POV-Ray : Newsgroups : povray.off-topic : The other rant that amused me recently Server Time
12 Nov 2026 11:35:27 EST (-0500)
  The other rant that amused me recently (Message 12 to 21 of 21)
<<< Previous 11 Messages Goto Initial 21 Messages
Subject: Re: The other rant that amused me recently
Date: 1 Nov 2007 11:19:51
Message: <op.t04fm2dvcs6ysw@e6600>
On Thu, 01 Nov 2007 01:19:42 +0100, Warp <war### [at] tagpovrayorg> wrote:
>   The next C++ standard will commit a big sin and will define the concept
> of garbage collection in C++.
Could you provide a reference? I have seen it being discussed at times,
but I was not aware that consensus had been reached.
FE
Date: 1 Nov 2007 11:45:19
Message: <472a029f$1@news.povray.org>
Warp escribió:
>   However, these ranters go ahead and generalize that this is the case
> with *all* possible programs. You should *always* use C# instead of C++,
> no matter what kind of program you are writing. Current computers have
> multi-gigabyte RAMs, so who cares?
I once saw a website of a guy creating one program a day in C#, to rant
about how easy it was to code in C# and how everything else sucked ("HA!
Can you do this with YOUR programming language?"). The simplest of the
programs ate 40MB of memory. Of course I didn't bother to try the more
complex ones.
Date: 1 Nov 2007 12:49:13
Message: <472a1199$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> Except it's not my code, so I couldn't fix it if I wanted to. :-)
>   It's not like programs written in other languages were bug-free...
Not at all. Let me give you an example:
C++ program crashes. How do I know? The socket it's listening on closes
or, alternately, stops responding to requests because the program hung.
Tcl program crashes. How do I know? It catches the top-level bgerror,
logs a record to the database (and failing that, writes it to the
filesystem, and failing that, emails it to me, and failing that, well,
yeah, OK.)  If the error was something that is probably recoverable
(such as a lost socket, restarting database, etc) it cleans up all
globals, reloads the code, closes all open sockets, and launches itself
again.
You *could* do it in C++, sure, as long as you don't make any mistakes
that trigger undefined behavior.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 1 Nov 2007 13:38:53
Message: <472a1d3d$1@news.povray.org>
That's really more my gripe. Not that C++ is more buggy. It's that it's
less easy to notice, track down the source of, or repair a bug. I make
lots of buggy code as I'm developing. Making non-buggy code in a
language with no support for knowing you made a bug takes me much much
longer than finding the bug the first time I run the code I've written.
Date: 1 Nov 2007 13:43:11
Message: <472a1e3e@news.povray.org>
http://en.wikipedia.org/wiki/C%2B%2B0x#Transparent_Garbage_Collection
Date: 1 Nov 2007 13:57:03
Message: <472a217f@news.povray.org>
Sounds like "conservative GC" to me, where the runtime deallocates an
entire page from the address space if, after scanning all memory, can't
find a pointer-aligned integer whose value is in the range of addresses
of that page.
I'd be fascinated to see how this works with pointer arithmetic et all.
Date: 1 Nov 2007 14:33:30
Message: <472a2a0a$1@news.povray.org>
Le 01.11.2007 19:43, Warp nous fit lire :
This is what you get when you mix java-hord with C++ specification...
Looks like the C++ comittee wanted to seduce the careless java-people.
Multiple inheritance is the strong interest of C++ vs Java
(interface just do not always do it).
The superior man understands what is right;
the inferior man understands what will sell.
-- Confucius
Date: 1 Nov 2007 14:55:13
Message: <op.t04pmkx3cs6ysw@e6600>
>> concept
"Note: In the post-Kona mailing (2007/10), Transparent Garbage Collection
has been dropped to a status of Not quite ready for C++0x timetable, but
actively pursued. This likely will postpone GC from C++0x to the version
after it."
So, maybe sometime around 2020 then.
FE
Date: 2 Nov 2007 08:06:49
Message: <472b20e8@news.povray.org>
> > bits were wasted. I re-implemented the this class so that it would only
> > store as many bits as necessary for each element. This meant that if,
> > for example, the integers stored in this vector had value ranges between
> > 0 and 100000, only 17 bits were allocated for each element, producing a
> > saving of 46% in memory usage.
> That's a keyword in Ada, see. :-) You declare the array "packed" and you
> get that behavior without writing any extra code.
  The question is not whether the language has direct support for
something specific but if offers you the tools to transparently change
the implementation of such a data container in such way if needed
(including things not directly supported by the compiler).
Date: 2 Nov 2007 19:16:19
Message: <472bbdd3@news.povray.org>
Yeah, Ada does that too, of course.   I'm just pointing out it has a
bunch of *other* stuff *also* built in.  Like, most of the kinds of
things you'd want to do to drive hardware, handle realtime needs, catch
interrupts, pack bits, use funky size memory bandwidths, replace running
code without stopping what you're doing, multithreading, mapping
variables to specific memory locations, handling multi-processor issues
like atomicity and volitility, and all that sort of stuff, in a
standardized way you can rely on.
Of course Ada has encapsulation. Better than C++'s, even.
