POV-Ray : Newsgroups : povray.off-topic : Mac Plus vs AMD Dual Core Server Time
8 Jul 2026 01:32:54 EDT (-0400)
  Mac Plus vs AMD Dual Core (Message 51 to 60 of 170)
Subject: Re: Mac Plus vs AMD Dual Core
Date: 18 Oct 2007 04:00:48
Message: <471712b0@news.povray.org>
>> They don't!  If I open a blank Word document, that's 10 MB.
> ...which begs the question, "what are you using 10 MB for?"
I couldn't really care less.  10 MB is nothing on modern machines.  My
digital camera generates 10 MB per shot, it's not really making me lose any
sleep.
> There used to be word processors that would run inside less than 60 KB of
> RAM. Sure, nobody could argue they had the same features. And sure, I can
> see how adding lots more features would require quite a bit more RAM. But
> 10,000 KB? That's not "quite a bit more". That's 170 *times* more!
You have more than 170 times more RAM now though.
> ...the point being that software for the Amiga was designed to not
> *require* more than 2 MB in the first place.
What if you had an Amiga with only 512K or 1MB RAM?
What Windows software requires more than 1 or 2 GB of RAM anyway?
> (Because if it did, you just massively reduced your potential market.)
> Back then, software only used memory if it was absolutely, unavoidably
> necessary. Which is kind of my point...
Because you only had 2MB to spare, of course you couldn't include 600K of
fancy bitmaps in RAM, a thesaurus, dictionary and grammar checker, you made
a "bare bones" word processor that basically did the bare minimum to produce
documents.  Now you can do all that cool stuff and of course it uses more
RAM.  What's your point?
> (To actually answer your question, if you ask AmigaOS for 2.5 MB of RAM
> when only 2 MB of physical RAM exists, you get a message that amounts to
> "no, go away". One of the ways they kept the Amiga cheap was by not
> including the hardware necessary for implementing virtual memory...)
So what if you take an AmigaOS program that tries to use eg 1.5 MB of RAM
and run it on an old Amiga that only has 1MB?  It doesn't work.  What
happens when you try to run a modern piece of software on an older PC?  It
works ... but very slowly.
If you prefer the Amiga option, then just switch off virtual memory in
Windows.
Date: 18 Oct 2007 10:56:43
Message: <4717742b@news.povray.org>
chromatograms? what kind of chromatograms?
I regret not getting to this thread sooner. We do have lab equipment
connected to PC's that use older interfaces.
There is an old Dell Inspiron 7000 (366MHz, 256mb RAM) running WinXP
connected to a Sartorius SC2. We used this old laptop while new Dells don't
come with rs232 ports.
We also have a couple of Pentium IV machines with equipment connected via
ISA-slot GPIB cards. These also run WinXP, but one has 512mb RAM and
another has 1GB. All of these have far more RAM than they need for what
they do, but they have never had access to the internet, never had any
Windows updates, and aren't as bloated as typical office or personal
computers as a result of that. We even had to call in our registrations for
the Windows software just to avoid the risk of plugging into an ethernet
port to register.
Orchid XP v7 wrote:
> scott wrote:
>>> No. Our normal *lab* environment. ;-) The *office* just runs Word and
>>> Access. (And the guys in the lab insist on using Excel a lot...)
>> And I expect the guys in the office often want to include fancy graphics
>> into their Word documents, perhaps just company logos on a letter, or
>> photos/diagrams in a report.
> Not really, no.
> Just chromatagrams. I gather that they're quite large... (Well, the data
> is almost always very noisy.)
>> All of which rapidly use up memory and
>> which would slow down hugely on a very slow machine.
>> Sure, they could use a plain text editor on an ancient machine with 32K
>> of RAM, but it's not going to look very professional.
> My point is not so much that we should go back to using 32K machines,
> but rather that we should go back to the days of programs only using
> more than 32K if they *need* it for something. ;-)
Date: 18 Oct 2007 13:07:50
Message: <471792e6$1@news.povray.org>
Darren New wrote:
>> One of the ways they kept the Amiga cheap was by not including the
> The CPU didn't even support it, just like pre-386 days.
Correction: The Morotola 68000 series *does* have an optional MMU. And
that's just it - optional. There was a special board you could get to
install a replacement CPU with an MMU fitted, and software to go with it
to add virtual memory to your Amiga.
So there. :-P
Date: 18 Oct 2007 13:12:40
Message: <47179408$1@news.povray.org>
> any sleep.
A digital camera uses 10 MB for a reason - it's capturing a highly
detailed digital image. That kind of thing requires storeage space. I
have no problem with that.
>> of RAM. Sure, nobody could argue they had the same features. And sure,
>> I can see how adding lots more features would require quite a bit more
>> RAM. But 10,000 KB? That's not "quite a bit more". That's 170 *times*
>> more!
...so it's OK to waste 170 times more RAM?
And that's just my point. Just because we have all this stuff available
does *not* mean it should just be wasted on inefficiency. Just think
what the hell we could do with all this stuff if it wasn't being wasted
all the time...
Apophysis. ;-) Not that that matters here...
> of fancy bitmaps in RAM, a thesaurus, dictionary and grammar checker,
> you made a "bare bones" word processor that basically did the bare
> minimum to produce documents.  Now you can do all that cool stuff and of
> course it uses more RAM.  What's your point?
My point is that 20 years ago I had a word processor with a spell
checker and it didn't require 10 MB.
> RAM and run it on an old Amiga that only has 1MB?  It doesn't work.
> What happens when you try to run a modern piece of software on an older
> PC?  It works ... but very slowly.
> Windows.
Apparently you still don't understand what I'm trying to say...
Date: 19 Oct 2007 00:35:11
Message: <471833ff$1@news.povray.org>
Right.  A replacement CPU.  I.e., the 68000 didn't support virtual
memory. The 68010 did. So you replace the 68000 with a 68010, and you
can do virtual memory.
And the 68020 supports 32-bit addressing.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 19 Oct 2007 13:09:01
Message: <4718e4ad$1@news.povray.org>
I emphasise: The Morotola 68000 *series*. (Of which different Amigas had
varying versions.)
My point is, the hardware supports it if you pay extra money. It's just
an extra-cost option rather than standard like these days. (There was
also a big performance hit, IIRC...)
Date: 19 Oct 2007 18:18:20
Message: <47192d2c$1@news.povray.org>
> varying versions.)
Really? I thought they were all 68000.  OK.
Date: 20 Oct 2007 04:27:35
Message: <4719bbf7$1@news.povray.org>
Darren New wrote:
>> had varying versions.)
For example, the Amiga 1200 shipped from the factory with the 68020
running at 14 MHz. (Actually, the 68EC020, which lacks the MMU.)
IIRC, I later upgraded mine to a 68030 + FPU...
Date: 22 Oct 2007 02:44:23
Message: <471c46c7$1@news.povray.org>
> (There was also a big performance hit, IIRC...)
So, asking a program to use 3MB of RAM on a 2MB Amiga with the VM support is
different to you trying to use more than 256MB on your Windows machine how?
Date: 22 Oct 2007 02:53:32
Message: <471c48ec$1@news.povray.org>
That you'd prefer 99% of your RAM to be left unused, while sitting at very
basic and streamlined versions of the OS and all applications (that the
developers have spend years optimising RAM usage to a bare minimum and so is
generations behind what is normal today and 5x the price)?
Perhaps I don't understand then...
