POV-Ray : Newsgroups : povray.off-topic : c++ memory question Server Time
10 Jun 2026 18:25:33 EDT (-0400)
  c++ memory question (Message 3 to 12 of 22)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: c++ memory question
Date: 2 Oct 2007 18:46:08
Message: <op.tzldjaptcs6ysw@e6600>
On Wed, 03 Oct 2007 00:36:05 +0200, Samuel Benge
<stb### [at] THIShotmailcom> wrote:
> If I create an array like so: int i[20];, and then proceed to assign
> values for each entry, must I then delete it at some point?
No. Indeed, you must not, as it is not dynamically allocated.
> Is the memory used by that array freed after the program is terminated?
It is freed when 'i' goes out of scope. If 'i' is in namespace scope, it
goes out of scope when the program ends.
FE
Date: 2 Oct 2007 18:47:33
Message: <4702ca85@news.povray.org>
Vincent Le Chevalier wrote:
> What you make whith the instruction int i[20]; is a static array, that
> is allocated in the stack if I remember correctly. You do not have to
> manage the memory in the stack, so no free or delete.
Hmm, that's good to know.
> Try googling for "static dynamic array C++", it should bring you
> something useful...
> Hope this helps
Yes, it does. Thanks! I'm off to use Google for the umpteenth time today!
Sam
Date: 2 Oct 2007 18:49:02
Message: <4702cade$1@news.povray.org>
Thank you. My program should not have any memory leaks, then. I assume
this also applies to other variables as well?
Sam
Date: 2 Oct 2007 18:49:47
Message: <4702cb0b@news.povray.org>
Samuel Benge <stb### [at] thishotmailcom> wrote:
> It's probably a stupid question, but here goes. I know that for every
> "new", there must be a delete.
> So here's the question. If I create an array like so: int i[20];, and
> then proceed to assign values for each entry, must I then delete it at
> some point?
  Odd question, given that you answered it even before you asked it.
  If you deleted it, you would have more deletes than news, which would
break the "for each new, delete" rule.
> I didn't use a "new" flag to initialize the array. Is the
  No. It's freed when it goes out of scope.
Date: 2 Oct 2007 18:52:52
Message: <4702cbc4$1@news.povray.org>
>> it goes out of scope when the program ends.
Everything that wasn't new-ed.
Normally the OS frees the memory used when the program ends anyway... So
I don't understand exactly what you observe in your game. You mean it
takes more memory when it runs for the 6th time than it took the first time?
Vincent
Date: 2 Oct 2007 18:55:05
Message: <op.tzldx8fmcs6ysw@e6600>
On Wed, 03 Oct 2007 00:50:20 +0200, Samuel Benge
Only objects that are dynamically allocated - i.e. with 'new' - need to be
explicitly deallocated. You may not need to use 'delete' at all if you use
standard library containers and/or smart pointers.
FE
Date: 2 Oct 2007 19:13:06
Message: <4702d082@news.povray.org>
> time?
I mean when I monitor my system's memory usage, more memory is being
used AFTER I close my program. But after several runs, the memory is
returned to an earlier state.
Sam
Date: 2 Oct 2007 19:14:17
Message: <4702d0c9$1@news.povray.org>
> be explicitly deallocated. You may not need to use 'delete' at all if
> you use standard library containers and/or smart pointers.
Okay, it's good to hear it from several people.
I use a DirectX game engine which requires a few "news", but I always
delete them when I am through with 'em.
Sam
Date: 2 Oct 2007 19:17:08
Message: <4702d174$1@news.povray.org>
I knew I'd get this response from someone. I was just worried about the
non-new declaration of arrays and variables, but I am clear on those now.
Indeed. This happened with my maze game, and I got a warning about it.
>> I didn't use a "new" flag to initialize the [static] array. Is the
Cool. Thanks!
Sam
Date: 2 Oct 2007 19:20:49
Message: <4702d251$1@news.povray.org>
I don't think the problem is in your program, then. When it does not run
anymore, it does not use memory anymore, at least on modern OSes...
Perhaps you could try to find a way to monitor the memory per process,
rather than the whole.
Vincent
