There are still quite a few object in the collection at
http://objects.povworld.org
Would it be possible to merge the two, since that collection hasn't been updated
since 2003?
Just a suggestion.
Also, I'd be willing to submit my Christmas Ornament bulb model and my LED
display macros, if anybody were interested...
A.D.B.
> since 2003?
I think that can't be done without permission from the authors of each
object.
> > since 2003?
> object.
It's a shame, really. The official online object collection library is
an excellent idea, but it seems that it hasn't really catched up, and there
haven't been many submissions. It would really benefit from a library of
thousands of entries instead of just 31.
Some people have suggested that we start creating objects about certain
topics. This, of course, is a slow process which would require volunteers.
How about this idea instead: Volunteers who have made a lot of POV-Ray
images in the past, could go and dig those old scenes and take interesting
objects out of them, clean them out and create include files from them and
contribute them to the object collection. (That's actually what I have done
with all my submissions.)
It seems to me that the 'object' collection really wants to be a 'macro'
collection. This would serve a somewhat divergent purpose from an
'object' collection in my mind.
Strictly an 'object' collection, it seems to me, acts like a trove of
antiques in a shop. You rummage there for oddities, particular things,
to be used more or less as found. In that paradigm, the idea of
'thousands' of items makes sense.
But right now, it seems, submissions need to occupy a sort of
intersection set. They must be objects, but objects built procedurally
from macros, and ideally using csg techniques. This can put a submitter
wanting to create interesting objects at cross-purposes. Such an
intersection set of requirements can be restrictive. Modularity does not
usually lend itself to particularity.
It would be better to define and recognize the true nature of the
effort. This would be to build macros of all kinds, including csg-object
macros, and which serve manifold purposes. The classic example here,
would be the MakeTree macro. One little macro, trees, bushes, coral,
blood vessels,...lots of variety. The sense of variety, and more so, the
sense of usefullness of the collection, lies precisely in the level of
usefulness, the manifold scope, of the core macros in the collection.
Then requirements of modularity become the strength rather than a
restriction.
This would also remove a taint of hegemony. The hegemony that an
'official POV object' must be a csg object, or at the outside, something
procedurally produced. I admire a useful macro. I resent having to
conform to a particular method of producing objects. And I just can't
shake the feeling that such a hegemony of conformity is the true thrust
behind the 'object' collection as it is now defined.
"Jim Charter" <jrcsurvey [at] msn com> wrote in message
news:47eb3b2d@news.povray.org...
> collection. This would serve a somewhat divergent purpose from an 'object'
Hi Jim,
I think it can develop in either direction and I'm not convinced that one
direction is necessarily better than any other. At the moment there's a
mixture of both, with some pure objects (e.g. the Earth and the Sun) and
some pure macros (e.g ScaleConvert).
Many are mixed within a single submission, for example, the road signs
'macro' incorporates about 40 prism object definitions that can be used
independently or with the accompanying macros (that use them as pigments).
The Chess board has a number of object definitions along with a macro for
positioning them using a standard chess notation. I think the freedom to
pick and mix is good.
> antiques in a shop. You rummage there for oddities, particular things, to
> be used more or less as found. In that paradigm, the idea of 'thousands'
That's a good analogy, but it's like if you go rummaging for a particular
historical jelly mould and you only find a mould-making press. So it might
take a bit more study, work and time to make the mould, and it may not be
suitable for everyone, but it may end up being the best and quickest way to
get to what you want.
> But right now, it seems, submissions need to occupy a sort of intersection
> set. They must be objects, but objects built procedurally from macros, and
There are no such constraints. Individualy crafted objects are most welcome
and they don't need to be CSG'able. In fact they don't even need to be
objects. There are categories for textures and media definitions and there's
the scaleconvert macro that doesn't have or generate any objects.
> This can put a submitter wanting to create interesting objects at
> cross-purposes. Such an intersection set of requirements can be
> restrictive. Modularity does not usually lend itself to particularity.
Anyone wanting to submit an object should do so. Don't feel constrained.
It's a hobby. Do what you enjoy doing and share the bits you think may help
others.
As mentioned above, there are no constraints to prevent anyone submitting
any object. The only requirement is for naming standards, intended to enable
people to use objects in combination within their scenes. Even with this
there's an option on the web site to submit non-standard objects if your
variable and macro names don't conform.
I don't really see that there's necessarily conflict between modularity and
particularity though. The staircase macros are modular, but generate
particular, clearly recognisable forms. Furthermore, all of the components
can be readily switched to generate an individualised and unique staircases.
> It would be better to define and recognize the true nature of the effort.
> This would be to build macros of all kinds, including csg-object macros,
> and which serve manifold purposes. The classic example here, would be the
> MakeTree macro. One little macro, trees, bushes, coral, blood
> vessels,...lots of variety. The sense of variety, and more so, the sense
> usefulness, the manifold scope, of the core macros in the collection. Then
> requirements of modularity become the strength rather than a restriction.
I think the true nature is that it's open to people to take it in whatever
direction pleases them. I would encourage anyone with a particular interest
to use the site to pursue that interest. I certainly have a personal leaning
towards building flexible macros, but I would equally encourage those
interest in creating individual objects or groups/categories of objects to
I think that different people enjoy creating different things and that this
ties in very well with the diverse needs of people looking to use objects.
There could be a time when I just want a bunch of different objects to line
up on a shelf somewhere in the background of a scene. Other times I may want
to be able to generate a very specific and individualy tailored object such
as a tree that will be unique to my scene.
Sometimes individually crafted, non-changeable objects (even quite simple
ones) can take on an almost iconic status and could prove enormously
popular. For example, I think your seal punch and ink bottles look great and
would be very popular in any form. Any configuration options, like being
able to depress the handle of the punch or adjust the bitmapped image would
add the ability for people to individualise scenes that use them, but would
be icing on the cake from my point of view.
This term had me looking for my dictionary and I'm still not quite sure how
to interpret the paragraph. Are you saying that you think there's some sort
of Mafioso power struggle or control thing going on somewhere?
Constraints on what can be added into the collection are very minimalistic
and mostly consist of simple naming conventions intended to try and avoid
conflicts when multiple objects are used in the same scene file. Anyone can
register and submit stuff directly into the collection and is therefore free
to steer the collection in more or less any direction they are motivated to
follow. Anyone can download, tailor and upload or redistribute objects.
There isn't any requirement for anyone to conform to a particular method of
producing objects and I'd argue that this is illustrated by the diversity of
objects and macros that are already there.
My personal thrust is to try and build up the collection so that it moves up
the list of places people look at when they want something and so that they
feel proud to contribute. I'm hoping there's a sort of critical mass beyond
which this takes care of itself. I'd like to think we're getting close to
that now because, although it's only got 32 entries quite a few of those can
generate multiple objects. I think the more people find that they can use
the more they'll see value in contributing.
Forward thrust imparted by others, in whatever direction, has been most
welcome and will ultimately be what makes this collection work. I haven't
observed any thrust that seemed in any way surreptitious.
Chris B.
I don't see that kind of restriction anywhere? AFAIK *anything* can be
submitted to the object collection.
Of course if the object is made an easy-to-use include file, which has
been cleaned up, and which might have some configuration properties (such
as, for example, being able to override textures), all the better, but
I can't see it as a requirement anywhere.
Thanks for your reply at length. I'll give it all more thought.
There was some talk that made that idea known without it being made
explicit. But water under the bridge. Chris was expansive on that
issue in his reply.
But my critique is also a suggestion that a closer definition of the
goals might somehow produce better motivation. It's a half-baked idea,
I admit, but I wanted to air it out.
Again, just a few useful macros could make for a successful collection.
Does it need any specific goal? IMO anything you want to submit which
might be useful to someone is ok. Made a small object some time ago?
Or perhaps a macro which does something useful? An interesting isosurface?
IMO anything goes.
> collection.
Only because that's what most of the submissions are at the moment.
This could easily change.
...Ben Chambers
www.pacificwebguy.com
