POV-Ray : Newsgroups : povray.newusers : Images are pixelated Server Time
3 Aug 2025 12:12:57 EDT (-0400)
  Images are pixelated (Message 1 to 10 of 12)
Subject: Images are pixelated
Date: 16 Dec 2024 22:55:00
Message: <web.6760f5334f03bcfb264ac0beab67afd2@news.povray.org>
Hello, the images are pixelated for some reason
How I correct this? I am using povray 3.7
Download '005027.png' (1674 KB)
Preview of image '005027.png'
Subject: Re: Images are pixelated
Date: 17 Dec 2024 03:05:29
Message: <676130c9$1@news.povray.org>
I think this is because Antialiasing is not active by default, you
should enable it.
For example, with these flags, you get a quality antialiasing:
+a0.01 +am2 +r3
If rendering takes to much time (especially if you use radiosity), you
can set +r3 to +r2 or +r1 to decrease traced rays.
More infos on this wiki page:
http://www.povray.org/documentation/view/3.6.2/223/
Date: 17 Dec 2024 07:13:01
Message: <67616acd$1@news.povray.org>
How did you manage to get that pixelation ? Did you double the size of
the image after rendering ?
You should do :
1) Render directly at the desired resolution.
1.1) Some will render at double resolution then scale down by one half.
2) Use antialiasing. The presets do include some antialiased options.
The usual antialiasing use +a0.3 +am1 +r3. That's acceptable in high
contrast scenes.
In most cases, it's better to use more aggressive settings, like :
+a0.1 +am2 +r3
You may want to go farther, and use +a0.05 all the way down to +a0.001.
Using +am1 will often cause some glitches at the edges of the render
blocks. +am2 is much better as it never cause any glitches in those areas.
Date: 17 Dec 2024 08:35:00
Message: <web.67617d4ede28e8e4264ac0beab67afd2@news.povray.org>
> From: antoine
where exactly do I put this? I tried to write +a0.01 +am2 +r3 in the .pov file
but it gave an error
> From: Alain Martel
I didn't do anything, I downloaded povray yesterday and it was already like this
when I tested the example models. The resolution is 512 x 384, is this normal?
Can I change this?
Date: 17 Dec 2024 09:50:00
Message: <web.67618e78de28e8e4471fd7cd25979125@news.povray.org>
"gulino" <nomail@nomail> wrote:
> > From: antoine
> > From: Alain Martel
> Can I change this?
if it's on Windows, you have the drop-down menu to select the resolution and
stock anti-aliasing settings.
you also have the "command line" section at the top of the editor to input any
render control settings.
Linux users can chime in, or you can check out the instructions on
wiki.povray.org
https://wiki.povray.org/content/Reference:Tracing_Options#Anti-Aliasing_Options
- BE
Date: 17 Dec 2024 10:05:00
Message: <web.676192e2de28e8e4b2e841a6cde94f1@news.povray.org>
hi,
> > > From: antoine
> > > From: Alain Martel
> > Can I change this?
<https://wiki.povray.org/content/Documentation:Tutorial_Section_2.2#Setting_POV-Ray_Options>
the 'povray.ini' file, for instance, is a "good place" to set your preferred
default resolution, and other stuff.
regards, jr.
Date: 17 Dec 2024 10:08:25
Message: <676193e9$1@news.povray.org>
Le 2024-12-17 à 08:31, gulino a écrit :
>> From: antoine
Those are Command Line parameters.
You don't write «+a0.01 +am2 +r3» in the scene file itself. You write it
in the «Command line» box located right from the resolution Drop list.
>> From: Alain Martel
> Can I change this?
That resolution, [512x384, No AA], is the one selected by default when
you render your first scene. You can easily change it. Just click on it
and select the resolution that you want to use.
The one just under is [512x384, AA 0.3]. The «AA 0.3» mean antialias
enabled with threshold set at 0.3.
On Windows ? Look at the line just above the editor, all the way to the
left. That's a drop list from where you can select carious resolutions
and enable AA.
You can change it's content by editing the quickres.ini file. From the
menu bar : Tools|Edit resolution INI file.
Date: 17 Dec 2024 10:30:00
Message: <web.676198f0de28e8e4264ac0beab67afd2@news.povray.org>
Ok problem solved, merci
I am using +a0.01 +am2 +r3 with 1028x768 No AA and looks good.
Date: 20 Dec 2024 12:45:00
Message: <web.6765ac77de28e8e4e83955656e066e29@news.povray.org>
> > like this when I tested the example models. The resolution is 512 x 384, is
> > this normal?
> > Can I change this?
Yes, and the drop-down menu has all of the various resolutions that are included
in a file called 'quickres.inc'. You can add to or change those default
resolutions by editing that file. If it is not already open in your POV-ray
editor window in the Windows GUI, go to the 'Tools' tab at the top and select
'Edit resolution INI file.' That will open quickres.ini. Then you can write-in
other resolutions.
For example, the following is, I think, one of the default resolution blocks
there:
[512x384]
Width=512
Height=384
Antialias=On
Antialias_Threshold=0.3
You can write a new one:
[1920X1080 widescreen]
Width=1920
Height=1080
;Antialias=On
;Antialias_Threshold=0.3
Then the drop-down resolution menu will include that for your later use. (The
semicolons can be used to commment-out those particular entries, just like using
double-slashes // for comments in a scene file.)
My own quickres.ini file is chock-full of customized entries!
Date: 20 Dec 2024 13:50:52
Message: <6765bc8c$1@news.povray.org>
>>> this normal?
>>> Can I change this?
> other resolutions.
> there:
> [512x384]
> Width=512
> Height=384
> Antialias=On
> Width=1920
> Height=1080
> ;Antialias=On
Mine have at least double the number of entries of the default one,
including wide screen, double screen, double wide, triple screen and
triple wide options.
