POV-Ray : Newsgroups : povray.off-topic : The Raysnail - WIP, a probability based raytracer with (limited) support for PovRay SDL files : Re: The Raysnail - WIP, a probability based raytracer with (limited)suppor= Server Time
12 Nov 2026 16:34:11 EST (-0500)
Date: 19 Jul 2024 04:26:16
Message: <669a2328@news.povray.org>
Op 18-7-2024 om 19:49 schreef Bill Pragnell:
>> Even better, 'stochastic' is also supported by version 3.8! I generally use:
>> +am3 +a0.01 +ac0.90 +r3
>> and in the radiosity block a count between 10 and 50
>> varying +a, +ac and +r values increases/decreases the stochastic quality
>> (and render time!).
> Are we talking about the same thing here?
> I was referring to the unbiased purely stochastic version of radiosity, which
> was a significant change to the algorithm; I was under the impression that this
> wouldn't end up in main POV-Ray in the form it was implemented in UberPOV. Maybe
> I missed something, is this in v3.8 now, or are you referring to improvements to
> sampling alone?
Ah. This I do not know for sure. I am using the 'latest' v3.8-beta2, and
as far as I can remember, the use of the stochastic implementation there
is identical(?) to what was implemented in UperPOV. I am afraid this is
all I can remember from those days, back in 2014, if I am correct. Using
+am3 automatically switches on the stochastic render and I suppose
(wrongly maybe) that this directly influences the radiosity, but if this
then is a [quote] unbiased purely stochastic version of radiosity
[/quote] I do not know indeed. This would need the comment of an expert
(Christoph Lipka! where are you?). All I know is that it works fine
as-is, and I have been using it ever since with v3.8-beta or v3.8-beta2.
Sorry for not being able to be more specific. :-[
