POV-Ray : Newsgroups : povray.off-topic : All that Windoze stuff Server Time
12 Nov 2026 01:47:39 EST (-0500)
  All that Windoze stuff (Message 16 to 25 of 25)
<<< Previous 15 Messages Goto Initial 25 Messages
Subject: Re: All that Windoze stuff
Date: 30 Oct 2007 21:44:40
Message: <4727ec18$1@news.povray.org>
Darren New wrote:
> Google "Excel vba interface" or "Excel com interface".
Or, come to think of it, fire up Excel and go into the help box and
search for "vba".
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 30 Oct 2007 23:24:13
Message: <4728036d@news.povray.org>
"Orchid XP v7" <voi### [at] devnull> wrote in message
news:4727aac0$1@news.povray.org...
> (I guess it's kind of moot anyway. I don't have access to any
> programming language that supports COM. No, I classify VB as "joke"
> rather than "programming language"...)
C#?
You might also try F#. I haven't personally used it, but I think is a
language you might like, and it's built on the .NET framework.
Date: 31 Oct 2007 06:40:15
Message: <48qgi351j3ct4qs3i25m5sr6kqo5trj77r@4ax.com>
>search for "vba".
Or, while in Excel, [ALT}+[F11] to open the Visual Basic Editor, then [F2] to open the
Object Browser window, at least in Excel 2000.
Date: 31 Oct 2007 16:00:20
Message: <4728ece4$1@news.povray.org>
So... can anybody provide a high-level overview of the general structure
and terminology of this stuff?
(All the documentation I found so far just shows examples in C - which
means nothing to me.)
Date: 1 Nov 2007 01:05:13
Message: <MPG.2191c7f6ff09542f98a05e@news.povray.org>
In article <4727abda$1@news.povray.org>,
nic### [at] gmailisthebestcom says...
> Javascript running under Windows Scripting Host (and under IE with very
> low security settings) can use COM. PHP has a COM extension too,
> although I have never tried it.
It should be noted that support for COM in those does **not** include
event management. That is only supported if you are running it IE, since
it has all the fancy bits in it that allow you to call Invoke. This is
apparently intentional, though I never quite got how knowing that you
fracking clicked on a button is more dangerous than a COM object that
tries to format your hard drive... I just don't get how disallowing
events did anything but make it a pain to do anything (though it does
work in IE, since IE supports an object event handler system, which lets
you link your own script function to the event. Its why, if you look in
the help for it, you will find that there are commands to both "link" an
event (don't remember the name of that) and a "GetRef" command used to
get the internal entry point to your script function, so that when the
event happens that function will be called. But without IE's event
manager, the linking command just generates a, "This command not
available", type error. :p
Its basically a serious pain in the rear. You can get past it by
introducing what is known as a ATL Bridge. Basically, ATL give more
direct support to the functions that are "needed" to tell Event A to
call your own code/script function. The problem is, the event cycle is a
bit wacky. Basically, you click the button, for example, it generates a
system level event, which is sent to your application, which is **then**
supposed to be sent to the event handler that is keeping track of who to
call when the event is received. Things like VB, MFC and Windows
Scripting Host, all pretty much leave you hosed, since they either don't
provide a way to *create* the needed link, or to even inform the object
that it should generate the event. But in some like MFC, the "event" is
not identified as one that belongs to your program, so is tossed back to
the OS, to die in obscurity, instead of being passed on to any handler
you "may" have. VB is a bit nicer, since you can trap arbitrary events
(harder to do in MFC, and impossible in WSH), but since you can't talk
to the core layer of the object to tell it that you "want" the event in
the first place, it won't tell you that it happened, let alone allow
your application to do anything about it.
Bloody mess...
void main () {
  If Schrödingers_cat is alive
    call functional_code()
  else
    call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 4 Nov 2007 03:10:43
Message: <472d7e83$1@news.povray.org>
news:4728ece4$1@news.povray.org...
> structure and terminology of this stuff?
> which means nothing to me.)
http://en.wikipedia.org/wiki/Component_object_model
Also - powershell from MS is free and does COM
Date: 5 Nov 2007 04:36:01
Message: <472ee401@news.povray.org>
Already read it. It's one of Wikipedia's less helpful articles. (Ditto
for all that .NET stuff.)
Um... OK. Maybe they have some documentation I can use...
Date: 6 Nov 2007 00:04:05
Message: <472ff5c5$1@news.povray.org>
I think it's more like, now that you know what it is (namely, an API for
communication between independent objects via an API-like interface),
what's your actual question? :-)
Date: 6 Nov 2007 04:22:34
Message: <4730325a$1@news.povray.org>
 From Wikipedia's article, it seems that COM's idea of what the terms
"object", "class" and "method" mean is somewhat different from the usual
OO terminology. (Or Wikipedia is outright incorrect, which is of course
not impossible.) Can anybody clarify?
Date: 6 Nov 2007 10:29:12
Message: <47308848$1@news.povray.org>
Invisible escribió:
>> for communication between independent objects via an API-like
>> interface), what's your actual question? :-)
It is a bit different from normal OO terms. Just wait until you get to
the "containment/delegation and aggregation" part (replaces uses of
inheritance), that's really screwed up.
