POV-Ray : Newsgroups : povray.off-topic : Nanocover Server Time
17 May 2026 11:54:58 EDT (-0400)
  Nanocover (Message 21 to 26 of 26)
Subject: Re: Nanocover
Date: 16 Oct 2007 22:22:42
Message: <471571f2$1@news.povray.org>
Darren New wrote:
> scott wrote:
>> One of the most interesting uses of "nanotech" would be to keep your
>> car windscreen clean, without the need for wipers or a cloth to get
>> off splatted flies.
> That's called "Rain-X".  Go out and buy some. :-)
Rain-X doesn't really keep it clean, it just makes water (and snow, for
that matter) sheet off it :)
I use it here - it's great none-the-less ;)
Lance.
thezone - thezone.firewave.com.au
Date: 16 Oct 2007 22:39:31
Message: <471575e3@news.povray.org>
Darren New wrote:
> Bill Pragnell wrote:
>> I'm not sure how scotch-guard works, and I think 'chemical' is a bit
>> of a nebulous term.
> Uh, less nebulous than "nanotech" I think.
>> I always thought nanotech refers to discrete artifacts smaller than a
>> micron (i.e., whose size is best measured in nanometres).
> You mean, like, molecules? :-)
> I always thought nanotech had to be "devices", like it says on the wiki.
Not necessarily.  Carbon nanotubes are a good example of nanotechnology
where initially you'd think that it wouldn't be called a "device".  If
something is just a physical structure, can it be a device?
That brings up the question of what is and isn't a device: Is a device
only something with moving parts?  If it is, then what about a laser?
Most people would consider it a device.  It's a bit of a grey area.  Is it
a device if it has no moving parts but performs a function by altering
things on/around it?  Well, then a simple TiO2 nano coating on glass could
be considered a device, and so could a nanolaser even if, again, it's just
a physical structure (in this case a nanowire attached to a substrate).
So, a lot of surfaces and physical structures can be considered devices,
and, if their details are of a nano scale, would fall under the term
nanotechnology.
Lance.
Date: 16 Oct 2007 23:34:14
Message: <471582b6$1@news.povray.org>
Well, I'd say a pipe is more a device than the water flowing thru it. It
may not be very active, but as I say, I consider "nanotech" to be based
on the physical structure of the item rather than the chemical behavior
as such.  I.e., if it's a nanotube because it's cylindrical and hollow,
it's "nano". If it's a nanotube because it's made out of carbon, then
that's chemistry.
I don't think the reality of the objective world is such that you can
separate the two concepts reliably. Things are what they are, and
chemical reactions happen because of the shapes of the molecules. So
it's kind of a pointless discussion that nobody is "right" about.
Feynman, the guy who invented the concept as such, described nanotech as
essentially that which you used nanotools to build. :-)
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 16 Oct 2007 23:35:10
Message: <471582ee$1@news.povray.org>
It takes most of the grime with it, tho. :-)  But yah, it's not what
Scott was talking about, but I figured he'd want to know.
Date: 17 Oct 2007 03:32:23
Message: <4715ba87$1@news.povray.org>
> It takes most of the grime with it, tho. :-)  But yah, it's not what Scott
Yes, useful input here.  I think I recall seeing similar, but they were
advertised very badly and I just dismissed them as "rubbish" that would
never work very well.  I will look out for a bottle to try out.
Date: 17 Oct 2007 06:06:05
Message: <4715de8d@news.povray.org>
'Artifact' in the sense that it's an artificial structure that couldn't
occur naturally. In general I wouldn't describe molecules as artifacts.
I guess buckyballs and buckytubes count as both as they do occur in
nature, albeit rarely. And I wouldn't class a single crystal as a
'molecule' either. :P
I guess it is a bit of a grey area.
>> I don't know anything about that. I think I heard of a demonstration
>> some time ago, but what would you use it for?
> To demo that you have the technology to create such things!
Publicity; like a nanoscale ad poster... I guess it makes people aware
of it. They'll be bringing out a low carbon-emission version next just
to get the climate change crusaders off their backs.
