POV-Ray : Newsgroups : povray.newusers : normal Server Time
14 Sep 2025 12:31:33 EDT (-0400)
  normal (Message 1 to 3 of 3)
Subject: normal
Date: 30 Nov 2024 18:55:00
Message: <web.674ba549218568e4e3cbe740b3ec8729@news.povray.org>
Hello,
I'm trying to add normals to triangles.
Let's say I've got this mesh2 object:
mesh2 {
  vertex_vectors {
    4
, <-4.22827, 3.07201, 49.7261>, <-3.49716, 3.88399, 49.7261>, <-10.3386,
11.4822, 47.5528>, <-12.5, 9.08178, 47.5528>  }
  face_indices {
    2
, <2, 0, 1>, <0, 2, 3>
  texture { pigment { color rgbf <0.976471, 0.843137, 0.172549, 0> } }
  finish { MATERIAL } interior { MATERIAL_INT }
This renders fine.
So next step, adding normals.
Am I right that I need to do the following:
- for each triangle, e.g.:
  p1: <-10.3386, 11.4822, 47.5528>, p2: <-4.22827, 3.07201, 49.7261>, p3:
  and
  q1: <-4.22827, 3.07201, 49.7261>, q2: <-10.3386, 11.4822, 47.5528>, q3:
  calculate the normals:
    normal 1 = (p2 - p1) * (p3 - p1)
    normal 2 = (p3 - p2) * (p2 - p1)
    normal 3 = (p2 - p3) * (p2 - p1)
    normal 4 = (q2 - q1) * (q3 - q1)
    normal 5 = (q3 - q2) * (q2 - q1)
    normal 6 = (q2 - q3) * (q2 - q1)
- then put those normals in a:
  normals_vectors {
     6, (normal 1), (normal 2), etc.
But then I'm lost. What should I put in normal_indices { } ?
Subject: Re: normal
Date: 30 Nov 2024 19:55:00
Message: <web.674bb2d836845861f9dae3025979125@news.povray.org>
Look this over, and see if that helps you any.
https://news.povray.org/povray.general/thread/%3Cweb.6394bb44855140c41f9dae3025979125%40news.povray.org%3E/
- BW
Subject: Re: normal
Date: 2 Dec 2024 06:05:00
Message: <web.674d9316368458616086ed06830a892@news.povray.org>
> Hello,
> mesh2 {
>   vertex_vectors {
>     4
>   face_indices {
>     2
> This renders fine.
>   and
>   normals_vectors {
Normal indices list is optional if there is the same number of normals and
vertices. If so, the indices from the face_indices{} list are used instead.
Otherwise, each entry of the normals list points to what vertices a normal
should be applied. thus providing "shared normals" groups usefull in case of
partly smooth partly flat models... cf docs:
https://www.povray.org/documentation/view/3.60/68/
