POV-Ray : Newsgroups : povray.off-topic : Plans Server Time
10 Jun 2026 13:33:27 EDT (-0400)
  Plans (Message 31 to 35 of 35)
Subject: Re: Plans
Date: 7 Nov 2007 05:35:59
Message: <4731950f$1@news.povray.org>
>> No, but it's a typical value with some tolerance.  On our drawings we
>> always have stuff that is labelled like 16.68 +/- 0.20 mm, if they made
>> all the parts with an average of 16.66 mm then some of them wouldn't fit
>> together properly.
> As I understand it, the stuff you make is somewhat smaller than a
> building. ;-)
Exactly the same principles though.
Imagine you have a rise of 3050mm that you want to meet with 10 steps, and
you can make each step with a tolerance of +/- 50 mm.
You might specify each step as 305 +/ 50 mm, which will give you a total
height of 3050 +/- 50 mm.  Using your argument though, you would say the 305
is pointless and you may as well just say 300.  That would make every
staircase 5cm out on average!
In buildings I would imagine that lots of distances add up, and if you don't
at least aim to make each one correct, then at some point something is not
going to fit.
Subject: Re: Plans
Date: 7 Nov 2007 08:07:20
Message: <4731b888$1@news.povray.org>
> scott wrote:
>>>> That's because people who build the stairs works with that order
>>>> of tolerance (mm).
>>> So... what the hell do you do if you build some stairs, and the
>>> sement sinks by 0.4 mm while drying? (A perfectly likely outcome.)
>>> Then each step might be 0.4 mm out...! No noes! o_O
>> Who secures stairs in place by resting them on unset concrete? :-S
> I was thinking more that the *stairs* are made of concrete...
Concrete stairs are usually build in a workshop, poured into
a plywood form, upside-down (so the walking surface is at
the bottom of the form, giving a mostly perfect look and
dimensioning to the visible parts).
Fabien.
Subject: Re: Plans
Date: 7 Nov 2007 08:24:18
Message: <4731bc82@news.povray.org>
Really? I assumed they made them on-site. (And that that was the
principle advantage of making stairs out of such an otherwise
unattractive material when numerious better alternatives exist.)
Oh well, you learn something every day. ;-)
(Did you know, Boron is what makes silly putty so weird?)
Subject: Re: Plans
Date: 8 Nov 2007 19:16:39
Message: <4733a6e7@news.povray.org>
Did you mean 305 +/- 5mm?
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Subject: Re: Plans
Date: 9 Nov 2007 03:57:35
Message: <473420ff$1@news.povray.org>
Oops yes, actually no, thinking a little more about it the correct one would
be 305 +/- 15.8.  (tolerances like this are normal distributions, not
uniform...)
