POV-Ray : Newsgroups : povray.object-collection : New (Experimental) Index Page Server Time
29 May 2024 06:25:55 EDT (-0400)
  New (Experimental) Index Page (Message 16 to 25 of 25)
Subject: Re: New (Experimental) Index Page
Date: 22 Jun 2008 03:50:00
Message: <web.485e035c133a8f91896db6a10@news.povray.org>
Also, you might want to consider adding the "optgroup" element to the category
form to keep people from adding to the super-categories when submitting
objects.
-Mike
Date: 22 Jun 2008 05:36:43
Message: <485e1d2b$1@news.povray.org>
"SharkD" <nomail@nomail> wrote in message
news:web.485e01e9133a8f91896db6a10@news.povray.org...
> Will it be possible in the future to add an object to both the Area of
> Interest
> and Content Type categories?
It should be possible now because it's a multi-select list. When you're
submitting an object you should be able to use Ctl-Click in the browser to
select multiple categories and sub-categories. Though the mechanism for
doing a multi-select may vary between browsers and operating systems.
> Also, will it be possible to modify an existing entry without having to
> fill out
> all the fields and upload files from scatch? Sometimes you just want to
> fix a
> typo, or update a file without changing its description.
This is a little more problematic. Certain functions of this sort can be
done by an administrator but it needs a bit of consistent judgement to make
sure that significant changes aren't made without changing the version
number, otherwise people wouldn't be able to tell that an object had changed
since they downloaded it.
So for changing typos within the description, keywords and possibly for
small changes to documentation files and other meta-data you can email an
admin or post a request here.
For changing files that fix problems with the object or change functionality
you should create a new version which means uploading a complete new copy.
There are times when it may make sense to make an exception to this. For
example, if you forget a file or fix a bug and you can get an administrator
to upload it for you before anyone's downloaded it, then I don't see a
problem with that.
Chris B.
Date: 22 Jun 2008 13:05:00
Message: <web.485e85a8133a8f9123ce54f40@news.povray.org>
Thanks, I didn't notice that.
Well, a step in this direction would be to only require a version number change
if any new files are uploaded. Of course, this would as a result be triggered
any time *any* file is uploaded, regardless if the actual code hase changed.
However, despite this quirk it would still be an improvement.
Thanks for your reply.
-Mike
Date: 22 Jun 2008 19:35:00
Message: <web.485ee164133a8f9123ce54f40@news.povray.org>
> "Warp" <war### [at] tagpovrayorg> wrote in message
> news:47fc07f4@news.povray.org...
> >> I'm running on 1024x768. Are
> >> you running on a higher resolution?
> >  1600x1200.
> ok now that resolution is beyond what I can test :-)
> Is the text showing up ok at that resolution? I have used a small font.
There's a site called BrowserShots.org that will load any wab page in any of
about 40 different browsers and then upload a screenshot of what the site looks
like within that browser. You can pick which browser to test (you can test more
than one at the same time), choose from different operating systems and choose
from among several other options such as disabling JavaScript ot Flash. It's
simple and very convenient.
-Mike
Date: 22 Jun 2008 19:40:00
Message: <web.485ee24a133a8f9123ce54f40@news.povray.org>
I searched for an email address in order to take you up on that suggestion, but
wasn't able to find any. Who do I email?
-Mike
Date: 23 Jun 2008 03:51:56
Message: <485f561c@news.povray.org>
news:web.485ee24a133a8f9123ce54f40@news.povray.org...
> suggestion, but
It's on the members page at http://lib.povray.org/members/
Chris B.
Date: 23 Jun 2008 15:57:37
Message: <48600031$1@news.povray.org>
news:web.485e035c133a8f91896db6a10@news.povray.org...
> category
> objects.
> -Mike
Makes sense. I've modified the script that generates the multi-select.
Chris B
Date: 29 Jun 2008 21:00:01
Message: <web.4868300f133a8f91feb17ab00@news.povray.org>
Here's another idea: add a "New!" indicator to objects that are, say, less than
two months old. I suggest a red font color.
-Mike
Date: 29 Jun 2008 21:05:01
Message: <web.48683073133a8f91feb17ab00@news.povray.org>
> Regards,
> Chris B
You should probably mention somewhere in the submission form that you can make
multiple selections. As I said earlier, I didn't notice it and had to ask.
-Mike
Date: 30 Jun 2008 04:54:27
Message: <48689f43@news.povray.org>
news:web.48683073133a8f91feb17ab00@news.povray.org...
>> Regards,
>> Chris B
> make
> -Mike
When you move into the multi-select panel the help message at the top of the
screen describes using Ctrl-Click to select multiple items.
Chris B.
