POV-Ray : Newsgroups : povray.off-topic : Surprise! Server Time
17 May 2026 09:23:10 EDT (-0400)
  Surprise! (Message 21 to 30 of 109)
Subject: Re: Surprise!
Date: 8 Nov 2007 08:00:09
Message: <47330859$1@news.povray.org>
4733016b$1@news.povray.org...
> (I still can't figure out why you can use an oscilator to make radio
> waves, but not light rays...)
Is not a laser an excitated resonant optical cavity eg a oscillator?
Marc
Date: 8 Nov 2007 08:08:19
Message: <47330a43$1@news.povray.org>
Stephen wrote:
> Invisible <voi### [at] devnull> wrote:
>> * Electricity does not, under any remotely "normal" conditions, produce
>> light or affect it in any way. (E.g., you can't bend light using
>> electricity.) The same goes for magnetism.
> I thought lightning was normal at least in a storm.
Oh, sure, if you make stuff hot it will give off light. (And other
frequencies, for that matter.) But you don't need to use electricity to
make things hot; you can use *anything* to make it hot, and it will
glow. So it's not really an electrical effect.
> If you oscillate something fast enough it will heat up and emit light.
More to the point, presumably if you shine a light on some kind of
conductor, it will induce a current... (And yet nobody has found a way
to use this to convert sunlight to electricity yet. They all rely on
obscure chemical and physical properties to try to do the job.)
Date: 8 Nov 2007 08:08:56
Message: <47330a68@news.povray.org>
Actually, I thought it was a tube full of extremely hot gas with some
mirrors at the ends? (I don't know a huge amount about lasers.)
Date: 8 Nov 2007 09:15:02
Message: <web.473319144b19b3ff726bd13c0@news.povray.org>
than I. I thought that you could not separate electricity and magnetism. Also
Light is part of the Electro magnetic spectrum and to my simple mind that
implies some sort of relationship.
Date: 8 Nov 2007 09:58:20
Message: <4733240c@news.povray.org>
> However, it's really damn unusual for a material's electrical or magnetic
> properties to have any bearing at all on its optical properties.
I thought it was quite common, eg nearly all electrical conductors are
opaque.
> * Impure water is an excellent conductor, while pure water is a very good
> insulator. Yet both substances have almost identical optical properties.
I wouldn't exactly call impure water an "excellent" conductor, but more
conductive than pure water yes...
Lasers?
Date: 8 Nov 2007 10:09:27
Message: <473326a7$1@news.povray.org>
>> magnetic properties to have any bearing at all on its optical properties.
> opaque.
...which the obvious exception of water, liquid NaCl, various kinds of
crystals... ;-)
>> good insulator. Yet both substances have almost identical optical
>> properties.
Depends what the impurities are and how much. ;-)
> Lasers?
I don't actually know how those work. I was under the impression that it
works by exciting atoms so that they emit photons - much the same way a
lump of iron glows if you put it in a hot fire. (But with some mirrors
in there to ensure the light only travels in one direction...)
Date: 8 Nov 2007 10:20:44
Message: <4733294c$1@news.povray.org>
> scott wrote:
>> Lasers?
It's not the same thing at all. Laser light is very coherent, i.e. all
the photons in it have almost the same wavelength. When you just heat
iron you don't get that at all... And what makes it work is that the
mirrors build a resonant optical cavity, they are not there just to give
the direction.
Vincent
Date: 8 Nov 2007 10:33:01
Message: <47332c2d$1@news.povray.org>
473326a7$1@news.povray.org...
> lump of iron glows if you put it in a hot fire. (But with some mirrors in
AFAIK The optical cavity between the 2 mirrors works as a resonator or as an
amplifier with an amount (one of the mirrors is semi-reflective to allow
output) of reinjection of output into input.
Marc
Date: 8 Nov 2007 10:37:28
Message: <op.t1hb94k2c3xi7v@news.povray.org>
And lo on Thu, 08 Nov 2007 10:50:34 -0000, scott <sco### [at] laptopcom> did
spake, saying:
>> I find it rather bizare that electronic properties should actually
>> affect optical ones, but there we are.)
> Well yeh, what's light?
On a more serious note can anyone explain refraction in terms of
particles. To put it another way fit a standard double-slit experiment in
front of a transparent block set at an angle and then detect which slit
the photon is passing through then examine the terminus of the photon
through the block.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 8 Nov 2007 11:23:24
Message: <473337fc@news.povray.org>
> nemesis wrote:
>> a more direct link in his own site:
>> http://www.imagico.de/pov/metamaterials.html
> Woah - so you mean POV-Ray already does this *now*?
> Now suddenly the subject line seems even more appropriate. ;-)
WOAH
