POV-Ray : Newsgroups : povray.object-collection : CoffeeMug 2.0 with textures! Server Time
24 May 2024 15:06:04 EDT (-0400)
  CoffeeMug 2.0 with textures! (Message 1 to 1 of 1)
Subject: CoffeeMug 2.0 with textures!
Date: 5 Mar 2015 18:37:57
Message: <54f8e8d5$1@news.povray.org>
I lied.  A couple of function arguments slipped by me in versions 1.3
and 1.3a, with the result that these versions are not /completely/
namespace compliant.  (Although function arguments are not specifically
mentioned in the compliance rules, they can cause problems.)  The
offending function, which was not documented in the user manual (and
which you therefore should not have been using), has been deleted in
version 2.0.  If you are incurious about the wonderful 2.0 improvements,
and are satisfied with the severely limited and inadequate texture
options in version 1.3a, you can fix coffeemug.inc 1.3a by globally
replacing RMajor and rMinor with CoffeeMug_P0 and CoffeeMug_P1,
respectively.
However, you will no doubt want to apply patterns and image maps to your
coffee mugs without going through a whole lot of trouble.  In CoffeeMug
2.0, the pigment and texture macros can apply general pigments and
textures to the mug with cylindrical mapping.  Previously, the macros
could only apply object masks.
But wait, there's more!
  - A macro is added to compute the stacking height of a mug, so
    you can show some mugs neatly stored on a shelf.
  - A shortened prefix has been introduced to save typing and
    unwieldy-looking code.  The old prefix still works, of course.
http://lib.povray.org/searchcollection/index2.php?objectName=CoffeeMug&contributorTag=Cousin%20Ricky
