POV-Ray : Newsgroups : povray.off-topic : Nanocover Server Time
17 May 2026 11:54:58 EDT (-0400)
  Nanocover (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Nanocover
Date: 15 Oct 2007 06:11:57
Message: <47133ced$1@news.povray.org>
Bill Pragnell wrote:
> If they're less than 100 microns across
I meant nm, of course.
Date: 15 Oct 2007 06:43:13
Message: <47134441$1@news.povray.org>
> Fabric protectors (like Scotchgard) and water repellants have been
> available
> for ages (that's why people wax their cars), nothing "nano", just regular
> technology marketed under a hype branding. Also, not all (red) liquids are
> adhesive - depends on surface tension and cohesivity (mercury won't
> "stick",
> for instance).
Yep, it really does depend on what liquid they used.  I used to have a set
of marker pens for measuring the stickyness of surfaces (I forget what the
scale was, but they were numbered 1-50 or something).  The 1 was like
mercury, it would stick to nothing (not even normal paper) and would always
form blobs.  The 20-30 would mark and stick to pretty much anything (like a
permanent marker).  We were using them when we had problems with print not
sticking very well to plastic wrap.  They could have easily used a liquid
like I had in my marker pen #1 and it would pretty much "run off" of
anything you put in it.
One of the most interesting uses of "nanotech" would be to keep your car
windscreen clean, without the need for wipers or a cloth to get off splatted
flies.
Date: 15 Oct 2007 10:18:03
Message: <4713769b@news.povray.org>
>> available
>> are
>> "stick",
>> for instance).
> set of marker pens for measuring the stickyness of surfaces (I forget
> what the scale was, but they were numbered 1-50 or something).  The 1
> was like mercury, it would stick to nothing (not even normal paper) and
> would always form blobs.  The 20-30 would mark and stick to pretty much
> anything (like a permanent marker).  We were using them when we had
> problems with print not sticking very well to plastic wrap.  They could
> have easily used a liquid like I had in my marker pen #1 and it would
> pretty much "run off" of anything you put in it.
> splatted flies.
Indeed, and such coatings already exist in certain applications.  For
example, the application of TiO2 (titanium dioxide) on glass to create a
surface that is "self cleaning".  It's described as nano technology
because of the scale of the reaction that takes place and the thickness of
the coating, even though it's not nano technology in the sci fi
tiny-machines sense that most people think of.
Lance.
thezone - thezone.firewave.com.au
Date: 15 Oct 2007 10:37:05
Message: <47137b11@news.povray.org>
"Bill Pragnell" <bil### [at] hotmailcom> wrote
> Most nanotech is just particles at the moment, or nanoscale features on
> normal substrates. I think. Fullerenes count too, like buckyballs or
> buckytubes. There's all sorts of novel applications but it's mainly just
> paints and coatings at the moment. I think actual machines are quite a
> way off yet...
That's the bottomline. What's now called nano-science used to be known as
colloidal science (or in the other case, just solid state technology). Any
small molecule technically qualifies as a nano-particle as well. The
nano-science, as originally intended, hasn't come to fruition yet.
Date: 15 Oct 2007 10:57:55
Message: <47137ff3@news.povray.org>
>> way off yet...
Yah. Tiny machines swimming through bloodstreams etc is probably better
described as nano-engineering.
Date: 15 Oct 2007 12:25:12
Message: <47139468$1@news.povray.org>
"scott" <sco### [at] laptopcom> wrote in message
news:47134441$1@news.povray.org...
> splatted flies.
    Well, yes, good one, but I would say that one of the most useful would
be 'anti glare'. The glare from a windscreen when the sun is low(ish) is
certainly blinding and dangerous.
    ~Steve~
Date: 15 Oct 2007 22:12:55
Message: <47141e27$1@news.povray.org>
So what distinguishes it from chemicals?  Why isn't scotch-guard
"nano-tech"?
> I think actual machines are quite a way off yet...
They made working electric motors the size of logic gates some 10+ years
ago. I don't know if that counts, but I imagine it has advanced since then.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 15 Oct 2007 22:13:52
Message: <47141e60$1@news.povray.org>
> splatted flies.
That's called "Rain-X".  Go out and buy some. :-)
Date: 15 Oct 2007 22:15:08
Message: <47141eac$1@news.povray.org>
And polarized sunglass lenses don't do for you? :-)
Really, something that would cut light that's perpendicular to the
windshield would be cool. Like the larry niven blue-sun goggles.
Date: 16 Oct 2007 03:12:37
Message: <47146465$1@news.povray.org>
It would probably be illegal though.  Most countries have strict
requirements about the % of light that is transmitted through the front
windscreen and the front side windows.  AFAIK the specifications are not
detailed enough to deal with polarised light, but simply adding a polariser
would likely reduce the transmittance enough to fail the tests.
A further idea is to replace the screen with a LCD panel that has just one
huge passive pixel (=very cheap to make).  You automatically get polarisers
that will cut out any glare (assuming you align them correctly) and then you
just need a light sensor to dim the view when it is very bright - no need
for sunglasses!
