 or more.)
Date: 17 Nov 2007 12:46:50
Message: <473f290a$1@news.povray.org>
>> different levels.
While some cells in the eye may be able to distinguish that many colors,
that doesn't mean that the visual system in the brain can. A lot of
preprocessing is done in the eyes themselves before the visual data is sent
to the brain.
For example, the eyes have an edge detecting layer I think, or something
along those lines. This layer could find all the edges of the bars in your
image and send information about these edges on to the brain, so that the
brain can tell how many bars there are. The eyes also send the actual "raw"
brightness info on to the brain, but this may be in a "low resolution" where
no more than 16 different shades can be told apart. However, the brain can
still count all the bars, becuase of the edges detected in the eyes.
I'm not saying it's like that; just that your image doesn't prove anything
about the amount of gray scales the brain can tell apart. So it really comes
down to what you mean by "human visual system" - the eyes or the brain.
Rune
Date: 17 Nov 2007 13:12:05
Message: <473f2ef5$1@news.povray.org>
>> different levels.
First two and last two look quite similar from some angles (damned LCD
screen). Also, the black ones look all similar (damned gamma; the world
would be a better place if screens had had built-in gamma correction
since the beginning).
Date: 17 Nov 2007 13:26:11
Message: <473f3242@news.povray.org>
  I'm quite certain that if it was an animation where each frame is
completely filled by a shade of gray and was played eg. at 1 FPS, you
could clearly see the change.
Date: 17 Nov 2007 18:22:17
Message: <473f77a9$1@news.povray.org>
Warp nous apporta ses lumieres en ce 2007/11/17 12:19:
>> different levels.
I can count about 30 very distinct bands, monitor permiting.
A short cut is the longest distance between two points.
