POV-Ray : Newsgroups : povray.off-topic : Plans Server Time
9 Jun 2026 17:27:47 EDT (-0400)
  Plans (Message 21 to 30 of 35)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Plans
Date: 6 Nov 2007 12:23:52
Message: <op.t1drxlx8c3xi7v@news.povray.org>
And lo on Tue, 06 Nov 2007 11:40:26 -0000, Invisible <voi### [at] devnull> did
spake, saying:
> I'm just sitting here looking over the plans for our new building at
> work. It looks roughly like a tangled maze of lines, encrusted with text.
> Some of the text is in fact almost unreadable because it's so tiny. Even
> when printed out, I can bearly read it. I had a look at the PDF file,
> and it says the document dimensions are "23.39 x 33.11 inches". A quick
> trip to Google tells me that's 594.106 x 840.994 mm. (Wow, that sounds
> pretty big!) A quick check on Wikipedia tells me that's exactly A1. (!!)
> So, where the plan says "1:50 scale", it's really "1:400" when printed
> on A4 instead of A1.
Taking into account that the software may have 'fixed' it to print within
your printer margins.
> The drawing contains a number of items of interesting text. For example,
> this is "DWG NO 2222.173". It is described as "GROUND FLOOR PLAN, OFFICE
> B SETTING OUT".
> Also, next to the stairs, I found this:
>    OVERALL RISE OF STAIR 3825mm
>    EACH RISE: 165mm (x23)
>    EACH GOING: 250mm.
>    BALUSTRADE TO BE TOP FIXED.
>    DESIGN TO COMPLY WITH B.REGS
>    PART K & M.
> I just love the way they quote the size of a flight of stairs in
> millimeters! I mean, it rises 12 feet up, and we care about 25mm?
Yes if you want it to be 12 feet up when it races the top.
> I have no idea what "BALUSTRADE" is. (Assuming I've even read it right
> from the tiny writing on the printout.)
It's that bit that stops you from falling off the side of the stairs.
> Similarly, ever head of "BRISE SOLEIL"? Because apparently this building
> will have *lots* of those.
Sun-shade.
> But most of all, it's just numbers. *Millions* of numbers. Almost every
> line has a second line next to it with some numbers. Many of the corners
> there are dashed lines *everywhere*.
> (I just reliased... Every single doorway in the place has a unique ID
> written on it. Wow.)
Yup
> There are also all sorts of symbols that look like they probably mean
> something to a building engineer. Means nothing to me though! Heh.
Yup again
> It's certainly interesting anyway...
Looking at building plans is always fun.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Subject: Re: Plans
Date: 6 Nov 2007 13:24:01
Message: <4730b141$1@news.povray.org>
> spake, saying:
>> Even when printed out, I can bearly read it. I had a look at the PDF
>> file, and it says the document dimensions are "23.39 x 33.11 inches".
>> A quick trip to Google tells me that's 594.106 x 840.994 mm. (Wow,
>> that sounds pretty big!) A quick check on Wikipedia tells me that's
>> exactly A1. (!!)
> within your printer margins.
True...
Perhaps that's why part of the building is missing? Or maybe it's just
that this particular drawing only includes that part, I'm not sure.
I'm glad someone else thinks so.
I have no idea what half the stuff means, but I'm nosey anyway! ;-)
Subject: Re: Plans
Date: 6 Nov 2007 13:24:50
Message: <4730b172@news.povray.org>
Tim Cook wrote:
> Nicolas Alvarez wrote:
>> Invisible escribió:
>>> Ooo, I just found a small space that looks like this:
>>>   | 87°    94°|
>>>   |   RISER   |
>>>   | 90°       |
>>> Hahahah! Some poor **** is going to have great fun building THAT...
>> What the...
> Should probably be more like:
> +--..__
> |87     ''--.._
> |            94|
> |90            |
> ...still not too fun to build.
That's a tilt of a tad more than 4°, but essentially yes. ;-)
(On the paper it sure looks like a perfect square. But there we are.)
Subject: Re: Plans
Date: 6 Nov 2007 13:29:56
Message: <4730b2a4$1@news.povray.org>
>> That's because people who build the stairs works with that order
>> of tolerance (mm).
> So... what the hell do you do if you build some stairs, and the sement
> sinks by 0.4 mm while drying? (A perfectly likely outcome.) Then each
> step might be 0.4 mm out...! No noes! o_O
Who secures stairs in place by resting them on unset concrete? :-S
Subject: Re: Plans
Date: 6 Nov 2007 13:31:20
Message: <4730b2f8$1@news.povray.org>
>>> of tolerance (mm).
I was thinking more that the *stairs* are made of concrete...
Subject: Re: Plans
Date: 6 Nov 2007 15:03:54
Message: <4730c8aa@news.povray.org>
>>>> of tolerance (mm).
Oh you mean like one big pre-fab set of stairs?  If they all shrunk 0.4mm
after they were taken out of the mold then the usual idea is to make the
mold 0.4mm bigger than needed...
Anyway, who's going to notice if the last step is 0.4mm less that the
others?
Subject: Re: Plans
Date: 6 Nov 2007 16:51:11
Message: <4730e1cf$1@news.povray.org>
> others?
...which was why I was amused at the stairs having dimensions to the
nearest mm. ;-)
Seriously, if I take a tape measure to the finished building, do you
really think all the measurements will be exactly whole numbers of
millimeters? I somewhat doubt it. ;-)
Subject: Re: Plans
Date: 6 Nov 2007 19:07:15
Message: <473101b3$1@news.povray.org>
"Orchid XP v7" <voi### [at] devnull> wrote in message
> nearest mm. ;-)
If you give builders plans to the nearest meters, you can none of the
dimensions will be accurate to the nearest meter either. Does it all make
sense now?
Subject: Re: Plans
Date: 7 Nov 2007 03:29:12
Message: <47317758$1@news.povray.org>
>> others?
> nearest mm. ;-)
No, but it's a typical value with some tolerance.  On our drawings we always
have stuff that is labelled like 16.68 +/- 0.20 mm, if they made all the
parts with an average of 16.66 mm then some of them wouldn't fit together
properly.
Subject: Re: Plans
Date: 7 Nov 2007 04:13:58
Message: <473181d6$1@news.povray.org>
>>> others?
>> nearest mm. ;-)
> always have stuff that is labelled like 16.68 +/- 0.20 mm, if they made
> all the parts with an average of 16.66 mm then some of them wouldn't fit
> together properly.
As I understand it, the stuff you make is somewhat smaller than a
building. ;-)
