I want povray to produce images in both correct and reversed aspect(mirror).
I thought I saw the keyword "invert" somewhere in the documentation but maybe it
was a dream. how can I reverse my output images or get my camera to behave like
a mirror?
Q) Why?
A) Because <REASONS>
> a mirror?
> Q) Why?
suppose you want to reverse everything left-right.
instead of "right x" use "right -x" to reverse the camera view frustrum vector.
https://wiki.povray.org/content/Reference:Camera
>> a mirror?
>> Q) Why?
To mirror an object (with image map): scale<1,1,-1>
m@
That is simple and elegant! And never occurred to me. It also works correctly
even if the camera has an added 'rotation', like...
perspective
location <-.15, 1.48, -2>
look_at <.35, 1.48, 0>
right -x*image_width/image_height
angle 29
rotate 45*y
I'm thinking that it would be nice to be able to render *both* standard and
reversed views at the same time, side by side in the same image, but I have no
idea how it could be done. I seem to recall that such a dual-camera(?) render
may have been explained in an old newsgroup post... or maybe it's just my faulty
old memory playing tricks on me...
> camera {
> perspective
> angle 29
> rotate 45*y
Yeah, well, when I've screwed up the camera setup and/or position enough times,
I get to have a deeper appreciation of my little oopsies. I've also had to
convert between the z-up and y-up vector spaces when modeling things, so that
"helped" too. ;)
Playing with transforms and basis vectors let me sorta flesh all that out a bit.
Try:
up <1, 1, 0>
That might have been a feature in Uberpov or Megapov ...
What I guess you could do is create a whole scene inside of a union:
#declare Scene = union {...}
And then do:
#declare Left = object {Scene translate -x*VALUE}
#declare Right = object {Left scale <-1, 1, 1>}
object {Left}
object {Right}
To get both "views" in the same render.
