POV-Ray : Newsgroups : povray.object-collection : Sphere Sweep 1.2 Quadratic spline question : Re: Sphere Sweep 1.2 Quadratic spline question Server Time
17 Nov 2025 09:27:46 EST (-0500)
Date: 31 Aug 2020 19:35:00
Message: <web.5f4d88264d3847421f9dae300@news.povray.org>
> SVG's quadratic curve uses 2nd order Bézier splines, while
> SSWP_QUADRATIC_SPLINE uses POV-Ray's built-in quadratic spline type,
> which connects the control points with parabolic curves.  They are two
> different spline types.
I /thought/ that might be the case.
> To get an SVG style quadratic curve, you would need to use
> SSWP_BEZIER_SPLINE, and clone the middle control point:
> Unfortunately, the Bézier algorithm in SphereSweep 1.2 does not handle
> such cloning properly.  You'll need to replace macro SSwp__Bezier_calc()
> in spheresweep.inc with the following:
Weird, but glad you had a quick fix all ready to plug in.  :)
> It is under consideration.  In any case, the Bézier algorithm patch will
> definitely be in the next update.
Thanks very much - that fixed the bumpiness of the outlines.
Now I have to figure out why the SVG splines render oh-so-very nicely in a
browser, but have all sorts of apparently extraneous lines and scribble when
converted over to sphere sweeps...
