POV-Ray : Newsgroups : povray.newusers : import point cloud data in POV-Ray Server Time
18 Jun 2024 11:04:58 EDT (-0400)
  import point cloud data in POV-Ray (Message 1 to 2 of 2)
Subject: import point cloud data in POV-Ray
Date: 15 Aug 2022 01:45:00
Message: <web.62f9dc1bded0d72de55afb3e9c51c6c@news.povray.org>
I generated a dense point cloud data for the forest scenario(.las format), how
can
I import the point cloud data of the forest in POV-ray, or what type of object
do I need to define the point cloud data as?
Subject: Re: import point cloud data in POV-Ray
Date: 15 Aug 2022 11:30:58
Message: <62fa66b2@news.povray.org>
> can
what do you want to visualize ?
Looking up for las format, I found lidar related data, is that correct ?
https://en.wikipedia.org/wiki/LAS_file_format
Which of the eleven point data format did you use ?
You are of course aware that the header of the file *does* scale and
move the points ?
It's a binary format, not the best one to work with (first of all,
endianess is not always the same everywhere)
Save some time, here are the 11 variants:
     0: Core-0. 20 bytes. Includes x,y,z values, intensity of pulse
return, return identification, classification (see below), scan angle,
and identifier for the source for this point data, if derived from an
earlier dataset.
     1: Core-0 + GPS time
     2: Core-0 + three 16-bit color channels
     3: Core-0 + GPS time and three 16-bit color channels
     4: Type 1 + wave packets. Wave packets may be stored in the file or
in an auxiliary file with the same name and extension .wdp.
     5: Type 3 + wave packets
     6: Core-6 (allowing more bits for return data, and making GPS time
mandatory)
     7: Core-6 + three 16-bit color channels
     8: Type 7 + NIR (near infra-red) channel
     9: Core-6 + wave packets
     10: Type 9 + three color channels and NIR channel.
(from
https://www.loc.gov/preservation/digital/formats/fdd/fdd000418.shtml
